XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking > Xtreme Pi
Reply
Old 02-26-2005, 07:57 PM   #1
snq
Xtreme X.I.P.
snq's Avatar
Lightbulb Super PI with msec/anticheat mod
Update!
The latest version with cheat protection, more accurate timing and checksum is available here!
Well here it is!
My Super PI mod now also includes anti cheating code. Any attempt to cheat will now horribly fail. I changed the text in the titlebar so you will know from screenshots wether or not a cheatfree version was used.
If anyone does happen to find a way to cheat it please send me a PM telling me how you did it so I can add protection. I doubt people with the skills to cheat this version are seriously interested in faking results
Download here!
And feel free to spread the word!
I won't post a screenshot because I dont want ppl all over the world making fun of my poor PC
Happy benchmarking!
PS: Thanks to ajV for originally posting my mod here on XS and to Kunaak for the tips on making it cheat free!
snq is offline   Reply With Quote
Old 02-26-2005, 08:46 PM   #2
Kunaak
Xtreme 3D Mark Team Staff
Kunaak's Avatar
Send a message via ICQ to Kunaak
I can verify that this version is the the only Cheat Free PI program that I know of.
I tested it as much as possible, and theres little to no cheats possible on this version.
hopefully we don't get some dumb programmer trying to cheat on this version, like we did with CPUZ 1.26...
__________________
Kunaak is offline   Reply With Quote
Old 02-27-2005, 04:47 AM   #3
zakelwe
Xtreme X.I.P.
Looking very good for anti cheat, this and the enhanced timing puts superpi back up there IMO.
Regards
Andy
zakelwe is offline   Reply With Quote
Old 02-27-2005, 07:45 AM   #4
detonator
detonator's Avatar
wooo tnx m8 this is a cool program!!!!
__________________
The God Father OC.Team
detonator is offline   Reply With Quote
Old 02-27-2005, 08:18 AM   #5
detonator
detonator's Avatar
I made few test, on a prescot 3200@3600 (second pc)
classic superpii I score 35.890 process timer cheak
with the new anti cheat i score 36.493...
and Im not the unic, on a italian forum few peeps found the same problem...
any idea?
__________________
Old 02-27-2005, 08:31 AM   #6
snq
Xtreme X.I.P.
snq's Avatar
This version is based on original unpatched Super Pi 1.1E.
The code I added only uses CPU time every now and then and totals to no more than say 2-300 instructions over a whole run, so the results should be exactly the same as with the original, or maybe 1 msec slower if you're really unlucky and cross a msec boundary during those 2-300 instructions
What version are you guys using (url please)? Maybe I based my mod on the wrong version :/
Old 02-27-2005, 11:39 AM   #7
detonator
detonator's Avatar
well here in italy im not the unic, we opend a topic about this new Super pii and they all have the same problem....is give 0.800 more from the classic , personaly I use the english classic version of the superpii Pi 1.1E
if you watch here ,there are some peeps posting even screen showing different scores,I know is not english., but you can undestend
http://forum.hwupgrade.it/showthread...hreadid=891382
__________________
Old 02-27-2005, 12:10 PM   #8
snq
Xtreme X.I.P.
snq's Avatar
Thanks, I'll look into it.
I just did soime quick oc-ing and benching and I came very close to my personal record (like 100 msecs difference). The difference can be explained by that I was running a slighly lower FSB this time. At this moment I can't think of any other explanation than that you guys are comparing it to a different version. But as I said I'll look into it
Edit:
I compared the one you uploaded with the modded, results are in the screenie. They give identical results for me :/
Old 02-27-2005, 12:24 PM   #9
krampak
krampak's Avatar
I gives me +0'2s difference every time in 512KB loop.
