Hi Guys,
im really starting to stress.
i purchased an Abit IS-10 Motherboard. had best specs out of all the mATX s478 motherboards.. however.. has NO overclocking features what so ever.
i downloaded every version of modbin6, version 1.00.38 is the only stable version that opens the bios ok (one i had or latest downlaoded from abit)
going through the setup menu, theres a hidden area called Abit Engineering which has all the freq and voltage adjustments i need to OC.. however
when i try to enable it.. it does no save.
Under a windows environment (on FAT32/FAT16 or NTFS) it saves ok. but the changes arent made.
if i do the mod under either MSDOS or Caldera DOS saving onto FAT or FAT32 i get the error bios.rom cannot be loaded or something like that.
I have tried multiple versions of modbin6 .38, .45, 2.0b, ect.. either dont load or do the same..
Im going crazy
If someone would have the time to take a look the bios can be downloaded here.
ftp.abit.com.tw/pub/download/bios/is10/is1217.exe
Thank you!
