Results 1 to 19 of 19
Thread: DFI 250gb please help... bios problems?
    Nov 2004
    uNd3rgr0uNd
    first off specs in sig!
    ok i just got a new set of VX and i am trying to get this ram started...
    well i am doing fine all the way up to 250 @ 3.2vdimm 2-2-2-5..
    then i go for 3.3vdimm and i reboot the friggen thing clears cmos.. wtf
    it happens everytime no matter what. what is this thing doing? i cant figure it out. so now when i set the bios to 3.3vdimm it clears cmos and tells me some bios error.. so i reflashed like 2 seperate times and loaded optimized values.. still no worky
    also i have the LDT set to 3x and the chipset at stock voltage if thAT matters.. tried to up the chipset voltage and it still doesnt work
    OCZ Product Specialist
    Mar 2004
    Might be time for an RMA on the board. I never had any issues like that with mine.
    OCZ Marketing Team
    Email Me Here or Need Technical Support? Go to OCZ Support Forums
    Jan 2005
    Try ltd 2.5.
    U.N.D.E.R. C.O.N.S.T.R.U.C.T.I.O.N.
    Oct 2004
    Sthlm, Sweden
    I also have a problem when going above 3.2V, but my bios gets corrupted and I have to load optimized defaults... very annoying as my bh-5 clearly need more
    /A
    E6400@310x8|Asrock 775 Dual-VSTA|X800XT|2GB A-data
    Aug 2003
    Belgique, Belga, Belgio, Belgium, Belgica, Belgie, Belgien
    Mine does 3.6V 24/7. Never had a problem with my bios.
    Is your 3.3V line up to it?
    .:C2D 6600 :: Tuniq tower :: Asus P5B dlx :: 2GBHZ :: OCZ 520W :: 8800GTX :.
    Oct 2004
    Sthlm, Sweden
    Yes indeed it is - can get up to 3.7 out of it!
    /A
    Banned
    Dec 2004
    Never heard of this before. You using 10/15 BIOS? Id reflash again.
    Oct 2004
    Sthlm, Sweden
    yes 10/15 and I have reflashed many times - did it twise b4 last try... did not work
    /A
    Oct 2003
    Alpine, TX, USA
    You are running .1-.2v higher on your 3.3v PSU rail than you are running vdimm in BIOS, right?
    E.g. if you want 3.3v vdimm, then PSU 3.3v line needs to be at 3.45-3.5v. Otherwise all the extra BIOS vdimm options are useless unless the PSU rail is cranked up.
    Redline 3D Socket 754 = 40,179
    Retired
    Oct 2004
    Sthlm, Sweden
    yes ofcourse I am
    it's something fishy bout my mobo (which works the treat except for the Vdimm
    /A
    Oct 2003
    Alpine, TX, USA
    Quote Originally Posted by amv1981
    yes ofcourse I am
    /A
    I meant original poster Figured you already had PSU rail up higher.
    How about you aCidbAbY?
    Retired
    Nov 2004
    uNd3rgr0uNd
    yes mine is up and i got the error>>> bios checksom error...wtf
    it has nothing to do with me upping my rail this i already know...
    Mar 2003
    U.K.
    I have that problem with mine above 3.2V, the way I get round it is to set it to 2.8v reboot enter Bios save and exit, go into Bios again then try 3.3v save and exit and keep saving and exiting till it stick's, if it go's back to 2.5v you have to start again, but it can take 4 or 5 attempts to get it to 3.3v or above
    I am Xtreme
    Feb 2003
    Netherlands
    Make sure Vcore isn't set to auto, Vcore at auto will cause trouble with Vdimm over 3.2V
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Nov 2004
    uNd3rgr0uNd
    not sure how i did it but problem fixed
    Mar 2004
    COOL! Now on to the VX!
    OCZ Marketing Team
    Nov 2004
    uNd3rgr0uNd
    hehe yeah im at 260 with 3.45vdimm this time, waay better when compared to 3.6..
    andy thx for your help bro. i will be takeing my time and we will see how these do hopeing for 265 to match my cpu
  18. #18
    Xtreme X.I.P.
    Nov 2002
    Shipai
    im having a very similar problem. whenever i plug my bh5 or ocz eb into the dfi 754 ut and try to save something to the bios the bios is gone and the board just hangs. i can boot into windows and its stablem but as soon as i enter the bios and want to save changes or leave the bios even without having changed anything it gets stuck. i get a black screen and nothing happens... when i reset the bios it boots up again... i tried many bios files and flashed several times...
    please try to find out how you got rid of this problem acidbaby
    ah well, this board has huge vref fluctuations anyways, so i think i will just rma it :/
  19. #19
    Nov 2004
    uNd3rgr0uNd
    well one thing i did do was change the battery maybe try it.. also overnight i left it out.. maybe try this it worked for me....
