Page 1 of 4 1234 LastLast
Results 1 to 25 of 81
Thread: All DFI NF4 users, please come in if you still have problem with 2.17 bios
    Banned
    Jan 2004
    Land of Buckeye
    As this effort is belong to OSkar,
    I just have this beta bios couple minutes ago. It's regarding some XS friends PM me about they still got some issues on the 2.17.
    As I mentioned yesterday, it could be different NVMM version package. So , here you go, this 2.18 beta bios is the old nvmm
    please understand that, I can not talk about the NVMM.
    If you get the bios, please DO compare and confirm the results in this thread, don't just take it for granted and nothing back. PLEASE.
    Here you go for DFI NF4 2.18 Beta bios.
    Memory Addict
    Aug 2002
    Brisbane, Australia
    what's NVMM ? i'm used 209 and 217 bios with no probs
    Banned
    Jan 2004
    Land of Buckeye
    Quote Originally Posted by eva2000
    can't talk about that..
    Glad to hear you don't have prob.
    Jan 2005
    Which of the bios' is the best/most optimal for TCCD? GSkill to be exact?.
    2/09, 2/17, 2/18?
    Antec SX 1045Bll
    OCZ 520 Adj. Powerstream PSU
    A64 4000+ San Diego @ 2.8Ghz
    XP-90 w/92mm Vantec Tornado
    DFI LanParty nF4 SLi-DR
    4x512 GSkill PC4400LE
    HTT255x11 3xHT DDR510 2.5-3-3-11 1:1
    NEC3500 16X DVD +/- RW
    BFG 7800GTX OC
    3DMark01
    My RIGS
    Dec 2004
    Netherlands
    Haven't got any problems with the 17/02 bios, but i will try this one out also, i want 10x270
    Result with the 17/02 bios see attachment. Was better than the 09/02 bios, timings are tighter on this one.
    edit: uploaded wrong image lol, was from my previous mb.
    DFI Lanparty NF4 Ultra-D | AMD 3500+ CBBHD 0450 TPAW .90nm @ 11x245 1.50v @ XP-120 + YSTech fan@7volt | 2x 512 OCZ VX 2-2-5-2 @ 3.1v
    Powercolor X800XL 440/540 VF700-CU cooled | 2x WD Raptor 36GB @ RAID 0 | 2x Maxtor 200GB 8MB @ IDE | SB Audigy 2 ZS | OCZ PowerStream 520W ADJ | CM Stacker!
    Xtreme 3DTeam Member
    Dec 2004
    UK
    has this sorted the issue with BP815 based memory?
    Opty 144 0546FPMW @ 2.8ghz
    MSI K8N Neo 2
    2 x 512mb OCZ Platinum Rev. 2 TCCD
    ATI X800 Pro @ 570/1200
    Plus some other metal fings...
    Will do me till Conroe
    Heat
    Dec 2003
    SONOFA!!!......I haven't had any problems with 10x or 11x 270, but....
    ...well, problem solved with 2/18. Need to do some longer term testing but this seems to have helped me out enormously with the problem I did have. Since board #1 died on me, board #2 was not making me a fan of these boards. Pass my thanks on to Oskar.
    edit to add: little more testing and there is no doubt this helped me out.
    .........current project, make the 135i faster
    Jun 2004
    Brighton, UK
    Quote Originally Posted by Lidocaine
    2/09, 2/17, 2/18?
    Yes I'd like to know that too
    EVGA Classified, i920 @ 4200 24/7, 3 x 2GB XMS CAS7, ATI 5870 FC EK W/C , Bequiet 850W PSU, XFi Music, Vista 64 Bit, peltier-chilled water-cooling
    Feb 2005
    In the arms of an angel
    I've had a terrible experience with 217, after restart I couldn't load windows anymore with my SATA Raptor 74GB drive, said ntfs.sys had an error and I got the dreaded BSOD!!! Had to LLF the drive and then reinstall everything... Lost all my data on the disk. I also reverted to my old BIOS but to no avail, the harm was already done. Now, I don't think I'm in the mood to try 218...
    Just my
    Athlon64 X2 4400+ (Toledo) @ 2.8GHz (10x280)
    DFI LanParty NF4 Ultra-D
    2GB Mushkin XP4000 3-4-4-8 280@2.8V
    nVidia 7800GTX (Leadtek) 505/1.33
    OCZ 600W PowerStream PSU
    Dell 2405FPW
    Jan 2005
    AMD factory
    Quote Originally Posted by mikead_99
    SONOFA!!!...... I haven't had any problems with 10x or 11x 270, but....
    What? 2/18 solved the problem You never had ???
    This is a bit too high for me...........
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
    Jan 2005
    AMD factory
    Quote Originally Posted by Onepagebook
    O.K. - first thanks for the work, but this is the 4th BIOS since beginning of February and makes me wonder which one to use?
    So if You cannot talk about NVMM please give us an information when it is better to use 2/18 with the old NVMM or the 2/17 with the new one.
    I mean You don't have to post secrets here but try to explain it in Your own words so that You don't get a problem with somebody..........
    Previous system:
    Mar 2003
    i cant get over 210 with out memtest or prime95 crashing the computer. ive tried everything, except moving the jumper to the 5v rail.
