for whatever reason i was driven to test TRAS settings with bh5 on my dfi board today.
i used everest read benchmark to test at 2-2-2-X at 9x265mhz
i recorded results over several tests and threw out the highest and lowest and any tests that just plain didnt fit in. unfitting numbers like a sudden 20mb/s drop for one test i threw out. i took all the numbers and got an average score.
i did this for all settings 0 through 12, and a few tests from 12 to 15 which arent worth reporting(very bad).
below is a chart of my findings. dont hold the exact values as rock solid as i would need a much larger number of tests to get better results, but what i have is pretty accurate.
i tested tras 2 many times to be sure the number was true. the value for tras 0 should be a bit higher, similar to tras 1.
accounting for margin of error i would say anything 0 through 5 will be similar performance, with a slight boost with tras 2 oddly.
ill post a64 tweaker screenshots tomorow, for now here is the chart of my findings:
