Hehe... who else?
Hehe... who else?
Hey guys while we are on this topic I think you'd like to see this thread on Ocforums I made:
http://www.ocforums.com/showthread.p...43#post3476943
____Originally Posted by Sentential
Point is it ISNT bh5. Its a new version rather a pure unbinned and unmarked BH which everyone calls UTT. Sure it is *technically* BH5 in every way, but it is being made side by side Infineon products in the same fab. Twinmos has a healthy supply via Winbond so the odds of you getting UTT in a pack of premium Twinmos is really damn high. Id go for it :banana4:
NZXT Tempest | Corsair 1000W
Creative X-FI Titanium Fatal1ty Pro
Intel i7 2500K Corsair H100
PNY GTX 470 SLi (700 / 1400 / 1731 / 950mv)
Asus P8Z68-V Pro
Kingston HyperX PC3-10700 (4x4096MB)(9-9-9-28 @ 1600mhz @ 1.5v)
Heatware: 13-0-0
I'd also like to add that this "UTT" is apparentally being made from different wafers and are a differnt process size from any of the former winbond products. BH5 and all former Winbond tech is still extinct. This is something wholy new.
Also just for reference this stuff is *tehcnically* although not directally, manufactured by Infineon. <in the same plant>.
I also want to clarify that the pure infineon based BH isnt capable of decent timings/speeds at all. From what I heard 4-4-4 @ 200mhz is a best case scenerio. The same applies to the Mosel/ProMOS stuff. Neither ones take volts well and often die instantally when givein 3.2v+
The only stuff capable of doing 2-2-2 is the one using 100% winbond tech. These raw BH chips are available from people like Twinmos and possibly Adata.
However Twinmos has *the* highest concentrations due to the "stragetegic alliance"
Asus P8Z68-V Pro
Heatware: 13-0-0
Alonso,
Do you have any idea when the "distribution channels" will be getting this stuff into UK stores?
£58.73 - This is the amount of money a loyal customer is worth to Overclockers.co.uk
Beware of buying from overclockers.co.uk, they will swindle you by abusing the consumer law if they need to refund you for faulty hardware. Thieving gits
Sentential,
cheers for the update mate.
BUT, you keep saying UTT/BH... whereas from every other source I have read it seems UTT=CH die, not BH die.
VX/UTT Voltage Scaling, please contribute...
10x260 _ 1T-2-2-2-8-7-15 _ 3.3vDIMM _ 1.75vCORE
Mobile 3400+ CG 0437XDPW
DFI LanParty UT
XP120 w/ 120mm Thermaltake Thunderblade
2x512MB OCZ VX
BBATI 9800np w/Infineon
PC Power & Cooling 510w Deluxe
CH=0.13u
UTT=0.13u
UTT are blank CH dies.
Jus to clearify:
The "new BH" TwinMOS is getting will be on the BH die I think... according to Alonso.
I'm just saying previous ones seem to have been on CH die...
DFI LanParty UT
2x512MB OCZ VX
Well the point is that they are BH esk hence why I said that. Its just how you word it but the concept is still the same However they are NOT former winbond tech so technically they arent Ch5 either they are something completely different.Originally Posted by Rabbi_NZ
From my understanding of things this "UTT" is basically Infineon fabing using Winbond's specs hence why they are ty/need so much voltage
Asus P8Z68-V Pro
Heatware: 13-0-0
- Winbond BH5 = 0.175µm
- Winbond CH5 = 0.13µm
- Infineon/UTT BH5 = 0.15µm
- Infineon/UTT CH5 = 0.13µm
Are there any known differences other than size of the dies in these four chips?
You were not supposed to see this.
They use a differnt type of wafer and size. They use standard Infineon wafers afaik. However the dies are similar, probabaly not exactally the same. I'd have to ask specifically about that.Originally Posted by largon
Asus P8Z68-V Pro
Heatware: 13-0-0
Are you sure about this?Originally Posted by largon
If this is true these are exciting times... but I havent heard anything like this before.
What are your sources?
DFI LanParty UT
2x512MB OCZ VX
I cant say who my source is but I will say it is from a leading dram manufacturer. So I can confirm for 100% that the UTT is by proxy Infineon made. Its made in their fabs and that is enough to call it Infineon in my book.Originally Posted by Rabbi_NZ
The designs are still winbond but its being outsourced and then sold to Twinmos.
Asus P8Z68-V Pro
Heatware: 13-0-0
I thought old bh5 (winbond bh5) was 15nm?
E8400 @ 3600mhz
4870 @ 790/1100
2x2GB DDR2
Im not sure what process the UTT is made on...but cha know what. I can ask tonight This person isnt on atm but I will send an email.Originally Posted by kryptobs2000
Asus P8Z68-V Pro
Heatware: 13-0-0
I was refering to the fab process Sentential, can you confirm new and old BH5 use a different process?Originally Posted by Sentential
PS, a VW Beetle made in a Chev factory will still be a VW Beetle in my books... unless of course they change the makeup of the vehicle
DFI LanParty UT
2x512MB OCZ VX
Yes they do use a differnt process. I dont know which but I can confirm for 100% that both:Originally Posted by Rabbi_NZ
A) different die process
B) different size die
C) differnt size wafer its cut from
What's the closest thing that Infineon makes thats comparable to this?
If you wanna know right now look at Mosel, it uses UTT based chips that would be your best guess. However I will ask in an email because frankly I really didnt get into specifics however I will tonight, IF this person knows it.
Ill aslo see if I can get a product spec.
Asus P8Z68-V Pro
Heatware: 13-0-0
well in that case, any word on dh5?
E8400 @ 3600mhz
4870 @ 790/1100
2x2GB DDR2
Let us know broOriginally Posted by Sentential
DFI LanParty UT
2x512MB OCZ VX
Yea Ill do that. Ill see what kinda dirt I can dig up. However I wanna warn you, there may not be a product ID.Originally Posted by Rabbi_NZ
This person said that Infineon/Winbond sold the bare ICs and didnt even bother to bin them, or label just litererly blank ICs. Thus leaving/forcing OCZ and Twinmos to manually do so <and yes im serious> go thru and bin them themselves. Thus why they are so friggin expensive and so rare.
So its entirely possibel that it wont have a name <or at the least lacking an ns rating>
Asus P8Z68-V Pro
Heatware: 13-0-0
At least we'll know how to find the TwinMOS BH/UTT and CH/UTT... those AA4T and 1A4T codes are all we need
DFI LanParty UT
2x512MB OCZ VX
Just spoke with my "source" tonight This person was going to be talking to the Winbond techs anyway tonight and is gonna ask those questions along with providing serial IDs and tags :banana4:
Asus P8Z68-V Pro
Heatware: 13-0-0
Twinmos PC2700. These sticks are on the egg and they are labeled AA4T, they got the mtec chips... Hmm, wut IS twinmos up to?
EDIT: 37$ shipped, if truly BH5 or CH5, this is awesome and I'm pickin up 2 sticks for my 754 rig (vnf3-250 & 2800+) thats comin in a couple more days.
DO NOT GET THOSE!!!Originally Posted by stevemedes
Those are the UTTs I was warning about. Those are the pure Infineon UTTs, they are not Winbond's
Asus P8Z68-V Pro
Heatware: 13-0-0
Sent, can u point me in the right direction of which to get? I'm thinkin of goin with either the 256meg or 512meg sticks of twinmos SP... they seem to be out of stock though.
