Just to note , that while DFI is making some adjustments to their NF4 motherboard and bios we have found that swaping slots with 2 good units
may increase your performance greatly when using slots 2 and 4 when using any winbond based product.
If you are already over 250 Mhz this may not work as well , or slot swaping could decrease your performance.
Due to the non-standard trace routing and termination resistance on the DIMM slots as well as drive strength settings in the bios , you may need to swap dram slots to provide error free results with winbond die based products.
If your having trouble with any winbond die product, just swap slots and see how it runs , slot swaping under certain circumstances will provide up to a 50Mhz diference in overclocking
In addition something to note ,when switching from one set of memory to another we have found you may need to hard reset the cmos to allow booting.
Hm, I use the orange slots, is it 2 + 4 ? Working fine as shown here:
