Results 1 to 25 of 32
Thread: My CoolerMaster Stacker inc ThermoChill 120.3
Threaded View
    Nov 2004
    Koh Samui, Thailand
    Thumbs up My CoolerMaster Stacker inc ThermoChill 120.3
    Well this is my first watercooled build, spent about 5 hours Saturday building it, a couple hours of running it to check for leaks and then a night overclocking it!... Still have to fit my NV68, add some dye to the water and a UV light....
    I decided to fit the radiator at the front with the fans inside pulling air through. Unfortunately 3 x Panaflo fans on full blast are very loud so I'm going to remove them and fit 3 Vantec Stealth fans I've got knocking around...
    I loosely fitted the radiator at the front with foam packaging to position it in the right position, then marked out the holes to mount it, drilled them out and used 6 screws to mount the radiatior. I used 6 pieces of plastic piping I cut up to take up the space between radiator and case to stop it moving around.
    Unfortunately with the radiator at the front there's no much space for extra drives etc. I only use 1 Raptor Hard Disk and 1 DVD-R so this is fine for me.
    I mounted a Zalman HD Cooler just behind the fans to fit my Hard Disk - it's right in the flow of air so should keep it nice.
    Going to fit the NV68 tomorrow and other bits and bobs, I'll post a final picture when it's finished. I'm very happy with it, just want to play FarCry now!...
    Tell me what you guys think.
    MORE PICS LOWER DOWN THE POST
ID:	19154   Click image for larger version.
ID:	19155   Click image for larger version.
ID:	19156   Click image for larger version.
ID:	19157   Click image for larger version.
    Intel® Core™ i7-875K @ 4216Mhz For 24/7
    Gigabyte GA-P55-UD6
    2 x 2Gb DDR3 Kingston KHX1600C9D3/2G HyperX
    Thor's Hammer with 2 x 120mm 90CFM Push/Pull
    Asus EAH5970/G/2DIS/2GD5
    5 x WD 500GB RE3 SS'd to 50GB each in RAID-0
    1 x WD 1.5TB RE4 - Storage
    APC Smart-UPS 2200VA
    CoolerMaster Stacker CM690 II Case
    Need Water...
