Page 1 of 2 12 LastLast
Results 1 to 25 of 44
Thread: Abit Launch AN8 Fatal1ty
    Fused
    Dec 2003
    Malaysia
    Lightbulb Abit Launch AN8 Fatal1ty
    January 31, 2005 – Since the release of the Intel-based Fatal1ty AA8XE motherboard, ABIT's Fatal1ty Hardware Series has been taking the PC hardware scene by storm. Anandtech named the Fatal1ty AA8XE "the Fastest Intel Gaming Platform", and HardOCP said that the board was "bullet proof". Today, ABIT is proud to introduce the first AMD-based motherboard in the Fatal1ty Hardware Series – the Fatal1ty AN8.
    By harnessing the power of the NVIDIA nForce 4 Ultra chipset with AMD Athlon 64/64FX support and combining it with exclusive ABIT Engineered features, the Fatal1ty AN8 delivers extreme stability and performance for the discerning AMD gamer.
    The nForce4 Ultra-based
    Fatal1ty AN8
    ABIT Engineered for Extreme Gaming Performance
    Engineered by ABIT. Game-tested and approved by Fatal1ty. The Fatal1ty Hardware Series represents the culmination of ABIT Engineering with the gaming prowess and experience of the world's number one professional gamer, Johnathan "Fatal1ty" Wendel. The result of this collaboration is a gaming platform with no equal, specifically engineered for the gamer that demands nothing less than the very best.
    At the core of the Fatal1ty AN8 is the NVIDIA® nForce4 Ultra chipset, which supports the latest and greatest 939-pin AMD Athlon 64/64FX CPUs. NVIDIA's nForce4 Ultra offers gamers a bevy of advanced features that will help turn up their game. By integrating Ethernet capabilities onto the chipset, NVIDIA Gigabit Ethernet provides the highest network throughput with the lowest CPU utilization. Integrated NVIDIA SATA RAID delivers RAID 0, 1, 0+1, and JBOD for excellent storage flexibility, and a 3GBb/s transfer rate doubles bus bandwidth and provides blazingly high disk performance. NVIDIA Firewall protects your PC from intruders by filtering unauthorized traffic with instant-on capabilities. With the NVIDIA nForce4 Ultra chipset as a base, the Fatal1ty AN8 gives gamers both performance and peace of mind.
    The Fatal1ty AN8 also comes with ABIT's exclusive µGuru™ technology, which integrates OC Guru™ overclocking, ABIT EQ™ hardware monitoring, FlashMenu™ 1-click BIOS updating, and BlackBox™ diagnostic technology into a user friendly Windows-based interface. With OC Guru, users can tune front side bus speeds and CPU voltages on-the-fly through Windows. ABIT EQ lets users monitor fan speeds, system voltages and temperatures at-a-glance, and FlashMenu™ 1-click BIOS update makes it easy to keep the system running in absolute peak condition. If a problem arises, BlackBox™ automatically detects your hardware configuration, and allows it to be sent to ABIT tech support for fast, friendly e-service. With µGuru, gamers have the most comprehensive suite of system utilities ever to power a desktop motherboard. Audio performance is also top-notch with 7.1 channel high-definition audio backed by ABIT's AudioMAX technology. By using a separate daughter card for audio connectors, ABIT Engineers have greatly reduced the amount of noise caused by high frequencies generated from the motherboard.
    Signature to the Fatal1ty Hardware Series is ABIT's Dual OTES™ cooling technology. Originally found on the Intel-based Fatal1ty AA8XE, Dual OTES delivers twin fans and a heat duct that efficiently channels heat from the inside to the outside of the case. With OTES RAMFlow™, DDR memory is kept cool via two high-speed fans for unsurpassed system stability. The Fatal1ty AN8 also features an all-copper chipset cooler, which draws heat three times more efficiently than conventional aluminum coolers. For the optimal balance of thermal and acoustic performance, all fans are automatically controlled via µGuru. With these exclusive ABIT technologies, the Fatal1ty AN8 delivers impressive thermal performance for the serious gamer right out of the box.
