Has anybody successfully gotten this installed on a linux machine? I am having a bit of trouble here getting it set up on my linux box.
hi.
jjcom has.
http://www.xtremesystems.org/forums/...943#post777943
So far the easiest linux distro to use and set up DDOL has been Suse 9.2 for me...It has java support already loaded when you do the initial install so you don't have to mess with anything. I just downloaded the linux installer and have 4 instances running on my DX box ......![]()
I have D2OL running on 2 Gentoo Linux boxes. On one I used the complete install available here. On the other I did the expert (java yourself) version. No difference in speed.
Both are running GUI-less BASH prompt only. I start them by:
IIRC I had to edit the config files to reflect my paths.Code:cd /home/paladin/d2ol/D2OL ./D2OL controller:cli
DeXter::2xXeon2.4@3200, GF6800, PC-DL, 1gb Centon, IWT+panaflo air, Win7
Quad::Q6600(g0)@3400(1.30V), GTX275, 965P-DS3, 4gb HyperX, Asus SilentSquare (air), Win7_64U
NuQuad::Q9400@3300(1.24V), 8800GT, G31M-ES2L, 2gb Patriot, stock air (bigger Q6600 one), WinXP64
Crunch::E4300@2400, onboard, GF7100PVT-M3, 2gb Patriot CL5, stock air, Vista64U
I use SuSE Linux 9.0 and just downloaded the GUI installer with Java. All I did was just follow what the webpage said and away I went. Its now crunching at 2.17ghz...I need to up the volts some more
I would guess, try and get Java downloaded and installed before using D2OL. Maybe that will solve the issue?
jjcom
It's a lot easier to just use the installer with it's own jvm. I've had it running on most linux distros. I'd recommend altering the D2OL/res/general.prp to set LaunchMain=false, that way it's not really using java anyway.
then as mentioned earlier in the thread, start it with ./D2OL controller:cli
currently it's on all of my gentoo systems, an opteron running Suse 9.1 and a few redhat systems.
Bok
Hey Bok, thanks for the information. could you maybe give me a few more details on customizing it to run how you specified, i am pretty unfamiliar with DDOL.
OT, but I never saw you come in the door...Originally Posted by jaawood
Welcome to XS/D2OL team, jaawood!
Hi there Bok, how did it all go with your NCCH-DL?
Crunching to Crush Cancer
Somebody, Stop Me!![]()
Haha, thanks!!!
Alright, success!! I just tryed the non gui install, and it worked like a charm, even though it says for experts only, and I am by no means and expert!
Edit1: Unfortuantely, java is eating like 50% of my cpu even after i exit the fancy interface, but i am going to work on getting rid of that now.
Edit2: Now it works without using any java after i set it to not launch the fancy interface dealie, and restarted it, so all it well.
Well I let it run all night, and when I got up this morning, I found out that java is now hogging about 70% of my cpu, so basically not much is getting used for D2OL. Does anybody know how to fix this? It is really annoying, and also actually makes my system quite qlitchy.
I just downloaded the Linux client (gui installer) and I get loads of Java errors:
Preparing to install...
Extracting the JRE from the installer archive...
Unpacking the JRE...
Extracting the installation resources from the installer archive...
Configuring the installer for this system's environment...
Launching installer...
Invocation of this Java Application has caused an InvocationTargetException. This application will now exit. (LAX)
Stack Trace:
java.lang.NoClassDefFoundError
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:140)
at java.awt.GraphicsEnvironment.getLocalGraphicsEnvir onment(GraphicsEnvironment.java:62)
at java.awt.Window.init(Window.java:224)
at java.awt.Window.<init>(Window.java:268)
at java.awt.Frame.<init>(Frame.java:398)
at java.awt.Frame.<init>(Frame.java:363)
at com.zerog.ia.installer.Main.c(Unknown Source)
at com.zerog.ia.installer.Main.main(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Nativ e Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Native MethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at com.zerog.lax.LAX.launch(Unknown Source)
at com.zerog.lax.LAX.main(Unknown Source)
GUI-
Just a note from my past experience:
Linux doesnt take to oc as well as ms os
just my opinion
point: Tried to turn the fsb on my xeons to just 115 and got kernel panic crash
FX-8320
Asus M5A97 r2.0
8 Gb Gskill
Radeon 7870 Tahiti LE
Corsair 750 watt
Very true. Sometimes I can get Windows to boot fine, but at the same speed, the kernel will throw out a few memory stacks and reboot. Although, it is kind of a memory stability test in itself![]()
m0p, did you find out how to get D2OL to install when you got that error?
A wolf in wolves clothing.
Yeah I installed the JRE'less version and ran it in my system's JRE.
ok, thanks. I'll give that a try
