hi guys
here my new geil ultra-x pc3200 tccd
post your results
this is my standard settings
289*9 2.5-4-3-6 or 2.5-3-3-X 1T are rockstable memtest and prime
330*8 2.5-4-3-6 1T Dualchannel 1GB
hi guys
post your results
Signature
sweet, making a rig for my m8 and plan on getting 1x512 for him, now i know it will reach 300 as long as the cpu has a good mem controller. These seem pretty competitive with the gskill LE and LA, but no one speaks about the geil
MY GEIL ULTRA_X pc3200 2x256mb
is 320 Mhz 2.5-4-3-5 Run 3dmark loop
is 325 Mhz 2.5-4-3-5 Run Spi 1mb
Luigi
www.tecnocomputer.it
Engin , what voltage do you use for 289Mhz ?
Mine get real hot at 2,7+ volts, I think heat's causing errors there.
With a fan blowing over the sticks, I'm sure i can get higher
My 24/7 OC : 270 2,5-3-3-10 1T 2,65volt
(I need to do some more testing, also with a lower multi because the CPU is at it's limit)
I'm very happy with these sticks , they're only rated DDR400 but are running
DDR540 without changing voltage ! Also cheaper than GSkill over here !
i need for 289 2.5-4-3-X and good timings 3v, but its 100% stable.My cpu memcontroller are not so good, over 290 its instabil
Signature
|| Core 2 Quad QX6850 ES @ 3.5Ghz 1.35V || Thermalright Ultra 120 || Asus P5K3 Deluxe || Gskill F3-12800CL7D-2GBHZ
|| XFX 8800GTX || Dell 2005FPW 20" || Ultra X-Pro 750W LE || 3 x WD 320GB SD + 1 x Hitachi 500GB
Is yours GeiL Ultra-x ? if not why do you wirte here ?Originally Posted by krampak
Originally Posted by ENGiN
That second capture is of Aud1o at 330 stable, I with himself stable DDR640 with 3,0v.
You have timmings?
and voltages?
One thing to be aware of, Geil are using BH based UTT in their Ultra-X range now, so they're not TCCD anymore.
Is the 330 shot prime stable?
Main: i7 2700k @ 5.0Ghz, ASUS Maximus V Formula Z77
16GB Corsair Vengeance 1600, ASUS GeForce GTX680
2x240GB SanDisk Extreme RAID0, Seasonic Platinum 1000, Corsair H100
Server: i7 2700k, ASROCK Z68 Extreme7 Gen3
16GB Patriot 1600, 120GB SanDisk Extreme
5TB JBOD, Corsair 850TX, Corsair H100
Media: Phenom II X4 940BE, Biostar TA790GX XE
4GB Corsair XMS2 1066, VisionTek HD4850 512MB
60GB OCZ Agility 3, SilverStone ST400
Minstadave, i have the new ultra x, and its really crappy.
2-2-2-5-1T @ 2.85 volts wont even do 215 fsb.
Try slackening the timings to 2.5-3-3-7 if you can't get much higher then you've got BH5 modules, and will need alot more volts to get them to clock nicely.Originally Posted by meateater
Yeaah got same memory(BH-5) -the words of Geil engineer:"GEIL Ultra-X module used to equip with Samsung TCCD. It was able to overclock with low voltage. People love Samsung TCCD.
Unfortunately, Samsung has stopped making TCCD this February. Therefore, we switch IC from Samsung TCCD to Winbond BH-5.
Winbond BH5 needs higher voltage to raise it's clock speed or overclock; standard clock speed require 2.5 to 2.65v, OC to 260 or 270 require atleast 2.85+.
However, there are only few motherboards support 2.85v; most of them are 2.8v top. "
I have tested CAS 2.5 and result was bunch of errors on Memtest 86 at any speed-you can use CAS 1.5 or 2.0 only
Intel Core 2 Quad G0 L725020
cooled by D-Tek FuZion, MCP655, Dual Black Ice
DFI Lanparty P35 T2R
2Gb OCZ PC2 8500 SLI
BFG OC 7800 GTX 512 Mb
2x74Gb WD Raptors,2x 500Gb WD SATA2
Enermax EG701AX-VE(W)SFMA,600w
Nice BH-5 from GEIL "crappy"?....................
Maxime Voltage GO FSB at 2.2.2.5
I can do it, rock stable
I now take back the word crappy I mentioned before.Nice BH-5 from GEIL "crappy"?....................
I just got my ultra-d and now I love my geils!
I pumped 3.2v and I can reach 240fsb 2-2-2-5, gonna memtest this soon...
toliman, what cooling do you use for your proc? thanks