__________________
|| Core 2 Quad QX6850 ES @ 3.5Ghz 1.35V || Thermalright Ultra 120 || Asus P5K3 Deluxe || Gskill F3-12800CL7D-2GBHZ
|| XFX 8800GTX || Dell 2005FPW 20" || Ultra X-Pro 750W LE || 3 x WD 320GB SD + 1 x Hitachi 500GB
krampak is offline   Reply With Quote
Old 02-27-2005, 12:39 PM   #10
snq
Xtreme X.I.P.
snq's Avatar
Detonator, I took a look at the screenshot in the thread you posted (this one)
and I think the difference there was at most 0.3 secs. If you look at the results in the right the final time has to be a very high 35. So the results are not off that much. Also I seriously doubt that processtimer can give more accurate times than Super PI itself. I haven't tried it out tho but theoretically it's just impossible.
If you could test with this version. That's the old modded one, the actual time measuring hasn't been changed only displaying it has been changed in that one. And please compare it to both this new one and the results you get with processtimer. The results in that version *are* completely accurate with the original Super PI. The original Super PI records the time in msecs but just doesn't display them.
Let me know what you find out.. Preferably a screenie with the 3 of them run right after each other. Thanks This is impossible to test for me as I get the exact same results for every version.
Krampak: What are you comparing to?
Old 02-27-2005, 12:49 PM   #11
D_o_S
D_o_S's Avatar
I get varying results, for example on 64K I get a variation of about half a second.
And for 1M, I get a variation of about 1 sec.
__________________
"Strive for perfection in everything you do. Take the best that exists and make it better. When it does not exist, design it." - Sir Henry Royce
D_o_S is offline   Reply With Quote
Old 02-27-2005, 12:52 PM   #12
snq
Xtreme X.I.P.
snq's Avatar
Half a second on 64k? Uhh..
Could you check with this version and see what kind of results you get? I'm starting to doubt my timing code works flawlessly on all systems..
Old 02-27-2005, 12:57 PM   #13
HARDCORECLOCKER
Xtreme 3DTeam Member
HARDCORECLOCKER's Avatar
Excellent work - always got 25sec as best but now I now I'm very close to 24.........:
So if I'll get back my DFI NF4 some day from RMA we will see...........
__________________
Previous system:
DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
HARDCORECLOCKER is offline   Reply With Quote
Old 02-27-2005, 01:37 PM   #14
detonator
detonator's Avatar
this wath I have...
__________________
Old 02-27-2005, 01:57 PM   #15
snq
Xtreme X.I.P.
snq's Avatar
Hmm..
Is the 35 sec the result from this run or from a previous run?
I have to agree tho the timings seem to be off on your system, looking at your 16K score. My system (XP3200+) does 16K in 0.219s. But... As the time with the orignal mod is over 35 secs as well I think the problem is with your system, not with my code. The new one which has more code for timing is even faster on your sys than the one with original timing.
I really don't know what to do about it.. But the results in left top cannot possibly be wrong, unless they are wrong in the original super pi.
Old 02-27-2005, 02:40 PM   #16
detonator
detonator's Avatar
is not just me, if you cheak on the link I posted ,almoust all the pepes over there had the same problem, a different btwin 0.700/800 msm
those test were made on a 3200 prescot D0 on abit ic7max 1024 ram.did you try your super pi on an intell sistem?
__________________
Old 02-27-2005, 03:20 PM   #17
HARDCORECLOCKER
I love it - here comes the naked truth - no more cheating.....
__________________
Previous system:
Old 02-27-2005, 03:26 PM   #18
snq
Xtreme X.I.P.
snq's Avatar
I haven't tested with an Intel system no, I'll test it on my P4 2.8 but I doubt the results will make any difference.
It still is just as impossible to get wrong results. I've been thinking about it. The anti cheating code I added actually prevents wrong times from happening.
I've used babelfish now to translate the thread for me..
XstasY (you I assume?) wrote:
"on the classic superpii I make 35,890 controlato from process timer, on the new one I make 36,498.."
ProcessTimer is far less inaccurate than Super PI itself. It can in no way tell with the same amount of accuracy when the calculating process is started or stopped. Basically it lags. Of course it will lag both when starting and when stopping so you might think it'll equal out in the end. But when calculating is started, all cpu power goes to super pi so it will lag more. It will notice faster that the process was stopped, so it will give a better result than you have actually achieved.
