I finally went to aitec electronics shop near Leuven today and got the missing 20k VR.
I was so eager to finish the mods that I completely forgot to take pictures though :/
so here's one with the card installed. I didn't do the OVP mod and the white wires sticking out are for measuring the corresponding voltages
testing so far:
540 mhz core @1.5 Vcore = 30 mhz increase over stock :grum:
memory is a bit of a tricky thing:
best I got so far is 570 mhz @
2.10 Vdd and 2.25 Vddq
2.15 Vdd already gives worse results.
keeping vddq 0.05V higher then Vdd kills the oc
0.15 more V on Vddq give only a few extra mhz at best over 0.10 higher Vddq.
another thing that's odd is that I could reach 570 mhz on the mem stock on the axp
i only managed 540 with the p4 stock.
I also can't remember what bios is on the card or if it's the same as with the axp testing
overall, I'm very dissapointed seeing that many out there obtain these (or even higher) clocks at default volts...
