Results 1 to 16 of 16
Thread: GT to ultra power mod done, will it work?
    May 2004
    Perth, Western Australia
    its a simple mod, similaer to kamerats dual 12v lines
    will this work? no caps added to card, but the psu had 2 16A lines, so now the card is only drawing half the current load from the main rail, so the cpu should get more power too right? i just soldered together the joiner
    Quote Originally Posted by bh2k
    sorry m, OI'm a bit drunkz!
    Air benches with 3000+, DFI nf3 and 6800GT 2001SE: 26312 3d03: 13028
    May 2004
    will this work? i will try if its not gonna casue trouble pulling from 2 12v rails, since the psu is powering mobo it should make a difference right?
    Jul 2004
    n^n!
    I really don't know, but if you go ahead please post the results. This looks interresting
    Dec 2004
    I have been using that for two months, it is simple and it works....
    But in the psu ALL the wires are joined again so there is no 2 separate 12 V lines... they are all the same.
    But you get more current trough to the card and voltage doesnt drop so much in the card because of that double wiring....
    c[_]
    Nov 2002
    Alberta, Canada
    Quote Originally Posted by zadah
    PSU's with multiple rails are not joined internally.
    All along the watchtower the watchmen watch the eternal return.
    May 2004
    ill try it, the double rails will split the load on my psu, casue the secondary rail has better volts, but will the card short out from receiving 2 many incoming currents? i dont think so, but im scared becasue of all those guys who lost their x800s using a separate psu for vidcard
    May 2004
    ok im running with this now and its all good. played far cry for a few hours
    cant test oc till some cold weather
    Aug 2003
    Belgique, Belga, Belgio, Belgium, Belgica, Belgie, Belgien
    Is there a chance of short circuiting you psu and maybe your card?
    Sep 2004
    Fantasia
    The question is: is it more OC'able? What are the practical differences?
    There is a separate thread going about this, but with a different method being explored:
    ebay under aws983s, heatware under Mr. Tinker.
    Sep 2004
    Fantasia
    Quote Originally Posted by reject
    Not sure but I think that was a problem because you have the lines from one PSU grounding through the card to the MB then to the PSU connected to the MB, which is bad.
    May 2004
    i dont think ill be able to test the oc improvements till its colder or i get some better cooling, i think this mod will help cpu more than gpu tho. now it has up to 16A when before it had to share that with vc, and now gpu has 31A on 12v
    Dec 2004
    Overland Park, KS
    so wait, what exactly did you do? I don't quite see what you did. It has 2 lines, did you just connect one to the other and to the video card?
    Intel Core i7 920 #3841A437 @ 3.8ghz 1.26v HT off
    Thermalright True-120 Extreme
    Gigabyte ex58-UD3R @ 190x20
    6gb (3x2gb) G.Skill Pi @ 1520mhz 7-7-7-21-1T
    PNY 8800gtx @ 640/1000
    abs (tagan) 700w
    Antec Nine Hundred
    Seagate 320gb
    LG 25.5" LCD
    Logitech G11 + mx518, Logitech x530 5.1 + plantronics DSP500
    Jun 2005
    he made a 2 into 1 molex connector and has one input coming from +12v1 and the other coming from +12v2
    I'm not sure if I'd recommend this for long term use though - all of the 12v rails in the psu come from the same transformer, they are only divided by seperate rectifiers to keep current below 20A on each line. so whats the problem? Well if the voltages are a bit different like you said, the two rectifiers can start fighting each other... in a sense. Basically you risk civil war inside your psu with one line trying to raise the voltage on the other, and the other line trying to lower the voltage on the first, etc.
    though personally, i've yet to see hard-evidence that this can happen. i was going to do it myself but i just bought a single-rail psu, so its a null point.
    Amd64 3500+ Winnie; OCZ Plat Rev2 TCCD; DFI SLI-dr; FireGL V3100; Vapochill Classic; Dell 2405fpw
    Sep 2004
    Fantasia
    Now DamienKC can finally rest after receiving his answer 1 year and 2 months later.
    Jun 2005
    haha woops. i totally didn't even notice the date of this thread. wow, this is graveyard material... i don't even know how i found the thread o_O
    Aug 2005
    Hey, this thread has always intrigued (sp?) me
    Where there any gains at all?