Next, Robbi16v.
"Normal SuperPI: 53s
SuperPI mod: 53,860s"
That's a correct result.
Next, Mo3bius
From looking at the screenshot I'd say results are off by max 0.3 secs. But look at all the crap he has on his setup and what he's running (the toolbar for example)! I wouldn't expect any stable results from that setup, with or without mods.
Next, Jok3r88
super devout: 34 sec (whatever devout means
super devout mod: 34.857 sec
Results match.
The rest of the posts I cannot make any sense of because babelfish apparently isn't very good at Italian
But.. I suspect that if you'd run the modded program on a clean install and close anything that might affect the time (including explorer, mirc, etc) you will get roughly the same times.
I know for a fact that my code doesn't cause this so the problem must be somewhere else. I'm sorry, I dont wanna sound like an but there can't possibly be anything wrong with the code. My code is only used 20 times during one run. Even if it would be slow as hell, it would not give a raise of even 0.1 sec. The better results you or others may have had before were either caused by inaccuracy or plain luck.
Now I'm off to test with the P4, lets hope it wont make me eat my words
Old 02-27-2005, 04:01 PM   #19
detonator
detonator's Avatar
e second italian forum where few peeps got the same problem....
I hope you get a rid of it.
http://www.memoryextreme.it/viewtopic.php?t=1456
greating
__________________
Old 02-27-2005, 04:13 PM   #20
detonator
detonator's Avatar
btw those test made in the italian forums are made with the proces timer, they all say the same, a different of 0.800 like I told you before.
I want just to help you out ,becosue wuld be a must to have a spii with msm
and my own test are made on a clean istallation no twick at all, fresh Xp istallation.
__________________
Old 02-27-2005, 04:15 PM   #21
snq
Xtreme X.I.P.
snq's Avatar
I just finished testing on my P4 2.8. 512 MB PC333, pretty fresh XP SP2 install. It's a Dell
First I tested regular Super PI, result was 53 secs
Next I tested mine, result was 53.641 secs
It seemed the first test would've been a low 53 tho (some of the times in between were faster), so I tested again. This time I got the same second values for all of them as I got in mine.
I can't do anything about this. My version uses the exact same amount of memory as the original, uses the exact same code for calculating, the only difference is that when time is taken (20 times per run) it will cost a few more clockcycles. And believe me that will not cause a change of even 10 msecs over a whole run.
The error must be in italian PCs or software because I just cannot get it to make a difference here no matter how many times I try
Also please don't rely on ProcessTimer when comparing results. It might be good for seeing the differences between different memory timings and clock settings but it does not give an accurate time. Mine shows the actual time it took to calculate the digits, plus or minus around 15 msecs depending on your timer resolution (depends on OS).
Old 02-27-2005, 04:21 PM   #22
snq
Xtreme X.I.P.
snq's Avatar
I understand your frustration tho so I'll keep testing and thinking about it and hopefully I'll find an explanation for it. It's just too weird. I still believe its impossible that the little code I added could have anything to do with it.
Old 02-27-2005, 04:32 PM   #23
NiCKE^
NiCKE^'s Avatar
Send a message via ICQ to NiCKE^ Send a message via MSN to NiCKE^
Compare a modded super pi and a unmodded superpi times with process timer and see if modded super pi and process timer shows diffrently?
__________________
Intel FTW!
Beanna
NiCKE^ is offline   Reply With Quote
Old 02-27-2005, 04:35 PM   #24
snq
Xtreme X.I.P.
snq's Avatar
AHA!
I just figured something out.
To make a long and boring story short, the problem might be memory related. This is the only thing that has been changed for all of the code. It might be the case that on Intel systems this slows down everything a bit. Actually it MUST be that because if not then I really don't know
I'll try and whip up a new version tonight so we can see if it makes a difference.
Old 02-27-2005, 04:41 PM   #25
NiCKE^
NiCKE^'s Avatar
Sounds good to me
__________________
Intel FTW!
Beanna
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
