03-25-2005, 02:15 AM
#1
Xtreme X.I.P.
venice on ice 2850mhz 1.38v -40°C
first of all BIG thanks to s7e9h3n for making this preview possible!
thanks a lot for bringing those chips to XS and letting us freeze and torture them
and of course big thanks to our trusty member chunkylover77 for letting us play with his 3500+!
thx a lot guys!
after last weeks results of a 3800+ venice from s7e9h3n here
pc ice now received the 3500+ venice from to s7e9h3n to play with it using his phase change skills
and it looks like the low temp bug is gone!!!
i will keep adding more results here step by step
EDIT: bad news! opp cant get it to work under his cascade, seems there is still a low temp bug :S
now lets hope E4 changes that, so far i only heard that E4 had changes made in the temp probe , thats why it needs a bios update to work on almost all boards.
i really hope the low temp problems dont have to do with the manufacturing process!
phase change cooled system specs:
AMD 3500+ 2.2ghz dafault vcore 1.4v 90nm Rev E3 Venice core @-40°C
pc ice single stage phase change cooling
DFI NF4 ultra D bios 3/14
2x512mb G-SKILL PC4800FF @ddr660 2.5-3-3-6 1T
SAPPHIRE X850XTPE 688 / 644
OCZ POWERSTREAM 420w
here are the first results at stock speed (11x200):
................cpu-z............... ......sandra arythmetic....... ........sandra memory........ ...........3dmark 2001......... .........3dmark 2003.......... ..........3dmark 2005.........
click on the thumbs for a larger image
the bios undervolts, bump to 1.4v real gives 2850mhz:
.........sandra memory........ ........sandra memory........ ......sandra arythmetic....... ...........3dmark 2001......... ...........3dmark 2001.........
2950mhz with still the same vcore (1.4v):
.........sandra memory........ ......sandra arythmetic....... ............superPI 1M.......... .............the cooling..........
3ghz and still default vcore (1.4v) :
........sandra memory........ ........sandra memory........ ...........3dmark 2001......... ............aquamark3.......... ............aquamark3..........
3100mhz and still default vcore!!! (1.4v) :
..............cpu-z.............. ..............cpu-z..............
320fsb seems to be no problem for this memory controller :
................cpu-z............... ........sandra memory........ ........sandra memory........
watercooled system specs:
asetek waterchill
SAPPHIRE X850XTPE
stock 11x200 and 11x220 2420mhz :
...............cpu-z................ ...............cpu-z................ ........sandra memory........ ......sandra arythmetic....... .............waterblock........... ...........idle temps............
11x240 2640mhz :
...............cpu-z................ .......sandra arythmetic...... ........sandra memory........
11x260 2860mhz and 11x258 2838mhz :
...............cpu-z................ .......sandra arythmetic...... ........sandra memory........ .......sandra memory......... ...........3dmark 2001......... ...........3dmark 2001........
memory controller oddities :
..............sandra............... .............sandra...............
update:
cpu-z 1.27.2 or the latest CBID couldnt recognize the cpu either, dave will try to use cpu-z 1.27.2 to verify a shot though
update:
the superpi version he used was not sse3 patched, but he will test superpi with and without the sse3 patch to see what the difference is and how much sse3 helps those chips to perform
update:
the bios incompability issues you have all heard about are about the E4 stepping (san diego 1024kb L2 cache 90nm) not the E3 (venice 512kb L2 cache 90nm) so you dont need a bios update for the venice chips that will be released on april 4th
update:
we will add watercooled and aircooled results later
update:
please stop pming pc ice! hes very busy atm pushing this baby even further
update:
the screenshot indicates he is running 2GB of memory, this is a bug!
however, he will test with 4 DS 512mb sticks and post results
update:
bad news, pc ice hurt his back has the water and air results on a raid array he has problems accessing now. he will post the results asap though.
lets all wish dave to get well again soon
update:
more than stock vcore barely seems to do anything to this chip
lets hope that its just because this is an early chip and that future chips will scale better with more vcore. and 2.8ghz with stock vcore on water is not a bad result by any means
update:
pc ice tried it again under his cascade and the chip didnt boot at -90°C either, so theres def a low temp bug. :/
_
__________________
Nvidia: Tesla C2050 and C2070 products (GT300) will retail for $2,499 and $3,999
JHH (Nvidia) sep 2009: The best way to always be the number1 is to have no backup plan link
JHH (Nvidia) nov 2009: Tolerance for failure is important, it puts our employees in a position where they are willing to try new ideas link
Solus Corvus - maybe things would get better if people addressed the content of each others posts instead of trying to discredit each other with insults and poisoning the well. Attack the argument not the person.
Hail Voltage! The Solution to AND Source of all our Hardware Problems
03-25-2005, 02:26 AM
#2
Xtreme 3D Team Member
woah! Thats a sweet overclock man!
crank those volts up a bit and lets see 3GHz!
Awsome 3dmark 2k1 scores too.
__________________
03-25-2005, 02:27 AM
#3
Woah! .6ghz improvement with stock volts! nice work man, thats a sexy chip,
really goes to show that 3d mark 2001 is based alot on CPU, as i use to think that 3dmarks were mostly video card related. thats a great improvement,
thanks for pics  Good work
__________________
[ AMD Athlon XP Barton 3000+ @ 2.41ghz - 13 x 185 @ 1.75v - On Air ]
03-25-2005, 02:28 AM
#4
Strictly Business
Take note of the 2GB of RAM at 285MHz 2.5-3-3-7.