    Case modders will love the Fatal1ty AN8. The Fatal1ty AN8 features distinctive styling with a striking red and black color theme which will turn heads in a modded case. And when the lights are dim, the Fatal1ty AN8 stands out from the crowd with red LED backlights that outline the motherboard in a crimson glow.
    With ABIT Engineering and the gaming insight of Fatal1ty, the Fatal1ty AN8 motherboard delivers the speed and stability that gamers like Fatal1ty demand on the professional gaming circuit.
    Built with Bulletproof Technology
    Like all ABIT products, the Fatal1ty AN8 is built with Bulletproof Technology – a new standard in terms of Quality, Reliability, Stability, and Engineering. Bulletproof Technology begins with selecting the highest quality components available. ABIT uses only Japanese-made capacitors on ABIT branded motherboards and graphics cards – capacitors that cost several times more than regular capacitors. While others try to cut components, ABIT puts quality first. Bulletproof Technology also means stability, and the Fatal1ty AN8 has passed the Torture Test, a series of looping demos and benchmarks designed to tax the hardware far beyond normal use. Add to all of this exclusive ABIT Engineered features, and the Fatal1ty AN8 raises the bar by which motherboards are judged.
    They launch it earlier than expected...
    now when will they hit the market?
    Original news taken from here:
    http://www2.abit.com.tw/page/en/news...CNO=en_0501311
    Nov 2004
    Il
    should i wait for people to get their hands on this board and see how it is, or should i just jump on the DFI bandwagon. hmm.....
    i do like abit, but i'm not sure if it will be worth the wait.
    Biostar A780 mATX
    AMD Phenom II x2 (Unlocked to x4) Stock Clock/Heatsink
    ATI X850XTPE Stock
    OCZ 2x2GB DDR2-800
    Seagate 320GB 16MB Cache Sata 3.0
    heatware: skip86
    Nov 2004
    Ontario, Canada
    another price rip off O guess?
    Winchester 3500+ 0437
    Thermalright XP90+TT Silentcat 90mm
    2x 512M OCZ 3200 Gold VX 266 2-2-2-5 1T 3.9V
    Neo2 Plat ~1.3b6
    eVGA 6800U ~445/1150
    OCZ PowerStream 600W
    Lian-Li V2000b slightly modded
    May 2004
    Nazareth, Israel.
    i wonder how much will this 's experience contribute to OCing!
    Xtreme Mentor
    Nov 2003
    New-Brunswick, Canada
    I will get my hands one.
    Jan 2004
    Abit boards, as of recent, are all fatalities of high ambition, high price, and average performance.
    There is no way I'd buy this one, just like everybody I am waiting for the DFI launch.
    Nov 2004
    Il
    the aa8xe i thought was a very solid performer?
    Biostar A780 mATX
    ATI X850XTPE Stock
    OCZ 2x2GB DDR2-800
    heatware: skip86
    May 2004
    Nazareth, Israel.
    somehow!
    Nov 2004
    Il
    well if these special bios options can give it voltage options like the DFi, and it performs to the same level as the aa8xe, then i think that ABIT should be thrown into the discussion of the top boards.
    Biostar A780 mATX
    ATI X850XTPE Stock
    OCZ 2x2GB DDR2-800
    heatware: skip86
    May 2004
    Nazareth, Israel.
    but where is the SLI?!
    Nov 2004
    Il
    yea its not moddable into sli like the dfi ultra is, but those with ATI cards who want nforce4 shouldn't care.
    Biostar A780 mATX
    ATI X850XTPE Stock
    OCZ 2x2GB DDR2-800
    heatware: skip86
    Sep 2004
    noise problem.
    I waiting for http://www2.abit.com.tw/page/en/serv...station+Boards
    slap two 242's on water and OC (hopefully) all to hell.
    Dec 2004
    Wenatchee, WA
    I've had four ABIT boards and three sucked.
    Never gonna buy them again.
    Fused
    Dec 2003
    Malaysia
    Est.Retail Price: $218.75
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    ROFL.. wtf is that?! All those "cool" things are for noobs. The DFI boards are much more serious in this respect.
