I think I found the way to remove the issue we have with 6800 series cards. As most of you know while benchmarking the card would drop the core clock and this would result in lower scores. You can see that with RivaTuner monitoring. Most of our card would do that no mater on the cooling used. Now when you will apply my technique and the OC would be too much for your card it still will stutter so there is no cure for that you need to know it’s limits.
But it would not drop the clock. I gained as much as 300+ points in 3dmark05 by doing this. It’s is extreme way and probably not suitable for 24/7 operation like gaming ext…. But for benchmarking it works. Why my 6800GT is #1 place on orb ?
Because I run the benchmark @ speed I set not 1 MHz less. You could have your card clocked to 500+ but that really does not mater since it will drop the clock to whatever safe settings it programmed too if you put the card under stress. I found out that this protection kicks little bit too soon .
That #1 spot for my 6800GT will change probably soon since I’m releasing this and others can take advantage of this simple yet working solution. Oh well it took me a while to find this workaround so enjoy.
Here is how it all happen
We all know that thermal throttling is a big problem for NVIDIA cards. Now after a long while i think i figured it out how to disable it. It is an Extreme way but it works.
It began while i was benchmarking and monitoring my card with RivaTuner monitoring tool. I always notce that when the card would get to hot or would think it has to much work load it droped the clock. Even whith realy cold temps this problem stand true. Now i noticed that whenever this would happen the card would drop the CORE clock to 421 .
And then it hit me :thwack . The NVIDIA GOD came down and has spoken to me :respect: 421 was the default bios seting i was booting from. My bios was set to 421/1160 as a boot speed
So the card would throttle to safemode setting i.e the lowest setting it knew by the bios. So then it got obvios to me that if perhaps i would make bios with the max speed i knew my card can hadle then it would never drop the core bellow that. For me 100% safe setting was 472 on the core. So i made the bios that booted from 472/1200 3d@1.5v .
Did it work? Oh ya it did. :danceshee !!!
The proof is my 3dmark score . On the same 472/1350 that i benched for a while the card scored way more. I'm including a pic of RivaTuner monitoring and you can clearly see that while i was benching 3dmak2005 game2 it droped the clock from 472 to 421. Now i does not happen anymore. When i bench it stays rock solid @472 .
This is great yet simple find couse i bet most of Nvidia's here while benchig experince this problem. Why dont you guys benchmark 3dmark2005 @max your settings and enable RivaTuner monitoring i bet you will see your core drop. Give it a try
 below is imposible. It's not practicle couse i cant emagine you would want to run your card at that speed but it will work for benching. I use OMNI editor but it realy dont mater all yo need to know is how to make bios and flash
