Page 1 of 2 12 LastLast
Results 1 to 25 of 44
Thread: Got 0451EPAW from newegg today
    Jan 2005
    Just thought I'd let you know what the 'egg was flinging right now. Got this today, ordered it Monday (with my G.Skill LE).
    I'll have it tested in a day or two and get back with the results.
    Winnie 3000@2.63 (293x9) | 1GB G.Skill LE 2.5-4-3-8 1:1 | DFI Ultra-D | Chaintech 6600GT@622/1170 | Antec NeoPower480 | XP-120 | Zalman VF700-ALCU
    "That's a hot CPU"
    Jun 2003
    Cool, i've been thinking about picking up a spare. Good luck with it. :thumbsup:
    Feb 2005
    Orlando, Florida USA
    Please post results I am in the market for a new CPU and I want to see how the current stock from the EGG does in OCs
    A64 3700+ | DFI NF4 | 3gb Mushkin | 2x250 Seagate Barracuda 7200.8 | MSI NX6800GT -> Mitsubishi DiamondPro 930sb | On board sound -> Logitech z5500 | Antec P180 | Air cooling by Zalman: CNPS7700-CU, VF700-CU
    Powerbook G4 | 1.5ghz | 512mb | Radeon 9700 -> 15"
    Back @ XS after a long hiatus
    Please excuse my noobness as the industry has changed a lot since I left
    Apr 2004
    In a van down by the river
    i have a week 51 that maxes at 2500
    Nov 2004
    Ieper - Belgium
    mine maxes out at 2700, I'd love to try it with tccd though.
    DFI nF4 sli-dr - 2*512 mushkin hi perf lvl2 - winchester 3500 - ocz powerstream 520 - xfx 6800gt - watercooling
    Jun 2003
    Quote Originally Posted by Dentnvr6
    How high are you able to get your mushkin? I've been able to get my Lv2 to 270htt/2.2.2.5 with 3.3v, But they're 2x256, Just wondering.
    Jan 2005
    Build Progress Report
    I got the cpu installed, the AS5 applied and the XP-120 on:
    Then wrestled the mobo into the case
    And got it cabled up. I also put one of the GSkill LE chips into slot 2.
    And the moment of truth - It fired right up!!
    Yeah, I forgot the check the jumper on the DVD. I probably should get that over to Master. Quick check of the temps looks good:
    Fan2 is the neopower's auto-variable fan, that's why it's so slow at the moment, there's no load. Now to flash the bios and add the 2nd ram chip, then we'll see how she overclocks.
    "That's a hot CPU"
    Nov 2002
    Hawaii
    That's a lot of AS5 you put on there. You really don't need that much, just a very thin layer.
    Dell 2405FPW
    Lian Li PC-75B
    PCP&C 510 ASL
    DFI LP UT NF4 SLI-DR Expert
    Opteron 180
    Chilly1 SS Phase Change
    2x512MB Mushkin Redline XP4000
    BFG 7800 GTX 256MB PCI-E
    2xWD 740GD RAID 0
    Maxtor 6B300S0
    Plextor PX-716SA
    Audigy 2 ZS
    Klipsch Promedia Ultra 5.1
    Nov 2002
    We're glad you can put together a computer.... now overclock it! Wake me up then.
    Xtreme Infrastructure Eng
    Feb 2004
    Quote Originally Posted by B5I8
    Actually you don't even need a layer. AS5 is different from other versions of arctic silver in that its not meant to be spread over the cpu by the user. If you place the pastic tip/applicator of the AS5 tube directly on the center of the heatspreader while you push the plunger, the compound is transferred onto the heatspreader into a nice "grain of rice." The compound is then evenly transferred over the heatspreader by the weight and pressure of the heatsink.
    Less is more.
    Dec 2004
    Overland Park, KS
    That's right, just a small grain of rice, if that i think. I think they even said half a grain, but i think that might have been for cpu's for IHS, but don't hold me to it.
    Intel Core i7 920 #3841A437 @ 3.8ghz 1.26v HT off
    Thermalright True-120 Extreme
    Gigabyte ex58-UD3R @ 190x20
    6gb (3x2gb) G.Skill Pi @ 1520mhz 7-7-7-21-1T
    PNY 8800gtx @ 640/1000
    abs (tagan) 700w
    Antec Nine Hundred
    Seagate 320gb
    LG 25.5" LCD
    Logitech G11 + mx518, Logitech x530 5.1 + plantronics DSP500
    I am Xtreme
    Dec 2002
    ive always spread it, do you benifit from the grain?
