http://www.ocbase.com/downocct.html
http://translate.google.com/translat...language_tools
the page is in french, but you can always use google to translate.
The program itself is in english.
It LOOKS like a pretty good program similiar to prime95 since it calculates and compares calulations to an internal table. It works together with Motherboard monitor (mbm) and shows voltage rails and temps while its testing. Also, it allows uploading results to a database and has nice graphical statistics.
It might be worth looking into it.
I personally would be interested in how this program behaves for all those people with A64 winchesters which fail (eg. at stock). Does this program give problems too ? Play around with the options
Addendum: We REALLY, really need to differ between programs which only run and put heavy load on the CPU - and programs which calculate and compare the calculated results to fixed, known internal results.
ANY program which just "utilizes" the CPU but does not validate calculation results (IMHO) is not suitable for accurate testing of stabillty.
Thats why i think this program might be interesting - especially with all the recent problems with prime95 and some AMD winchesters.
Edit:
http://216.239.37.104/translate_c?hl...language_tools
has a nice review/listing of all the latest tools for stability testing,
- OCCT 0.91
- Prime 95
- Super Pi 1.1e
- Toast
- CPU Burn-In
- CPU Burner
- CPUStabTest
- Hot CPU To test Pro 4.2.3
- BurnInTest
as i mentioned above, ALL programs except Prime and OCCT are *worthless* since they only burn/bench the CPU.
Only prime and OCCT can give you a result whether your CPU is actually stable or not - i see TOO MANY people here on the forum using eg. SuperPI and making an assumption about stability - but they cant with those programs.
Thats why i am still against some recent opinions like "Prime is the most overhyped program, just dont use it" etc..... but Prime/OCCT is the ONLY program which allows us to make a somewhat reasonable statement about stability.
Read the review at above link. (page translated with google).
OCCT btw. comes out as big winner there with its many features and it was the only program (together with prime95) to detect instability in the tests there.
