I just wanted to make a few notes concerning some of the new OCZ products so that people have a fair idea of what there getting , And what speeds to expect , so I will make a quick list
OCZ " Value VX " PC-3200 Value with winbond UTT - ( should be priced around 130-140 USD )
This product is only tested for the value specification , but uses winbond utt, a very high percentage will do 220-240 with the right voltage , with I would guess half overall do above 240 ( 2-2-2 ). A small percentage will do 2-2-2 at 2.85-2.9 volts ( these are lucky sticks , not the norm )
if your trying to squeeze a few extra Mhz try 2-3-2
OCZ PC-3200 VX ( 2nd lowest in pricing about 200USD now and dropping )
You guys should know what to expect now , but I will state it for the record
these do on average 240 , many people after burn in get higher I have seen 250-260 ( I am sure not many do 260 ) , if your getting over 250 dont trade these in for VX-4000 , it just not a good deal if your trying to squeeze a few extra Mhz try 2-3-2
OCZ-4000 VX ( price should be dropping )
These should do at least the specification , but these of course dont have the same overhead the VX-3200 do , they are meant for those who want to hit 250 minimum, now some percentage of these will do 260 or even 265 after burn in , but thats not certain , only a very small percentage of the WB UTT chips meet our test specification for VX-4000.
OCZ PC-3200 Gold 2-2-2 ( should be priced less than PC-3200 plat rev 2 )
New Product using BH die , does 2-2-2 at 2.85 , higher speeds at higher voltages are possible but we dont screen for those , we screen for 2-2-2 at the lowest voltage
For those of you who have asked , where do all the lower performing chips go
most end up in these products.
OCZ PC-3200 Value ( not listed as a winbond chip )
OCZ PC-2700 performance
Just wanted to make sure everyone knows what to expect.![]()