    Nov 2004
    Il
    i try and put the smallest amount i possibly can, even a grain of rice will spread out more than the size of the core once it squeezed by the HS.
    Biostar A780 mATX
    AMD Phenom II x2 (Unlocked to x4) Stock Clock/Heatsink
    ATI X850XTPE Stock
    OCZ 2x2GB DDR2-800
    Seagate 320GB 16MB Cache Sata 3.0
    heatware: skip86
    I am Xtreme
    Dec 2002
    i just dont see how complete contact could be worse then a circle in the middle of your heatspreader
    Dec 2004
    Atlanta
    I'll be getting a 3000+ tomorrow from newegg shipped from the NJ warehouse. I'll report back with steppings and OC results.
    BTW did your CPU ship from the CA or NJ warehouse and was it oem or retail?
    Jan 2005
    This came from CA, and it was an OEM.
    I've got it memtest stable now at 2.7Ghz, but with high voltages. 1.62v on the core and 2.9v for DRAM. My temps are still sub 30 at that, but that's with memtest and it seems that's far from a reliable test. It was doing 2.6Ghz on 1.45 and 2.8v DRAM with loose timings no prob.
    I'm installing windows now, and we'll see what happens in real life.
    "That's a hot CPU"
    Dec 2004
    Overland Park, KS
    Nice clocks. Are you able to run 1:1? 2.7ghz is like, what, 300FSB?
    abs (tagan) 700w
    Antec Nine Hundred
    Seagate 320gb
    LG 25.5" LCD
  18. #18
    Jan 2005
    yeah, that's 1:1, 9x300.
    But let's see what happens with testing under windows. I've gotten excited about speeds that'll post but are hairball under windows and benchmarks.
    But it does seem to bode well, I'm thinking 2.6Ghz could be a reality for 24/7.
    "That's a hot CPU"
  19. #19
    Jan 2005
    I'm getting 2.6, 9x287, Prime stable, at 1.6v.
    It was pretty easy, I'm going to keep tweeking and start working on RAM speed.
    "That's a hot CPU"
  20. #20
    Banned
    Nov 2004
    that is a lot of AS5 i only use about half a BB size on a P4 and a little bigger then that on my a64 as the heat sink dosnt apply as much preasure to the cpu.
  21. #21
    Jan 2005
    Good tip - I won't make it look like a cake next time!
    "That's a hot CPU"
  22. #22
    Jan 2005
    Ended up with a stable 2.63Ghz
    293x9@1.63v, can do SuperPi 4M, and my 1GB of LE is at 2.5-4-3-7. Idle load 20-21 degrees, max load 38 degrees
    hit 10k in 3dMark03 with my crappy $155 refurb Chaintech 6600GT, although the GT needed a Zalman VF700 and a whole lot of pencil to get to 643/1200. GPU idle temp at 30, max load 58.
    My first OC'ed system, and I'm pretty happy. Thanks Xtreme Systems!
    "That's a hot CPU"
  23. #23
    Dec 2004
    Seattle
    For spreading thermal paste a razor blade works quite well. I've also heard of people using old credit card's to spread it.
  24. #24
    Jun 2003
    Quote Originally Posted by Cpt Twitchy
    Me like's razors.
    Quote Originally Posted by Flask28
    We've hooked another.
  25. #25
    Feb 2005
    Seoul/Singapore
    You're lucky that your CBBID 0451 can reach that speed, my pathetic CBBID 0451EPCW can't even go beyond 2.3ghz? I'm now stucked at 255HTT X 9. I've pumped all the possible voltage like vdimm, vcore, ldt voltage. I've tried putting 255HTT via clockgen and my windows filesystem just corrupted. I've tried 10x, it will not boot into windows, just curious, a super messy HDD with a OS ported from a barton system, will it affect the ocing due the messiness in the hdd itself? My vdimm is at 2.8v btw. I've already pissed off by it as i need to rebuild my windows filesystem painfully. I just hope this cpu can go till 2.5ghz and i will be very happy.
