can someone clarify this ? "Higher multi == higher mem bandwith" ??? (A64)
http://www.insanetek.com/index.php?page=overclocka64
This means that there [for the older XP CPUs] was no difference in memory bandwidth when running 11x200FSB or 10x200FSB.
The CPU horsepower was different, but the memory bandwidth stayed the same. This is no longer the case with Athlon64 CPUs. Multipliers affect the memory bandwidth significantly, which means that a higher multiplier results in higher bandwidth.
I need to have clarification....this guy does some benches, eg. he has (WInnie 3000) at 9x200 and then at 8x200....and since the 8x200 is SLOWER (DUH, DUH !!!!) he states "a higher multi also equals higher memory bandwidth".
Theoretical scenario:
winchester running at
200 HTT X 10, and then (for comparison)
400 HT x 5 (ASSUMING i could hit 400FSB/HTT). The last one has the "lower" multi).
Now i just heard (somewhere) Oscar Wu quoted, he made a comment about how a really low multi (eg. 5x) would run the memory "slower than you might think"
So...what is it about "a higher multi is better than a lower multi" ? Eg. lets say i find my CPU hits a max of 2700...eg. i could do 9x300 or 10x270...what would REALLY be better ?
(BTW,. i always thought that the multi itself is not important AS LONG as i am able to hit the CPU's limit as well as the memory limit ! But now it looks like that setting down the multi is something you better avoid ?)
thanks
- You may not post replies
- You may not edit your posts
Forum Rules