    3000winnie
    ocz 3200 plat rev2
    promie
    i have to pump 3.0v into the memory just to boot or else i get beeps and a flashing power light. and what makes it bad i was able to get 240hht on a8n-sli prime and 3d stable with just 2.9v. can someone let me into the big secret here. well off the flash the bios again. wish me luck
    3200vennie@3000ghz(1.58v)
    DFI NF-4 SLI-D
    1gbOCZ PC-4800
    xfx 6600GTx2 SLI (540/1170)wawa cooled
    2x 74gig Raptors Raid0
    Dec 2004
    The Holy Land
    my system work hest great with the 217 bios, to be honest its work fine wite the official bios
    and all of the beta bios, but i will try the 218 anyway
    thanks opb
    Asus P5-E X38 Intel QX9650 INOO3D 9800 Gx2 4x Super Talent's T800UX2GC4
    Creative X-Fi Raid 0 Raptors 36Gb data 1Tb Seasonic M12 700w
    Dell 2407WFP Lian-Li Pc-65 mod Custom Built Phase Change Unit |Logitech G25|
    RIG#2: DFI LANPARTY LT X48-T2R|Q9550| INOO3D 9800GTX|
    2xCellshok 1000| PC Power and cooling 750w Thermaltake v1
    Wife: DFI LANPARTY UT P35-T2R|Q930|BFG 8800GTS 512MB|
    Samsung ddrII 667| PC Power and cooling 610eps12v Thermaltake v1
    Htpc:Dfi Sli-Dr Venus|3700+|2x1gb Team Group ddr500|Thermaltake Mozart TX
    Nov 2004
    Il
    the official 125 bios was horrible for me, wouldn't allow me to change vdimm. 209 was good, and 217 was better, so if this one uses old nvmm, i don't think i'll switch, becuase 217 has been working better than 209.
    Biostar A780 mATX
    AMD Phenom II x2 (Unlocked to x4) Stock Clock/Heatsink
    ATI X850XTPE Stock
    OCZ 2x2GB DDR2-800
    Seagate 320GB 16MB Cache Sata 3.0
    heatware: skip86
    Dec 2003
    Quote Originally Posted by HARDCORECLOCKER
    I guess I can be a little more clear. My 12x multi was utter crap, 13x not so good either. Much better now with the old nvmm. I'm guessing other peeps with multi issues should get some help out of this release. Doesn't seem like everyone has the multi issue either, and some that do have issues with other multi's. I honestly thought until today that my board was crap.
    Nov 2003
    NVMM=NV memory management or what?
    I have to compare the bins one of this days :P
    I like the often BIOS updates, good work, but I can't test it yet
    Aug 2002
    London,Uk
    ok, using the beta bios on dfi's site for now, only got board installed today but had it for a week now. its an a01 i think, had the 1/25 bios on it. so far on both the bios's i literally can't overclock at all, even slightly, will bsod in windows. 600W ocz psu, 2x 6800gt's, turned off the nx bit protection which seemed to stop bluescreening at stock which was infrequent, but overclocking it didn't help. 3500+ winchester, 2x200gb dm10+'s in raid on the nvidia controller with 2 more maxtor drives on the nvidia controller not in raid.
    this same setup(diff psu though, 520W ocz) would run 2.6Ghz stable at 245ish Mhz 1:1 so i assume the memory(couldn't test anyhigher fsb) gskill LA kit is fine for at least that, and cpu can clearly do 2.6Ghz, was fully 100% stable and would do much more not stable on 1.5v.
    am i missing some major setting on this dfi board, i normally laugh at people with threads with really obvious stuff but, pci-e is locked, on both other nf4 boards 101Mhz didn't auto lock it or anything so kinda assuming we don't need it here either.
    also where can i get teh 2/09 2/17 bios's if they aren't on dfi site?
    also i think i used raid drivers i got with the asus sli board as my dfi floppy just didn't see any drivers on it while installing windows, assume they are the same though, and using 6.39 nforce drivers, 71.81's for gfx, any known issues with any of that lot?
    Mail Me | 3500+ , dfi sli-dr, g-skill la, 2x6800gt, 600w pcz, stacker case, air cooled
  18. #18
    Dec 2003
    Quote Originally Posted by drunkenmaster
    You've got mail (bioses).
    edit: no you don't. the email in your sig bounced.
    re: the tccd...have you used 3.0V+ on them yet? I haven't tried my tccd out on this board, but that seems to be the deal with them.
  19. #19
    Jan 2005
    No problem for 217. Will try 218. Here is the result using BIOS 217
    PS: All stock air cooling.
  20. #20
    Aug 2002
    London,Uk
    mikead_99 , cheers for trying, haven't updated sig in a good year, or two probably :p changed it , got hte 2/09 and 2/18 now, too tired to look for the 2/17 right now.
    just very weird, normally i can always max out my stuff, never ever not been able to overclock and this literally won't go 5Mhz fsb faster when i know all this stuff did 245Mhz minimum fine before. who knows
  21. #21
    Banned
    Jan 2004
    Land of Buckeye
    218 contains old nvmm and nv raid rom
    for me 218 is a bit better than 217.
    That's all I can say
    ** By teh way, I am using wd740gd in Raid 0 mode.
    I try several bios without any prob.
  22. #22
    Nov 2004
    Il
    i'd rather you not say anything more and break your trust with oskar, its really great for everybody here that your business relationship is as good as it is with him, all these beta bioses are great!
    Biostar A780 mATX
    ATI X850XTPE Stock
    OCZ 2x2GB DDR2-800
    heatware: skip86
  23. #23
    Jan 2005
    KAPVT MVNDI Rome, Italy
    i have not tried the 217 but with this bios gave me 30" on 1mb pì finally I can say I'm happy with my 3000 winchester with vitesta's 566
    cheers bud
  24. #24
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by enduracell
    maybe Nvidia Video Multi Media or Memory Management
    C:\Program Files\NVIDIA Corporation\ForceWare\Multimedia\NvMM.exe
  25. #25
    Banned
    Jan 2004
    Land of Buckeye
    ..you 're not eva2000, you're evil2000
    but that still under bios..
