Like an idiot I though the plated parts on my Reserator system would be fine for corrosion problems but NO!!!
The CPU block is nearly gone has a small pin hole I plugged for the time being and has held for couple weeks.
Looking to upgrade to a MCW6000 but can cooper be affected by corrosion problems?>?? My Z-chipset block looks fine and its cooper/plexi
just hate to loose another block and more wasted $$$$
I added a small amount of antifreeze to stop any futher problems ***crosses fingers***
Docsis3.0
