Page 1 of 6 1234 ... LastLast
Results 1 to 25 of 146
Thread: X700pro volt mods?
    Jun 2004
    USA, Vermont
    X700pro volt mods?
    i need some volt mods for an x700pro (saphire, toxic (ed))
    http://smbach.com/mad.gif
    Opty 175 Rig
    Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
    AM3 Rig
    Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
    DFI NF4 BIOS Guide
    Xtreme Vmod mod
    Aug 2004
    Cornwall/Newcastle uni, UK
    Can you post some pictures of the front and back of the card please.
    Jun 2004
    USA, Vermont
    Srry no digi came...i will look online to see if i can't find any...i think that is the refernce board/design though
    Opty 175 Rig
    AM3 Rig
    DFI NF4 BIOS Guide
    Jan 2004
    Sweden
    i can fix pic for you later, but i got a connect3d and the pics wont be high res but i can fix a close look to a area if wanted
    dont laugh at the tiny stock cooler
    Xtreme Vmod mod
    Aug 2004
    Can you tell me what is written on the chips I have marked please.
    http://www.xtremesystems.org/forums/...id=25875&stc=1
    Also, can someone try to get some pictures of the back of the card as well please.
    Jan 2004
    Sweden
    Quote Originally Posted by persivore
    sure can fix a pic of the backside and fix the chips later but now im of for some gaming got the card earlyier today and havent had any time to game
    Overclocking X.I.P. Otaku
    Nov 2004
    Kiminomori, Chiba, Japan
    bottom left chip:
    RT1973A
    CL55M90M
    top left chips:
    D39AT (there's an italic "f" in front of this line but I think it's just a logo?)
    FDS
    7096N3
    top right chips:
    4804
    0312
    Sep 2002
    Farmington, MI
    Here's some detailed shots of the card. x700 Pro
    Please don't download this file unles you need the pictures to help with the mod... you will kill my connection as the file is 20mb.
    DFI Lanparty NF4, A64 3200+ @ 2.5, 1gig BH5/6, 80GB JB, 2x 120gb seagate SATA Raid 0.
    HeatWare|My 04 R/T Neon| My Best Aircooled 3dmark|1.07TB Raid5 Linux Server
    Jan 2003
    Sweden
    Here's some measure points for a Sapphire x700pro 128MB
    And here's a pic of (where I think) the chip controling vgpu and the surrounding area. Tech-gurus be welcome to take a look (click image for bigger)
    MSI+A64 4000+ X800XT PE : 39179
    TECHSWEDEN.ORG 3D MARK TEAM
    Xtreme Vmod mod
    Aug 2004
    Quote Originally Posted by gocchin
    bottom left chip:
    RT1973A
    CL55M90M
    top left chips:
    FDS
    7096N3
    top right chips:
    4804
    0312
    Thanks. It looks like the chips on the top left and right are the MOSFETs for the regulators, but I can't find any information on the RT1973A chip, but I don't think its important.
    Quote Originally Posted by docah
    Thanks for the pictures. It looks like the card is using 2 ISL6522 chips for the regulators. Can someone measure the voltages on pins 5 and 8 as marked in the picture, so that I can find out which chip is controlling which voltage.
    http://www.drunken-student.co.uk/tom...20vc%20005.jpg
    Xtreme Legend
    Nov 2002
    Sweden
    I also think the FB/Pin5 is interresting for this mod.
    It is also possible that one is for VDD and the other for VDDQ.
    "In mild doses, ethylene produces states of euphoria, associated with stimulus
    to the pleasure centres of the human brain."
    Intel benching: 3DMark Vantage: E69642, P37253, H30363, X22138
    Swedish Overclocking Champion 2006 - Celeron Mobile 1400 @ 4243MHz - 203%
    Jun 2004
    Oregon
    The one closest to the front is vddr and should be ok witha 20K vr FB to GND., the one next to it is for VDDQ and should be fine w/ a 50K VR FB to GND. I couldnt find anything on it just yet but the SP61 32CU chip is definately controlling vgpu.
    -CaT
    Send Me Your Broken Hardware! - Repair Parts and vMod Research!
    Need vMods? PM Me!
    Jun 2004
    Oregon
    ALSO btw persivore, none of the vgpu, vddq, or vmem is going to be on the front of the card.
    Need vMods? PM Me!
    Nov 2004
    So for those with no soldering skills, where do we pencil?
    Jan 2004
    Sweden
    could someone pls post a picture with all the places to solder on to vgpu and vdd, whats vddq?
    Xtreme Vmod mod
    Aug 2004
    The Vgpu is controlled by the SP61 32CU, which is a sipex chip, the SP6132.
    http://www.sipex.com/products/pdf/sp6132.pdf
    Pin 4 of this chip is the feedback pin, so this, or something connected to this pin will be the mod point.
    Jun 2004
    Oregon
    Thanks alot for the info on that SP61 chip persivore. Anybody want to be the guini pig on this one? NOTE: Check resistance from pin 4 to GND before soldering. Then solder the 20K in circuit and measure it again. If its lower youre going to need to use a larger VR, if its higher then just leave it at 20K.
    http://img120.exs.cx/img120/3400/vgpuarea8py.jpg
    -CaT
    Need vMods? PM Me!
  18. #18
    Jun 2004
    Oregon
    This is the vddr mod. Again check resistance from pin 5 to GND, solder the 20K in circuit, and then check it again to make sure its the correct resistance which i belive it is. Use the checkpoints Marquzz posted above to make sure the mod is working and to check the voltage.
    http://img108.exs.cx/img108/4456/closeupvc0081of.jpg
    -CaT
    Need vMods? PM Me!
  19. #19
    Xtreme Legend
    Nov 2002
    Sweden
    Nice work CaTalyst.X, but don't you think we should advice the first person who would like to try it to start with 100k VRs instead?
    It's better to be on the safe side. Either way, be sure to have 20 turn VRs and turn them slowly and check voltages carefully.
  20. #20
    Jun 2004
    Oregon
    Yeah maybe for the vgpu, but thats why i really stressed checking the resistance. For the vddr, 20K should be more than enough. But like i said, check the resistance just to be sure, takes 10 seconds max and could save your card
    -CaT
    Need vMods? PM Me!
  21. #21
    Jun 2004
    USA, Vermont
    HA HA HA this is great i just got linked to my own thread here from ocforums.com....i will check voltages when i find my DMM...it has kinda walked off on me agian. So i will have those voltages for you.
    Opty 175 Rig
    AM3 Rig
    DFI NF4 BIOS Guide
  22. #22
    Jun 2004
    Oregon
    You dont really need to do the votlages I linked u to this thread at OCF Just check the 2 pics i posted above.
    -CaT
    Need vMods? PM Me!
  23. #23
    Jun 2004
    USA, Vermont
    Yeah i know lol that was great thnxs REALY looking into this for me...to tell you the truth i forgot ALL about this thread.
    Opty 175 Rig
    AM3 Rig
    DFI NF4 BIOS Guide
  24. #24
    Jun 2004
    USA, Vermont
    O yeah i will be the guni pig BTW...i should have to mod done by the end of the week...i need some better cooling for the core and ram though...i am going to get a stock p4 or AMD hs then cut up the toxic hs for ram sinks that should work allright to cool it until i get my wb and chiller here...
    Opty 175 Rig
    AM3 Rig
    DFI NF4 BIOS Guide
  25. #25
    Jan 2004
    Sweden
    yeah please post pictures of it when ready, im thinking of trying to vmodd it myself later on
