Got bored today so i made this CPU voltage table:
Hope its useful to someone
EDIT: Made some corrections to the table
good job
E5200
Asus P5Q-VM
A-DATA 2x2GB
Zotac 8800GT
500W Seasonic
Originally Posted by trakslacker
Thanks a lot, usefull contribution.
One of the problems is that even with the math done, the voltages reported in BIOS are not in line with the table. It seems that the higher multipliers do not always produce higher voltages. For instance in my testing 1.400x126(1.764), 1.325x133(1.762), 1.300x136(1.768), 155x113(1.752) all result in the same 1.72v reported by BIOS and everything from 1.648 to 1.680 reported in CPUZ. It is good from the start, but it might be advisable to stick with multipliers of 123% and lower.
LP UT nF4 Ultra-D Rev. A.02 03/31 BIOS, Geil Ultra-X PC4400 (2x512) 260@2.5,3,3,8@2.8v, 0451 3500+ Winchester @ 260x10@1.6v, Black Ice Extreme, MCW6002, Maze4 GPU, AquaXtreme 50Z, Seagate 80GB SATA w/NCQ, Maxtor DiamondMax 10 300GB SATA w/NCQ, NEC 3200 DVD-RW, Liteon 1633 DVD-RW, Sony floppy, ATech USB 2.0 Internal card reader, ATI X850XT PE @ 592/614, Soundblaster Audigy2 ZS, Antec NeoPower 480. All in a Kingwin KT-424 case.
Ive noticed that using lower voltages and high % seems to have a limit of 1.4V e.g 1.150 and 126% gives just under 1.4V
thx realy usefull table
Good job...looking for something like this. Too lazy to make my own![]()
WOW, great work.. That must of taken some time.. Very useful for sure... How did you keep from getting all those different numbers mixed up while typing that, LOL?
yea, that's true but the table is here not 2 tell u the exact voltage but +/-.Originally Posted by WheresWaldo
E5200
Asus P5Q-VM
A-DATA 2x2GB
Zotac 8800GT
500W Seasonic
Here the same - 12 x 279 with 1,500 x 123% ist 1,77 in Smartguardian, 1,776 in CPU-Z and 1,792 in CBI so I think it is somethin' between 1,77 and 1,78 real but normally it should be 1,845.
But I recognised the board is undervolting even no special vid is used so maybe this comes from the undervolting issue..........![]()
Previous system:
DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
Yea DFI is undervolting but it holds the volts stable.
E5200
Asus P5Q-VM
A-DATA 2x2GB
Zotac 8800GT
500W Seasonic
has anyone noticed that the volts go up considerably when you stress the cpu? For example I get 1.62v @ idle and 1.7-1.73v @ load
C2D E6300 @ 3.5ghz | 2x1GB ADATA "Micron D9" @ 500 4-4-4-12 2.3v | Asus P5B-E Plus C2 | Sapphire X1900XT 512MB | Tuniq Tower 120
Originally Posted by _Eduard_
Can not confirm - got always extrem stable volts at all loads - maybe Your PSU is too weak ?
Previous system:
^^, it should b ur PSU, I had/have very stable volts on MSI K8N Neo 2 & DFI NF4Originally Posted by HARDCORECLOCKER
E5200
Asus P5Q-VM
A-DATA 2x2GB
Zotac 8800GT
500W Seasonic
I had the same issue with my msi neo2, when i stressed the cpu the voltage raised, but at the DFi NF4 it is rock stable maks 0.01 volts variation... now thats awsome![]()
OPTERON 148 @ 3200mhz Water cooled
1024 mb Muskin REEDLINE xp4000
2x7800 gtx SLI @ 570/1445
Even though some of these settings don't physically translate into usage, the table serves as a good base for any new user. Great job.
deception``
Opteron 146 CABYE 0540FPAW @ 2.9 ~ 3.0 Ghz, DFI Lanparty NF4 Ultra-D, 2x512 OCZ PC 4800 Platinum, Msi 6600GT, Big Typhoon, 2x250gb Hitachi T7K250 Hard Drives, OCZ Powerstream 520W, Audigy 2Zs, Logitech z-5300e
Putting in use Excel,
I didn't use excel, i laboured over many hours to create this![]()
Great work. Now, can someone mod the bios so that you can just enter the final voltage without having to adjust the other values? That would be the simplest and most convenient approach.
no, a weak psu would drop the voltage even more under load. both my dfi nf3-ut and msi k8n neo plat. do this... probably something to do with the efficiency of the PWM circuit with varying load.Originally Posted by HARDCORECLOCKER
Got a fan over those memory sticks? No? Well get to it before you kill them
Still could be something with the PSU possiblly. I've got a cheap PSU that has the 12v rail go way up under load. Like idle is 12.6v and load is 13v or 13.1v sometimes.
jjcom
nice table![]()
mobo: strix b350f
gpu: rx580 1366/2000
cpu: ryzen 1700 @ 3.8ghz
ram: 32 gb gskill 2400 @ 3000
psu: coarsair 1kw
hdd's: samsung 500gb ssd 1tb & 3tb hdd
Great work and thanksive been looking for a way of getting 1.73v for AGES but too lazy to work it out myself
Thanks![]()
AN OPEN MIND, WITH A CLOSED FIST.
With a multimeter?Originally Posted by pudds
great post this is just what i was looking for after wiping out cmos.. thanks for taking the time to make this for us.
Current Setup:
-9850 GX2's in Quad SLI config
-Asus P5N32-SLI MB
-2x512mb of PC2-5300 DDR2
-Intel Celeron D OC'd to 3.2Ghz
-Windows Me with XP theme
-WD Caviar 20GB Hard Drive
-Zip drive
-Jazz drive
-3.5" floppy drive
-5.25" floppy drive
