Page 1 of 10 1234 ... LastLast
Results 1 to 25 of 229
Thread: MSI K8N Neo 2 November 2004 released version
    Banned
    Jan 2004
    Land of Buckeye
    K8n Neo2 Chip: 0438A2 Made in Taiwan:
    Date:NOV 2004 released, nothing new
    Bios: 1.37 Moded
    What kind of improvement?
    well, as usual, I need to set vddr as 2.65 to run DDR570 2.5-3-3-7 to pass memtest std test
    now, use only 2.5v
    (HTT=3x)
    Memory Addict
    Aug 2002
    Brisbane, Australia
    any indicator as to date of release seen on the box's label ???
    Banned
    Jan 2004
    Land of Buckeye
    Quote Originally Posted by eva2000
    With S/N:K0411xxxxxx
    Feb 2004
    South Africa
    Please do me a favour and see if that board runs well with 4 sticks of RAM in it.
    This signature does not exist.
    <---I love that smiley
    Xtreme X.I.P. MaxxxRacer's Avatar
    Aug 2004
    Los Angeles, Ca USA
    The sticker on the board says made in china.... But you said it was made in taiwan.. Im confused.. Or are you just refering to the nf3 chip itself...
    Banned
    Jan 2004
    Onepagebook, what PSU are you using ???
    Banned
    Jan 2004
    Land of Buckeye
    OCZ 520w powerstream
    update:
    How about DDR584 2.6v..( This pair of RAM is what I received from agenda2005, he could npt even got 275, 3-4-4-8@ abit av8 1.1 )
    Oct 2004
    Athens,Hellas
    Thats weird mine is a 0439A2 Korea and the serial num is a 0410XXXXX
    Some user reported better BH-x performance with the new version can you confirm that?
    Do you have your winchester to check if the subzero bug is still there?
ID:	19755   Click image for larger version.
    if this is your first night in xtremesystems,
    you have to overclock.
    Banned
    Jan 2004
    Land of Buckeye
    Quote Originally Posted by esdee
    Basically, I would say October and November boards are all good.
    I did tried the 3500+ 0.09micron, nothing wrong though.
    Oct 2004
    Athens,Hellas
    Damn OPB
    you mean no no-reboot when the winch is COLD?
    Please if you have the time check that bh-x performance
    /EDIT I have the impression that the Chipset is printed upside down
    Banned
    Jan 2004
    Land of Buckeye
    Damn OPB
    Did that long time ago since I used 1.3b6 at that moment:
    mobo: MSI k8n neo2 1.3b6 beta bios
    CPU : 3500+ 90nm s939
    Cooling : vapo LS
    OCZ DDR booster 3.7v
    Oct 2004
    Athens,Hellas
    Quote Originally Posted by Onepagebook
    Cooling : vapo LS
    Thanks!!!
    You really push those Mushkin HARD!!!
    Oct 2004
    SC, USA
    update:
    WOW... just wow. I cant beleive my eyes! My Abit Av8 sucks and dissapointing. Do you know any store where I can order for those new MSI board and get the new release? I check newegg yesterday and all their MSI NF3 Neo2 board are sold out. I guess they should be getting the new revision soon. Does anyone know how I can work around the MSI NF3 Neo2 board to get Thermalright XP-120 heatsink to fit on it. I can't do away with my XP-120 bcos of it's cool and quite operation but I also need this MSI badly. Thermalright mentioned that the backplate obstruct the XP-120 mounting. Unfortuntly I have already lapped the XP-120 and cannot return it for exchange for XP-90. Any help will be appreciated at this time.
    Core 2 Duo E6600 [L625A] 3330MHz 1.375Vcore 24/7
    Core 2 Duo E6600 [L640F] 3330MHz 1.475Vcore
    Crucial 10th Anv 2 x 1GB DDR2-667 @ 463MHz 4-4-4-12
    ASUS P5B Dlx
    FOTRON BLUE STORM 500W
    TT BT with stock Fan
    Gigabyte Nvidia 7600GSw/ Silent Pipe
    WD Cavier 250GB
    Antec P160
    Oct 2004
    SC, USA
    update:
    Onepagebook,
    What type of cooling are you using? Vapo LS or what. That CPU temp (41C) is a bit high for Vapo LS, so I'm wondering what type of cooling you were using.
