Do I have to plug in a 4-pin molex from the PSU to the mobo itself?
The molex that is circled is the one in question.........do I have to plug a line from the PSU to this? The manual doesn't specify and I just try to power on and NOTHING.
That is for more stability with SLI enabled. You don't need to unless you are running SLI.
any updates also post your specs, do are you using your ocz 520 like in your sig?
I've tried powering up and nothing! All jumpers appear to be correct.....what could be wrong? DOA?
Disconnect everything and connect them back again. Oh an another thing, RTFM, it always has a couple of things to knowOriginally Posted by Lidocaine
Athlon64 X2 4400+ (Toledo) @ 2.8GHz (10x280)
DFI LanParty NF4 Ultra-D
2GB Mushkin XP4000 3-4-4-8 280@2.8V
nVidia 7800GTX (Leadtek) 505/1.33
OCZ 600W PowerStream PSU
Dell 2405FPW
http://www.xtremesystems.org/forums/...ad.php?t=52258Originally Posted by Lidocaine
How did I know you were gonna say that?.....LOL.......I wish the manual woulda told me that my new OCZ 520 Powerstream Adjustable was gonna die...............another one bites the dust. Antec filling in until I get an RMA.Originally Posted by Anakin_Skywalke
Thanx Blindbat for the linkage.............I've had my face buried in this case for 16hrs, but will follow.![]()
There sure are a lot of the OCZ PSU's going tits up since they came out. Sorry to hear that and good luck with the rest of the build.
Maximus Formula||E8400 9x445 1.42v||2x2GB GSkill PC8000||150GB Raptor||ATI 3870 840/1200||Vista64
DFI NF4 Ultra-D modded to SLI-D||Opteron 165||4x512MB Patriot XBL 2.7v||X850XT 575/594||37GB Raptor||Seagate 120gb||Audigy 2 ZS||XP Pro
Actually I have had the same problem.Originally Posted by Lidocaine
I got my SLI-D yesterday, hooked everything up and turned it on. Nothing happened. Double checked all cables and jumpers but everything was OK.
Tried booting it several times but no succes.
Built the system outside the case on a box but the same thing, offcorse I tried booting with other memory, PCI videocard no harddrives connected etc but it just wouldn't work
Went downstairs to search for a solution, came back and it smelled like something was burning in there. I come in to my room and see the leds of my 120mm fan burning, but no fans spinning etc, what the... the system powered itself up?
Because of that my PSU has died
I hope the other hardware is undamaged, can't test it all, and hoping i'll get a new PSU. Already got conformation i will recieve a new board.
Got an x850xt pe and 2x 512ocz vx laying around now doing nothing
Or does your system work now with the antec psu?
DFI Lanparty NF4 Ultra-D | AMD 3500+ CBBHD 0450 TPAW .90nm @ 11x245 1.50v @ XP-120 + YSTech fan@7volt | 2x 512 OCZ VX 2-2-5-2 @ 3.1v
Powercolor X800XL 440/540 VF700-CU cooled | 2x WD Raptor 36GB @ RAID 0 | 2x Maxtor 200GB 8MB @ IDE | SB Audigy 2 ZS | OCZ PowerStream 520W ADJ | CM Stacker!
man all these stories are getting scary. Perhaps I will hold off getting one of these for now.
Silverstone Temjin TJ-09BW w/ Silverstone DA750
Asus P8P67
2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
8GB G.Skill DDR-1600 7-8-7-24
Gigabyte GTX 460 1G
Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
1 X 120GB OCZ Vertex
1 X 300GB WD Velociraptor HLFS
1 X Hitachi 7K1000 1TB
Pioneer DVR-216L DVD-RW
Windows 7 Ultimate 64
Boot up with a single stick of mem in slot2.
take it from there
Similar situation here. I took out my MSI K8N Neo4 mobo, rebuilt, and never saw power after that...........3 months old andOriginally Posted by vrtn
This ANTEC SL-450 is waaaaaaayyyy undervolting..............I'm lucky to just be up at default.It's only a 20-pin psu........dropped it down 2 slots on the 24-pin connector and fired it up.
I'm sopissed right now it aint funny. Waited ALL this time for this board to be "gimped" by a DEAD hella expensive PSU
The board is sweet though.............pics:
Sideshot of XP-90 on the board:
In the case:
Chipset "stuff".......the "paste" is hard as cement.![]()
.......got a nice thin layer of AS5 now. :thumbsup:
Back of the Ultra-D
Last........the 6800GT OC DOES HIT THE CHIPSET FAN....but it will install.
...........again......there is ZERO clearance between the chipset fan shroud and the 6800GT.
so your ocz powerstrteam 520 died with your board? eeks im getting this psu and board. but samething happened with my friends msineo2plat. did your psu work prior to this? just curiuos and if any one has any reasons why it did this?
thanks a lot.
I've had this OCZ on 3 Neo2's, 1 Neo4..........the PSU was working when I took the Neo4 out of the case to put the DFI in. The spare ANTEC I had pulled me through though, because I thought when I heard the "POP!" that my CPU had gone up in smoke................to heck with the cpu thinking about it..........my $500 video card coulda went up in smoke.Originally Posted by synergy321
The board is nice other than the fact that the 6800GT sits on top of the chipset fan shroud with no clearance at all. The bios is loaded with stuff.
Quality components on this board.
That thick pad on the chipset HSF is a fairly good TIM normaly, it's phasechange so don't know if the chipset would get hot enough to make it work properly.
