I made a small alteration to the vdimm=vio mod so I thought I would share it. Basically, instead of connecting the mod wire to a pin on the dimm slot, I connect it to the vdimm capacitors.
This makes it much easier/safer to do the soldering, and it also more evenly distributes the voltage. There are many more than just one vdd pin on the slots, so connecting a wire to one of those pins makes all the current have to go through that one trace. This is what causes a vdimm droop that some people have noticed and gotten around by connecting to multiple slots.
I have connected to 3 of the 4 possible capacitors, the fourth I did not because it was surrounded by traces. Probably two or maybe even one would be plenty. The main one that you should do is the one next to the vdimm mosfet (lowest one in the picture).
Also, probably 22-24 Ga wire would work best, I used 20Ga because it was all that was available at the time.
Here's a picture of the mod:
Please post your thoughts/questions and if you've seen or done this method before. Thanks!