    ASUS P5B Dlx
    WD Cavier 250GB
    Antec P160
    Sep 2002
    UK
    The problem I thought with the XP-120 is the cap.
    I reckon you have 2 choices.
    Either bend the cap, or squash the offending pipe (or cut a bit out of it)
    Avatar supplied by Major Slaughters sister
    Nov 2003
    It's not a good idea to start cutting heatpipes
    Bending or replacing the cap (with another one or at different orientation) might be a good idea.
    Oct 2004
    SC, USA
    Quote Originally Posted by split
    Thanks for that nice pic. I don't want to squash the pipe, as i may want to sell it on ebay anytime later. Which cap are you talking about. Do you mean the MB backplate or some capacitors on it. Did you actually fit XP-120 on your MSI board or what? Please give me more details on the work around if so. Does XP-120 block any of your memory DIMMs?
    ASUS P5B Dlx
    WD Cavier 250GB
    Antec P160
  18. #18
    Memory Addict
    Aug 2002
    Brisbane, Australia
    thanks onepage
  19. #19
    Oct 2004
    Quote Originally Posted by agenda2005
    http://www.zipzoomfly.com/jsp/Produc...uctCode=241143
  20. #20
    Banned
    Jan 2004
    Land of Buckeye
    the reading temp from MSI is ALWAYS wrong.
  21. #21
    Oct 2004
    SC, USA
    Thanks, the temperature reading is a big problem on all S939 MB. ASUS seems to do a better job on this area though. I'm using an AXP-2500+ and the PC probe seems to work pretty good on the ASUS Nforce2 A7N8X-E Deluxe MB.
    ASUS P5B Dlx
    WD Cavier 250GB
    Antec P160
  22. #22
    Xtreme Enthusiast p4z1f1st's Avatar
    Feb 2004
    @ Onepagebook: so, you just want to say, that all "newer" boards are good/better?
    ----- AMD K6-2 300 "Chomper" xxxxx xxxx xxxx /// 300 MHz @ 2,200 V -----
    ----- AMD Athlon XP 1700+ "Thouroghbred B" JIUHB 0306 MPMW /// 2400 MHz @ 1,900 V -----
    ----- AMD Athlon XP-M 2500+ "Barton" AQXEA 0327 UPMW /// 2450 MHz @ 1,850 V -----
    ----- AMD Athlon XP-M 2600+ "Barton" IQYHA 0401 XPMW /// 2500 MHz @ 1,750 V -----
    ----- AMD Athlon 64 3000+ "Newcastle CG" xxxxx 0418 WPMW /// 2600 MHz @ 1,600 V -----
    ----- AMD Athlon 64 3200+ "Winchester D0" xxxxx 0433 SPMW /// 2750 MHz @ 1,616 V -----
    ----- AMD Phenom II X2 555 BE "Callisto" xxxxx xxxx xxxx /// 4080MHz @ 1,375 V -----
    ----- AMD Ryzen "Zen" xxxxx xxxx xxxx /// TBA @ TBA -----
  23. #23
    Xtreme X.I.P.
    Dec 2003
    Cooling : vapo LS
    http://www.e04hardware.com/coolalerb....jpg&#91;/IMG]
    OMG... u just addresed my main worries... so there's still hope for my stock of BH-5 to fly on Neo2/Winnie.... i guess i'll be ordering that combo very very soon, then....
    excellent work on those mushkins... :thumbup:
  24. #24
    Banned
    Jan 2004
    Land of Buckeye
    Quote Originally Posted by bachus_anonym
    No problem, but please note..be aware of that I was using OCZ DDR booster to reach that bench! but you will need kinda hight volt to get that stable like I was running 3d as following shot:
  25. #25
    Xtreme X.I.P.
    Dec 2003
    excellent 3d bench !!! volts is not a problem... on my NF2 Infinity i was showing my BH-5 up to 3.9v with 120mm fan blowing on mems... but that was vdimm taken from 5v rail... Neo2 takes it from 3.3v so having 4v rail is no joke.... maybe i should get a booster to play with as soon as i get Neo2/Winnie...
    thanx for screenies....