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
    Nov 2004
    Kenmore, NY
    Gee that memory cooler looks familiar... What a joke...
    Memory Cooler I reviewed back in May...
    ~MadMikeSS~
    Intel Q6600 G0 @ 3.2GHz 1.31v - AX MP-05 SP LE cooled
    P5B Deluxe 1236 BIOS
    HIS HD4850@750/1100 - AX MP-1 cooled
    Mushkin 4GB(1GBx4) DDR2-800 5-4-4-15 1.9v
    FSP 700W PSU
    Lian-Li PC-V2000B
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    Why did you rate it so high? I think it probably didn't do for the o/c. BH-5@3.3V it would help..
  18. #18
    Nov 2004
    Il
    yea i don't know why he called it a joke, when he said it was a good product...
    Biostar A780 mATX
    ATI X850XTPE Stock
    OCZ 2x2GB DDR2-800
    heatware: skip86
  19. #19
    Nov 2004
    Kenmore, NY
    If you read it, you'll see that even though I gave it a good overall rating, I rated it poorly for usefulness.
    ~MadMikeSS~
    FSP 700W PSU
    Lian-Li PC-V2000B
  20. #20
    Nov 2004
    Il
    yes i did notice that. but it did help temps somewhat.
    hopefully tictac is wrong about the retail price. 220 is way to much. all the other ultra boards are way less money. Nobody is going to buy this board regardless of the bells and whistles if it is that price.
    Biostar A780 mATX
    ATI X850XTPE Stock
    OCZ 2x2GB DDR2-800
    heatware: skip86
  21. #21
    Jun 2004
    The Baltics
    Hey, it seems that "Japanese made capacitors" have just become a new marketing riding horse - these "superhigh quality caps" are now both on DFI and Abit boards I wonder, which manufacturer is going to be the next ?
    away & gone
  22. #22
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    Hmm.. MSI?
  23. #23
    Jan 2005
    Czech R.
    And where is a 4pin MB connector ?
    Intel Core2Duo E8400™@ 4050MHz (1,3V real in LOAD) >Prime stable< || eVGA 680i SLi A1 (P32) || all fans @ 5V
    silent wc system [D-Tek FuZion + GPU + NB + SB + HDD + DDC Ultra+AC top + MCR320QP + Trodas's res + 11/15 Tygon tubing]
    4x1024MB A-DATA Vitesta 800+ EE (D9GCT) @ 900MHz 4-4-4-8 (2,2V real) || 2x ASUS 8800GT 512MB SLI
    3x WD5000YS - 500GB + Samsung SP2004C-200GB || Samsung SH-S183A || 22" LCD Dell™ E228WFP
    Chieftec DA-01B-D - Bigtower || CORSAIR HX620|| Logitech Cordless MX + MX510 + MOMO Racing + DFP
  24. #24
    Jan 2005
    Quote Originally Posted by tictac
    They better have an AN8 Ultra coming if that's true. But I must ask: was it ABIT that told you this price?
  25. #25
    Dec 2004
    The Holy Land
    nice board, bat im wondering in the vdimm and vcore is like the dfi board
    Asus P5-E X38 Intel QX9650 INOO3D 9800 Gx2 4x Super Talent's T800UX2GC4
    Creative X-Fi Raid 0 Raptors 36Gb data 1Tb Seasonic M12 700w
    Dell 2407WFP Lian-Li Pc-65 mod Custom Built Phase Change Unit |Logitech G25|
    RIG#2: DFI LANPARTY LT X48-T2R|Q9550| INOO3D 9800GTX|
    2xCellshok 1000| PC Power and cooling 750w Thermaltake v1
    Wife: DFI LANPARTY UT P35-T2R|Q930|BFG 8800GTS 512MB|
    Samsung ddrII 667| PC Power and cooling 610eps12v Thermaltake v1
    Htpc:Dfi Sli-Dr Venus|3700+|2x1gb Team Group ddr500|Thermaltake Mozart TX
