01-08-2005, 06:17 PM
#1
Xtreme Mentor
A64 Ram Divider Training Guide and overclocking tips(newbies Please Read!!)
Here's a handy guide I wrote with an enclosed tool to help calculate different ram speeds and cpu clock speeds using different memory dividers and multi's. Big thanks to goddh0r for writing A64 MemFreq 1.1 Program!
A ram divider is usually a setting found in your ram tweaking setting menu in your bios. dividers usually are 200(1:1), 166, 150, 133, 100 or 400, 333, 266, 200. etc..
The lower you go on the divider, the less ram speed is used. The whole point of a divider is if your memory can't keep up with your fsb. say you have an a64 3200+ that does 2.5 ghz. you would normally do 250x10 ram 1:1 (ram 250 also) 1:1 HTT=ram speed 250=250.
but in your case you have ram that won't do 250mhz, so you need to use a divider. Download this zip file and type the HTT(fsb) in the top line and go from there. This will help you find your sweet spot. You can use it to help calculate your ram speed and total cpu clock by using different dividers and cpu muti's. AMD64 multi's are unlocked downwards. so if you have default multi of 10, then you can use 9, 8, 7, 6, 5, don't go below 5. In the case of an FX, the multi is unlocked both ways.
Just think of your cpu max clock and your ram's max clock and find the best way to utilize the most from each.
ex. Joe has an athlon 64 that does 2.53 ghz. stable. but his bh6 ram only goes up to 232mhz at 2-2-2-6 1T. what does Joe do? he does this: set's the cpu multi at 9. sets ram divider at 166. sets his HTT(fsb) at 280. bingo! Joe's cpu is now doing 2.52ghz(9*200) and his ram is doing 229mhz!
Here's another example: Steve just shelled out $250 on some new TCCD that does 284mhz at 2.5-3-3-7 1T. He has a crappy 3500+ that only does 2.58 ghz. Steve assumes that because his cpu only does 258x10, his ram will have to run at 258 too. But Steve wants to use all that bandwidth of his tccd, but doesn't want to go over his cpu speed. So what does Steve do?
Steve set's his multi to 9 and runs his ram up to 284 1:1. Now his cpu is at 2.55(9x284) and his ram is ripping at 284mhz like it should! Steve is very happy and he is glad he spent the money on his new ram.
GENERAL RULES ON A64:
Remember, never use .5 multis, never use multi under 5. For best performance use 1T command setting(I've found 2T command is about the equivalent to a 20mhz loss in memory performance)
IMPORTANT!!!
Depending on your A64 chipset your total HTT(fsb) and HT multi(2x, 3x, 4x, etc.) should never exceed the total hyper transport link speed. ex. NF3 250 ultra has max of 1000mhz hyper transport link. So if fsb is 290 and htt is at 5x(200*5=1000) 5x290=1450 BAD!!!
to fix. just lower the HT multi(hyper transport Link) to 3x(200*3=600) so 3*290=870 total hyper transport speed. GOOD! you kept it under 1000!
In the attached zip file. enter your fsb(htt) in the First line at the top.
__________________
i5 665k, i3 540, i5 660
H55M UD2H
maximus III formula, Tpower I55,
5850 920/1300
lsi 9260-4I w/fastpath
3 x 50gb vertex2 Raid0
ST1000-P psu
01-08-2005, 06:50 PM
#2
Xtreme Guru
You have the HTT multi wrong. The multi is what your FSB is multiplied to get the HTT, its not 1000+290, its 290*5.
__________________
For those of you about to post:
01-08-2005, 07:16 PM
#3
Xtreme Mentor
Thanks craig.
LOL, my bad. I will change it. Other than that, do you think this would be helpful to newbies?
__________________
H55M UD2H
5850 920/1300
ST1000-P psu
01-08-2005, 07:23 PM
#4
XS News
I dunno. It would be helpful for me if I can find the RAM divider in my stupid K8N-E Deluxe mobo...
01-08-2005, 07:25 PM
#5
Xtreme Mentor
Some bios's are different. It might show divider as 1:1, 2:1, 5:4, etc...
nevermind... go to advanced menu in k8ne and select chipset. Make sure mem clock mode is set to manual. then go to first line. memory clock and dividers should be in there..  k8ne list dividers as 400 (1:1), 333, 266, 200
__________________
H55M UD2H
5850 920/1300
ST1000-P psu
01-08-2005, 08:03 PM
#6
XS News
Thx trans am. But what are the rest? I know 400 is 1:1, but, what are the rest? Thx for all the help so far.
01-08-2005, 08:32 PM
#7
Xtreme Mentor
200=100(2:1)ddr400 will run 1/2 at this setting(ddr200) you figure the rest out. just use the file I attached.
__________________
H55M UD2H
5850 920/1300
ST1000-P psu
01-08-2005, 08:43 PM
#8
Thanks for the complete newb perspecitive.. Though anyone I would think that has fojund theyre way her should know this. So I am assuming youve encountered lots of hows to and how do you threads
__________________
A64 X2 4400+@2.7/DFI NF4 ULTRA D//Patriot Pc3200 LL CE-6 2gb@540 3,3,2,5/7800GTX/OCZ Modstream 520/LLPC75 swiftech H20.
01-08-2005, 08:51 PM
#9
Xtreme Mentor
You'd be surpried how many people don't know this. A64 overclocking is a little different from Pentium. Many are switching to K8 and have no idea what they are doing. Maybe it doesn't help you, but the tool alone is really handy when using dividers with really high fsb. I think most who read this thread will really care about the tool that's attached. it makes calculating dividers really fast and easy. There are others who are new to overclocking and they deserve a few tips. XS, is for everyone.
__________________
H55M UD2H
5850 920/1300
ST1000-P psu
01-08-2005, 08:56 PM
#10
Fully understandable. I just found the really large type to be a sublimal clue
__________________
01-08-2005, 10:36 PM
#11
tl;dr
setting to a half multi is only bad if the resulting memory frequency is below your optimum frequency.. sometimes it is handy to use it as it could get you say 5mhz closer than running a full multi.
Also, half multipliers round UP to the nearest full integer, not down.
setting 5.5 would result in 6 for ram divider, not 5.. for example.
#12
Xtreme Mentor
noted...
my point was that using .5 multi is very misleading.
__________________
H55M UD2H
5850 920/1300
ST1000-P psu
01-10-2005, 03:34 AM
#13
Xtreme X.I.P.
nice!
09-23-2005, 12:40 PM
#15
Nice program, it's easier than using a calculator ^^
05-21-2006, 10:34 AM
#16
IMPORTANT!!!
Why are you not supposed to go below 5x...?
-Thanks
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
