Page 1 of 4 1234 LastLast
Results 1 to 25 of 94
Thread: EPOX 9NDA3J VER.:2.1 test
    Nov 2004
    EPOX 9NDA3J VER:2.1 test
    1
    2
    3
    4
    5
    6
    7
    BIOS
    K8 939 3000 0.09 0441spmw
    9nda3J 2.1
    G-Skill TCCD DDR600 256MBX2
    GeForce256
    TEAC512EB
    300W
    DDR600 1T CL2.5 4-3-5 memtest
    3000+ oc 2.7g
    Memory Addict
    Aug 2002
    Brisbane, Australia
    nice max vdimm ?
    Nov 2004
    Quote Originally Posted by eva2000
    nice max vdimm ?
    2.8V
    Dec 2003
    Quote Originally Posted by windwithme
    2.8V
    With a real easy (clip on if wanted to do that way) mod and plenty of overhead since VDimm is +5V driven. Have used up to 3.7V so far with only .01V fluctuation loaded/unloaded.
    edit: On 3+ not 3J, same VDimm circuit though
    .........current project, make the 135i faster
    Aug 2002
    I should've gotten the Epox....
    Asus P6T i7-920
    Asus P5N-T - C2Q Q9550
    Heatware: Omega65 170-0-0
    eBay: Omega365 138-0-0
    Aug 2004
    Finland
    I bought 9NDA3+ on saturday and it's rev 2.1. Flashed the newest bios rightaway. Memory (2x512MB OCZ 3700 EB) was memtest stable 241 cas3-3-2-8-1T with 2.8 Volts (max in bios), but no more. I think Vdimm-mod is required to go higher. These memsticks were totally memstable 239 cas3-2-2-8-1T with 3.0 volts on DFI Lanparty. But the most disturbing thing in this board is temp readings. With watercooling, 11x236 clocks and 1.65 vcore idle-temp is 52 and running SuperPi32M rises to 70 degrees according USDM. Anyone experienced same thing with temp?
    Asus P5Q Deluxe
    Q9650@4.2GHz, 1.2875V
    2x2GB Mushkin XP6400
    Club3D Radeon 4870X2
    Samsung SATA DVD-burner
    1.25TB HDD
    Chiectec full tower
    Zalman ZM850-HP
    BenQ G2400W
    Vista64 Ultimate
    Watercooled with PA120.3 & BIX3,Laing DDC,Swiftech Apogee GT & EK FC Acetal blocks
    Dec 2004
    Fuzhou,China PR
    Quote Originally Posted by Family man 72
    I am using 9nda3j v2.1.It seems like this mobo doesn't use corediode,instead it use something like 8rda's thermoresistor.For example, when you use watercool,the temp of cpu maybe above 50,but if you place a fan near cpu,the temp will drop to 2x!
    So don't trust it.
    Aug 2004
    Finland
    Quote Originally Posted by fatbird2046
    So don't trust it.
    Thanks for the info fatbird2046! I reinstalled the waterblock and applied a thin layer of AS5 (previously used only silicon paste). I let it settle and then check again.
    Asus P5Q Deluxe
    1.25TB HDD
    Chiectec full tower
    Zalman ZM850-HP
    BenQ G2400W
    Vista64 Ultimate
    Apr 2004
    Poland - Lodz City
    Windwithme - could you please tell me what is the size of this black bracket? I mean the one which is used for mounting coolers on cpu. I hope you know what I mean because I don't have any idea how is it called in english, sorry.
    Aug 2002
    Quote Originally Posted by Adasi
    CPU Rentention Frame
    I believe it's the same for all S754/939/940 motherboards
    Asus P6T i7-920
    Feb 2004
    Does it actually give the core voltage it claims to be available? This could be a reason to dump my msi .
    Dec 2003
    Quote Originally Posted by Speedo
    Yup.
    Oct 2003
    Terra
    Dunno if u know it but here is the latest bios 11/01/2005 http://www.epox.org/cms/index.php?op...details&gid=69
    CPU : Intel Core 2 Extreme QX9650
    MB : Asus P5E X38 Rampage bios
    RAM : Team Xtreem 4x1GB DDR2 OPB handpicked
    VGA : Sapphire 4870
    Power : Antec Quattro 850w
    Storage : 1 x 60GB OCZ Vertex + 2 x 750gb WD 32Mb
    DVD : Samsungs DVDwriter Sata + Liteon DVD
    Sound : Creative XFI Xtrememusic
    Cooling : D-Tek Fusion + D-Tek Fusion GFX
    Monitor : Samsung 226BW
    Errorcode : An error occurred at address AC 20 DE AE FF BC ...... System halted.
    Nov 2004
    to Adasi:
    about 8~10 or 8~12cm
    to Cranox:
    thanks
    i will test 9nda3+ 2.1 in this bios
    Apr 2004
    Poland - Lodz City
    Quote Originally Posted by Cranox
    Did anyone test it already?
    Aug 2004
    Finland
    I have been using it since I got my board. Dual channel works now better in slots 1&2 than with previous bioses. In fact, stable memspeed in dual channel is now equally good in slots 1&2 and 3&4.
    Asus P5Q Deluxe
    1.25TB HDD
    Chiectec full tower
    Zalman ZM850-HP
    BenQ G2400W
    Vista64 Ultimate
    Apr 2004
    Poland - Lodz City
    Hmm I'll check it then, thx for info.
    One more question about this board. Did anyone try how it works with hynix d43? Hope it will o/c the same or even better than on socket A - amd.
  18. #18
    Feb 2003
    Belgrade, Serbia
    What is the difference beween the old rev and the ver 2.1............... and how is this board with 2 x 512mb of TCCD, WB UTT or BH-5 with 1T i read somwhere that it doesn't like 1gb of ramm to much.......and how stable or unstable are voltages on it
  19. #19
    Dec 2003
    @ Millyons:
    2x512 TCCD does 270 MHz for me, 2x512 VX does 265 MHz, 2x256 BH-5...even higher. This board does fine with 1 GB 1T, I'm using slots 3-4 though, as 1-2 acted a bit differently. Regarding voltages, they seem pretty stable to me. I have seen some other post where someone said that this board limited is max stable clocks compared to the Neo2, but I am seeing the opposite with my cpu.
    edit to add: and the Rev 2.1 has a new VCore circuit
    edited again for spelling
  20. #20
    Feb 2003
    Belgrade, Serbia
    Quote Originally Posted by mikead_99
    @ Millyons:
    2x512 TCCD does 270 MHz for me, 2x512 VX does 265 MHz, 2x256 BH-5...even higher. This board does fine with 1 GB 1T...........
    thanks man, that's what i was hopping to hear
  21. #21
    Oct 2003
    Terra
    I also use 2 x 512 mb BH-5 and that in slot 1&2
    VGA : Sapphire 4870
  22. #22
    Sep 2004
    good board good price. no reaon to buy + version for $40 more unless you need FW
  23. #23
    Apr 2004
    Poland - Lodz City
    Do you guys have issues with asynchro mode too? For example:
    If I set fsb at 300mhz (no matter what is the multiplier) i cannot boot with memory set at 166 asynchro mode.
    Could you please try to boot with the settings above and check if you can boot with them? Thx
    Edit -> I have brand new bios from epox website.
  24. #24
    Sep 2004
    try mem slots 3 and 4 only. I don't have problem..this is 166.
  25. #25
    Apr 2004
    Poland - Lodz City
    I used every slot, still doesn't work. I'll try later with another bios version... (from what i've seen, the oldest one seems to work fine :| )
