just flashed x800pro to xt pe, few problems...
Hi, just found some balls in me to flash my asus x800pro vivo, to an x800xt pe bios, and it turned out with all the 16 pipelines 1st, the first thing i ran was aquamark3 at default 520/560 xt pe speeds, and it went through fine, then came 3dmark03, again fine, then 3dmark05, and fine, i was so HAPPY! but then i did 3dmark01se just out of damn intereste for scores, (as i was getting higher scores on all other benchmarks) but it always keep freezing at the nature test? what the hell?? i even back it down to 500/560 and it still freeze at the the nature test.. i mean wtf? it passes all the 3dmark03, 05 adn even aquamark3 no probs....
is my gfx card unstable because of that? i could get up to 525/590 before the flash, rah!!
also, i noticed my load temp has raised from 54C to around 64C!!! is that normal after a flash to xt pe? and will it effect my o/c? thanks, bye.
- You may not post replies
- You may not edit your posts
Forum Rules
