http://www.scan.co.uk/Products/Prod...roductID=135086
or
http://www.scan.co.uk/Products/Prod...roductID=139772
Im going to be running a 650 P4 in the motherboard and it will be watercooled.
I am undecided between these two. The dfi has some problems with 6xx series processors and sometimes you cant even flash to the latest bios unless you have a 5xx series to do so.
As far as I know the Asus supports 6xx series out of the box but I am not to sure on this. Price/performance is what I want but the 875 is a better chipset than the 865 but they both have pro's and cons.
Which would any of you suggest me to get?
Thanks in advance for your input
