Results 1 to 25 of 192
Thread: Dothan screams like scalded CAT!!!
Threaded View
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    Yeah,
    hehehehehe....
    So out of the box DFI 855Gme with shipping BIOS, default voltage and stock cooler....
    Dothan 1.7gHz @ 2.5gHz.... that's nearly 50% OC @ 1.34v.
    Now the issues....at default Vdimm, I can't run the BH-5 north of 200mHz and oddly enough.... PQI Turbo TccD (256mb) won't boot at cas 2.5?????? Running CAS2-3-3-7 the TccD is good to about 240mHz at 2.5v.
    I don't have many benches yet, I can't get the onboard LAN to work. I installed the LAN driver and enabled it in Control Panel and in BIOS, but the board just won't "see" my DSL Modem.... and I only have a few apps on disc. So I'll use the A64 rig to burn some apps on a disc and run more benchies later. So here's what I've got for ya....
