- Forum
- Hardware
- AMD
- DFI nF4-DAGF – The board considers not only Price but also OC
I just got it 2 days ago and had a preview
Let see if this nF4 board, under 110USD, has DFI’s great OC blood
Look at the box first, another style, depending on personal like
The full view of board, completely different with DFI LP series
Boards left corner
Boards right corner with 4 SATA ports. Hope they can change to more pretty Chipset FAN...
The components around the CPU
The full view of IO panel, it’s with 1394!
The bundle accessories are very simple but enough.. The worse point is the manual is too thin.
Test Platform Configuration
AMD K8 939 3000+ 0441SPMW(CPU No.2)
DFI nF4-DAGF
GSkill 512LA
Leadtek PX6200TD
Maxtor 30GB 5400rpm
DELTA 300W
Let’s check the BIOS first
CPU Frequency and Voltage Control
CPU maximum can rise default voltage to 0.45V more
DRAM maximum is 3.2V
DRAM Parameter, not as many as LP but compare to the others, the adjustable values are quite many already
Basic Test,256MBX2 DDR600 1T 2.6V Reached
Long time no use my No.2 CPU...1.47V 2.6G Reached
6200 modified to 8 pipes, test 3Dmark2003 by default 300/500, the numbers are still over the standard
Coclusion:
If DFI can make the user manual be more rich, in this price, nF4-DAGF can be the value board also equips the OC ability.
After MSI, DFI is coming
For the users who don’t have such high budget, this is great news.
PS: This version is not the released version. The test result is for reference only. We are glad to see if the released version can reach higher performance.
Something more exciting is...My mobile also can watch video…
WOW...Really Happy
Next time, probably I will test this mobile phone or the 520W PSU I bought today
Just show you some photos which mobile playing video
- You may not post replies
- You may not edit your posts
Forum Rules
