Page 1 of 3 123 LastLast
Results 1 to 25 of 61
Thread: MSI Neo2 Platinum Modded 1.5X BIOS
    Jan 2003
    Hi,
    I've a modded version of 1.5X Beta BIOS for the Neio 2 Platinum for you. It's for those don't like the loud chipset fan. All other hidden options are usable too. You find the file in the attachments of this post.
    Maybe file ist to big. Uploading it is not working. I'll upload the file to my websapce now. Here is the link: BIOS 1.5X mod
    greetz,
    Erik
    Nov 2002
    er..where's the attachment?
    edit: thanks...I'll be your first guinea pig.
    Jan 2003
    I've flashed it already. It's working perfect
    Nov 2004
    what kinda extra performance u getting? any higher overclocks...? i think im on 1.51b now.... good idea to go to modded version?
    Jul 2004
    Finland
    Includes +18% vcore like in 1.36b bios?
    Athlon 64 3000+ Winchester @ 2,6GHz, ASUS V9999GE 256MB @ 450/1200 16/6
    MSI Neo2-54G Platinum Edition, OCZ 3200 VX 1GB, OCZ DDR Booster, OCZ 520W, WD Raptor 74GB, Mitsubishi 2070SB 22" CRT
    Nov 2004
    i downloaded the attached file. Doesnt want to open... says something about binary file being unable to open :/
    Jan 2003
    @Kuri, no I haven't found a way to make these settings selectable. For me it is not the problem. My winnie doesn't like any voltage about 1,55+10% setting. Tested this with 1.36b.
    @mushk1n
    If you like silence, yes it is. With my watercooler setup this chipset fan is pure horror. Thats the reason why I've modded this 1.5X BIOS. I haven't tested if higher speed are possible now. My system is running with 2750=275x10 1:1 1T 2,5 3 3 5 rock solid at the moment. With 1.41mod it isn't 100% stable. Just give it a try.
    Jan 2003
    Where you get this message? While unzipping, or while flashing BIOS?
    I've flahed it with awfl833d using a bootable DOS floppy. No problem with that.
    Nov 2004
    ^^^ doesnt work via the Windows Update
    flashing
    Jan 2003
    Maybe. I never use windows flash tools. Try booting with a floppy. There's a guide here in this forum using beta files with the windows flasher, but I don't know where it is.
    Nov 2004
    can you do me a favour, upload a zip file that contains everything i need to flash succesfully? i will do it via bootable floppy then..
    cheers
    Jan 2003
    No prob, just wait a minute
    Uploaded including flasher and flash.bat
    Just extract to floppy, boot and type flash
    The link
    Nov 2004
    cheers buddy,
    got it all flashed now! yey... seems to wanna do 2.5-3-3-6.. where it wud only do 3-3-3-10 b4! woohooo, that bios rox! Good Find!
    wot settings have u got for ur NB? i dont want it to crash and burn.. but i wud like it to be a little quieter...
    Jan 2003
    Fine !!
    I use the 40°C Setting. No problems with heat or instability.
    Dec 2004
    The Holy Land
    i will try it know, 10x dude
    Asus P5-E X38 Intel QX9650 INOO3D 9800 Gx2 4x Super Talent's T800UX2GC4
    Creative X-Fi Raid 0 Raptors 36Gb data 1Tb Seasonic M12 700w
    Dell 2407WFP Lian-Li Pc-65 mod Custom Built Phase Change Unit |Logitech G25|
    RIG#2: DFI LANPARTY LT X48-T2R|Q9550| INOO3D 9800GTX|
    2xCellshok 1000| PC Power and cooling 750w Thermaltake v1
    Wife: DFI LANPARTY UT P35-T2R|Q930|BFG 8800GTS 512MB|
    Samsung ddrII 667| PC Power and cooling 610eps12v Thermaltake v1
    Htpc:Dfi Sli-Dr Venus|3700+|2x1gb Team Group ddr500|Thermaltake Mozart TX
    Nov 2003
    Quote Originally Posted by MMIQHW
    Hi,
    greetz,
    Erik
    Loud chipset fan? Its prett darn quiet...and what setting controls it?
    Nov 2004
    Keller, TX
    yes im curious as well ths fan is the epitome of hell.
    EDIT: What options do you have for the fan?
  18. #18
    Aug 2004
    Erfurt/Germany
    how does it work with tccd ram?
  19. #19
    Jan 2003
    @tbonekot
    Very well.
    I use A-data DDR 600 TCCD RAM in my system.
    @DevilsRejection
    Fan control ist in the hardware monitor section. Just use the 40°C setting. Fan speed ist always the same. It seems that 40°C is never reached, because there's no stability problem with this setting. Well, the other setting only set a higher temperature where the fan speeds up. 40 is the lowest.
    @Monarch
    With standard setup this chipset fan kills my real silent cooling solution
  20. #20
    Sep 2003
    any better clocks with this????
  21. #21
    Jul 2004
    Sweden
    @tbonekot
    Very well.
    @DevilsRejection
    @Monarch
    How do your A-DATA overclock?
  22. #22
    Nov 2004
    Keller, TX
    thank you so much, hope this aids in my stability testing, damn glad the chipset fan shut the hell up, this alone makes this bios rock!!!
  23. #23
    Jul 2004
    Sweden
    The link
    That AWFXXX file is broken, I tried to dl it again and it was the same error... I already got that file, but others may not have it...
  24. #24
    Jul 2004
    Sydney
    I've been having troubles with my 9600pro rebooting during games with my neo2 (x800xtpe died so i gotta use this for a while). I tried this bios today and now it's working perfect! Thank you very much
  25. #25
    Jan 2003
    No Problem. It's not a big deal to mod BIOS files. Is the zip-file with flasher ok? I#ve downloaded it some minutes ago. Unzipping is no problem for me. But if there's a problem for others I'll upload it again.
    Greetz,
    Erik
