Hello,
I needed a Vcore mod so I searched the Internet but no luck, so I started to look how I could make a mod.
You will have te solder a wire to PIN 23 of the voltage chip that is located above the cpu. with a 10K trim pot to the GND it gives a minimum of 1.8V (Haven't tested more). But I doesn't help much for me I will have to test some more.
I will post a pic asap when it 100 % works
