Results 1 to 17 of 17
Thread: Dangers of the OCZ Booster
    Oct 2002
    Oslo, Norway
    Cut'n'paste from another thread I posted in: http://www.xtremesystems.org/forums/...290#post647290
    No need to mod it, the voltage of the booster varies with the 12V line (this by using an OCZ PSU). Tried again with 4,32V, display on booster only showing 3,9V. One problem is that the booster uses the 5V line as reference, if the 5V line isn't 5V the display on the Booster shows wrong voltage.
    This is dangerous for people not knowing that, the 5V line must be exactly 5V and the 12V line must be 12V for the booster working the right way. With higher voltage on the 5V line than 5V the Booster shows lower voltage than it gives and lower than 5 it shows higher voltage.
    Tested again with 12V line at ~13,9V, 5V line at ~4,6V, display showing 4,8V, actual voltage is 4,32V. With 5V line at ~5,8V, the booster only showed 3,8V, boster still giving 4,32V.
    Pic of one measuring point:
    Satan: Opteron 165 - TT Big Typhoon - DFI Lanparty NF4 SLI-DR - OCZ EB PC3500 2x512MB - Asus Radeon X800 XT - Raptor 74GB x2 RAID0
    Slepbar (Lenovo 0761): Pentium M 735 (Celeron M 380 @ 2,13GHz) - DDR2 2x512MB - GMA 900
    3DMark2001: 40392 - Super PI: 23s
    Aug 2004
    Italy - Piacenza
    Mhmmm... interesting
    Opteron 170 @ 2.2Ghz - Zalman 9700
    OCZ Pc3200 2x512Mb VX @ 220Mhz
    DFI nF4 SLI-DR ( 3.29 BIOS )
    Leadtek 6800GT@415-1120
    Seagate Barracuda 2x120Gb Raid0
    This is the rule :P
    Jun 2004
    The Baltics
    Care to translate that text on the pic? I can pretty much guess what's meant there, but guessing-trial-error method is not the most applicable here .
    away & gone
    Oct 2003
    Scotland
    I've just done some testing on mine (rig in sig).
    OCZ Powerstream rails as measured with DMM:
    12v = 13.041v
    5v = 5.432v
    3.3v = 3.881v
    I set bios vdimm to default 2.5v:
    with bios vdimm showing 2.5v, the booster showed 2.5v on both display & read point (using above pic), the DMM showed 2.5v at the mosfet on the dfi (to measure vdimm).
    I then increased the booster knob until the display read 2.8, and the bios/booster read point and dfi mosfet scaled accordingly (all showing 2.8v).
    I tested up to 3.6v, and all 4 voltage readings were in line with each other (other than usual .05v discrepancy between bios/actual). Everything seems to be fine using my normal rails.
    I then decreased my 5v rail to 4.8v (had trouble booting any lower):
    with vdimm set to default in bios (2.5v):
    bios showed 2.5, dfi mosfet showed 2.5, booster read point showed 2.5 but the booster display showed 2.8.
    turning the booster knob until the bios/mosfet/booster read point showed 3.6, the booster display showed 3.9, so it does appear that something is weird...
    I haven't tried any more rail configurations (different 12v, higher 5v etc), but I will if anyone wants me to.
    btw, Kamerat, wtf is that green thing in your avatar? I've actually been using that as my msn messenger pic for a couple of weeks but don't know what it is, lol (looks really cool tho).
    Feb 2003
    Denmark
    Quote Originally Posted by mrlobber
    The actual voltage can be measured here, by using ground also.
    Oct 2003
    Scotland
    just did another test by maxing out my 5v rail (5.62v).
    using bios default of 2.5v:
    with a reading of 2.5v actual @ bios/mosfet/booster read point - booster display = 2.4.
    with a reading of 3.7v actual @ bios/mosfet/booster read point - booster display = 3.5.
    too scared to try higher vdimm just now.
    c[_]
    Nov 2002
    Alberta, Canada
    green thing is called "bundles"
    its a genmay thing
    /thread hijack
    All along the watchtower the watchmen watch the eternal return.
    Jul 2004
    where can i measure the 3,3 Rail??
    System in Sig
    Daily use PC: P4P800-Deluxe BIOS1019 PAT Hacked | P3.0C@3675 | 1GB 3700EB 1:1 3-2-2-6 DC | DDR Booster | R9800Pro@425/730 | 2x Crappy Maxtor 120GB | OCZ 520W
    Daily use PDA: Fujitsu-Siemens PocketLoox 720 CPU 520@585 | BUS 208@234 |RAM 104@118 <--- No-one wanna try LN2??? :O
    Oct 2003
    Scotland
    Quote Originally Posted by I_Am_ToO_SeXy
    System in Sig
    use one of the orange wires from the psu.
    On the OCZ, I have an unused 4-pin cable (looks like the 4-pin 12v ones that plug into motherboards), it has yellow, red, orange & black wires.
    thanks, STEvil, that's been bugging me for ages.
    Oct 2002
    Oslo, Norway
    mrlobber: What my Danish friend Pejsen said.
    Trixxy: Bunchies. OCZ should be aware of this problem, weird thing is that the manual doesn't say anything about it.
    c[_]
    Nov 2002
    Alberta, Canada
    er bunchies... was close enough
    Kamerat - Does the manual not say anything about calibration? Its not much of a problem if you calibrate the unit to your system
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    Kamerat
    OMG man.. that green thing is hilarious!
    So the voltage isn't that much off, as long as your 5V rail is KINDA close to spec?
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
    Oct 2002
    Oslo, Norway
    Quote Originally Posted by STEvil
    The manual mention calibration, but it doesn't say the readout is dependent of the voltage of the 5V rail, nor does it say that the voltage increases with the voltage of the 12V line.
    Adjusted my 12V rail to max, which is 13,8V and adjusted the voltage of the Booster to 3,9V. Then i adjusted my 12V rail to min, which is 11,0V, and the Booster only gave 2,8V. Imagine someone whos not aware of this and adjusted his Booster to 3,4V when running 11V... then maxing the rail, that will give about 4,7V to the RAM. I'm lucky that I have BH-5...
    c[_]
    Nov 2002
    Alberta, Canada
    This is why it mentions calibration
    Oct 2002
    Oslo, Norway
    Not from what's written in the manual, doesn't mention anything about the 5V rail:
    Q: I set a voltage of 2.6V (or some other value) in my BIOS, but the DDR Booster is not reading the correct value! Whar's wrong??
    A: The DDR Booster may have been knocked out of calibration during the shipping process. In order to recalibrate the DDR Booster, locater the small screw adjust on the front of the DDR Booster, just under the LEDs. To adjust the readin upward, turn the screw very slightly clockwise. To adjust the reading downward, turn the screw very slightly counter-clockwise.
    Sep 2004
    Spain
    Quote Originally Posted by Kamerat
    So:
    Readout: Varies with 5V rail
    Voltage: Varies with 12V rail
    I'm running 5V: 5.4V 12V: 12.64V
    Booster reads 3.5V.
    What is your educated guess about the actual VDimm?
    zib.
    EDIT: MB is Neo2 Plat, which has the crappiest BIOS readouts in the world anyway...
    Member
    Dec 2002
    Leics UK
    Its a good idea to recalibrate the booster if you make any system changes.
    Setting it to minimum then reajusting is the best way.
    Dont trust the bios as thats allways wrong, use a multimeter.
    The way the booster regulates voltage is a bit shoddy IMO, if I could get my system to turn on with it fitted (which I cant) I can think of a few mods that might make booster better.
