Results 1 to 25 of 39
Thread: OFFICIAL ABIT AN8 Series bugs tips and tweaks thread
Threaded View
    Brilliant Idiot
    Jan 2005
    Hell on Earth
    Ok first off there is no diff between the fatality an8 3rd eye and vanilla an8 motherboard.
    *Reviews*
    pc perspective
    http://www.pcper.com/article.php?aid=120&type=expert
    doomed pc
    http://www.doomedpc.com/drupal-4.5.2...efab6e21aeb41c
    the tech report
    http://techreport.com/onearticle.x/8108
    Xbit labs
    http://www.xbitlabs.com/articles/mai...al1ty-an8.html
    this is a pic of a vanilla an8 and ive circled the IC that controls memory ddr voltage and and vtt voltage.
    voltage ranges
    vcore 13m up to 1.85v
    vcore 90nm up to 1.75v
    ddrv up to 2.8v
    vtt up t0 1.4v
    nf4v up to 1.8v
    htv up to 1.35v
    vcore ref up to +.1v
    vddr ref up to +.1v
    Pros
    very stable
    voltages do not fluctuate
    can reach 385 fsb without voltage increase to nf4 or ht
    when pushing OC to high need only to shut power off then reboot and bios will automatically enter safe mode no need to reset cmos.
    cons
    floppy ide is in a undesireable location.
    getting windows to recognize a bootable raid array is a pain.
    ddrv only go to 1.8v and vtt does not track(requires a vtt and ddrv mod)
    **Multiplier 5x for cpu is buggy i highly reccomend not using**
    POST code info
    Known good post codes are as follows
    "FF" is the normal post code you should get upon entering windows without abit software installed.
    "1.7." is a normal postcode you will get with abit guru installed this should be the code you see when windows has completed booting and guru clock yellow icon has flashed on.
    "2.2." is a normal post code in windows with abit eq software running.
    "5.6." is a normal post code in windows with abit OC guru software running.
    ***TIP for those using 256mb X 2 and random prime crashes***
    Try disabling bank interleave
    ***TIP for running high FSB***
    DO NOT cold boot at 350 or higher fsb. In order to attain a high fsb first boot at 300 then work your way up from there. DO NOT power off pc only restart it. POWERING OFF pc will result in activating abits safe mode and a failed overclock attempt.
    ***TIP for setting up raid***
    Win 2k must have a integrated sp4 install disk or it will not recognize raid drivers.
    Win XP must have a integrated sp2 install disk or it will not recognize drivers.
    For both OS's If followed all raid setup instructions and windows setup still does not recognize raid array do these steps in this order.
    1. do a low level format on all drives to be used in array.
    2. enable raid in bios exit and save
    3. create a raid array and make sure you set the array to bootable
    4. go back into bios and make sure the raid array is recognized and is your primary bootable hard drive
    5. start windows setup hit f6
    If you need any help with raid after this explanation than you shouldnt be setting up raid.
    ***OTES FAN TIP***
    Some people have stated that the OTES fans dont come on or barely run. Go into bios and guru clock section. At top of screen you will see fan EQ once in the guru clock menu. In order to run the fans constantly put all fan controls to disabled and they will run full speed. You can also configure temps so they come on sooner or run at a specified rpm.
    current recent bios is 12
    bios 11 release( mutipliers not working)
    bios 12 fixes(update nvraid/ update nvmm/multipliers fixed)
    bios 13 is the current bios i use and seems to be the most stable.
    bios 14 most of the users here are using this bios
    bios 15 **I highly suggest not using. reports of corrupted drives and bsod are flooding the forums with this bios.**
    *EDIT*NF4 chip runs very hot. You could definitely benefit from watercooling this chip.
    *EDIT* XP 120 and XP 90 fit this motherboard however you lose the ram cooler if mounting xp 120 over ram slots.
    *EDIT* Max htt reached to date was 385 htt stable with default voltages.
    *EDIT* There is a ongoing thread in abit support forum on XS that we could use some support on for pressuring abit into releasing a bios with higher vddr and vtt. Your post/support is appreciated.
    Link http://www.xtremesystems.org/forums/...213#post761213
    *EDIT when installing the an8 youll note that right between northbridge and ddr dimms and at the lowest IDE connector there is no metal surrounding for mounting a screw. Most of us AN8 users have installed a post and put a piece of electrical tape over the post so that the mobo does not lack support in these areas. We did not install a screw.
    *EDIT Apparently some people are experiencing issues with a usb mouse or keyboard installed. I would suggest using a usb to ps2 adapter if your having issues. I am currently using a usb trackball mouse by logitech with no issues though.
    *EDIT Apparently the AN8 when using maxtor 250gb drives will fail to post and give code 75. Am not sure atm if this is a issues with only maxtor 250gb drives or just any drive over 200gb. User who reported this issue had no problems using 4x 200 gb maxtors.
    I will continue to update this thread as necessary. If theres anything i missed feel free to add to it or PM me and i will add to it.