__________________
Brayden rules!
OVERCLOCKING - The process of installing high hopes, dumb luck, and several paychecks into a rectangular
box which transmits a signal to a screen that displays your fate. The outcome is usually depressing.
03-25-2005, 02:30 AM
#5
Xtreme X.I.P.
yeah and dave said it could do 330mhz :o
dont know if thats with 2gb though
great work dave! keep pushing that baby
__________________
03-25-2005, 02:31 AM
#6
Strictly Business
I'm pretty sure it is. Those new memory controllers rock!
__________________
Brayden rules!
#7
Corsair Engineering
Nice! I believe CPU-Z showing 2048MB is a bug, right?
also...
G-SKILL XXXXXXXX @ddr660 2.5-3-3-6 1T
__________________
3ch 3x2GB WR - Dominator 2000C7GT @ DDR3-2560 7-8-7-20
03-25-2005, 02:33 AM
#8
Strictly Business
bachus_anonym - It's not a bug. And about the G.Skill, I'll keep my mouth shut and let pc ice do the talking.
__________________
Brayden rules!
03-25-2005, 02:41 AM
#9
Corsair Engineering
are you sure, Conrad ? - http://www.xtremesystems.org/forums/...&postcount=430
otherwise, it would be awesome
maybe that gskill is FF... let's wait for pc ice...
EDIT: Just looked at Sandra... "Memory used by test - 512MB"
So it's 1GB
__________________
03-25-2005, 02:45 AM
#10
Strictly Business
You're right. I was just looking at that as well.
__________________
Brayden rules!
03-25-2005, 02:49 AM
#11
at last a 3500+ venice being tested
looking forward to more results...
03-25-2005, 02:50 AM
#12
Xtreme X.I.P.
So it's 1GB
should have seen this as well
__________________
03-25-2005, 03:20 AM
#13
So it's 1GB
Dang! Too late! I saw the same thing well after I had already crapped my pants! Would still like to know if 4x512 will run 1T. Wouldn't mind if it results in slighty lower OC, but don't want the double whammy of lower HTT and 2T timing.
__________________
Bench rig now in constant change, with scraps thrown to my game rig. 2x8800GTX + e8400 = 29K 3DMark05
03-25-2005, 03:40 AM
#14
AMD Fanboy
woot!
*buys a 3200+*
__________________
4*256 KHX3200 bh5 | x850xt | OCZ600 | no mobo | no CPU
Broken Home-built single stage phase change | Unfinished watercooling
yes i have AIM, yes you can send me a message. EvilSpork3 i dare you.
Those who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety -benjamin franklin
03-25-2005, 03:55 AM
#15
Xtreme X.I.P.
I just fell out of my chair... stock volts and 2.8ghz.... i think i smell 4ghz on venice!! Dont call me ti4200 but I think we got something here.
Cant wait to get my winnie out of here and grab a venice.
03-25-2005, 03:57 AM
#16
Xtreme Guru
probably he has 4x512Mb and we dont see lower? Because that would be the first time I see CPUZ showing bad memory size.... If it is a bug, it is probably because of the new Memory Controller?
#17
03-25-2005, 03:58 AM
#18
Xtreme Guru
Its doing a while GeForce ain`t connected.... you are replacing him? lol
03-25-2005, 04:31 AM
#19
in the 3th screenshot (sisoft sandra mem bench) u can clearly see its 2x 512MB
u can also see some of the timings..
does that "2CMD" mean its only running at 2T?
also im wondering why its only using 2 way mem interleaving?
isnt that normally 4 way?
intresting results btw, would love to know how it does at normal temps too though
__________________
DFI NF4 Ultra-D (704-2bt bios) + Swiftech CPU heatsink on the chipset
AMD Athlon64 Venice 3200+ 0518APAW IHS removed @ 9x300 @ 1.66v + Swiftech Storm G4
2x512MB Corsair XMS PC4400C25 DDR-RAM @ 300Mhz @ 2.8v (2.5 4 4 8)
XFX GF6600GT @ core: 600Mhz ; mem: 1150Mhz + DD Maze 4 Acetal + OCZ RAM Sinks
A-Open 1648AAP/PRO DVD-ROM | Benq DW1620A DVD-WRITER
2x Samsung SATA300 250GB (RAID0) + 2x Samsung SATA300 120GB (RAID1)
OCZ Powerstream 520W | CoolerMaster Stacker Case
Thermochill PA120.2 Radiator | DD D5 Pump
03-25-2005, 04:38 AM
#20
Xtreme Recruit
omg rocks!!!
__________________
Venice 3000+
MSI K8N Neo2 Platinum
2x512 OCZ EL Platinum Rev.2
Powercolor x800 pro ViVo @ XT PE 16 Pipes
OCZ 520W PSU
high-end watercooling
03-25-2005, 04:39 AM
#21
Xtreme X.I.P.
if we have enough time dave will also post watercooling and air cooling results
__________________
03-25-2005, 04:55 AM
#22
What's that you say? Cold bug gone?
 Hot diggity damn
I'm going to see what my LS can do with one of these babys ASAP. Might have to change my  motherboard though.
G
03-25-2005, 05:28 AM
#23
thats pretty damn good results so far, any preorders online anywhere yet? heh
03-25-2005, 05:32 AM
#24
and which is the stepping ?
03-25-2005, 05:38 AM
#25
Xtreme X.I.P.
ADA3500DAA4BP
CBBLE 0504EPAW
same as the 3500+ from steven i think
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
