Page 1 of 7 1234 ... LastLast
Results 1 to 25 of 151
Thread: k-ohashi Pentium-M LN2 is cooling25 second, ID3.3G
    Mar 2004
    Taiwan
    測試配備
    M/B: AOpen i855GMEm-LFS / BIOS: R1.01
    CPU: Pentium M 755 SL7EM/7416A480
    CPU Cooling: LN2
    Chipset Cooling:
    Memory: SanMax BH-5(339WF)B-V 512MB x1
    VGA: GeForce2GTS(AGP)
    HDD: IBM DTLA-307015
    Power Supply: Zippy-460WS
    Vcore: 1.424V
    Vddr: 3.198V, Vio: 3.521V
    OS: Windows Server 2003 Enterprise
    MEM: CL2-5-2-2, 400/266/133/267 MHz設定(3:4)
    edit: DDR-BOOSTER use
    LN2
    3213Mhz run 25s
    CPU 3.3G
    source
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    I see an OCZ DDR booster!
    I need a desktop board...
    Dothan showing some muscle
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Feb 2004
    CeBIT City
    I said it a year ago...
    Athlon pro MHz Power combined with Intels ocing Power = Pentium-M Power :-)
    Pentium-M 1.4
    Kubuntu, KDE 3.x, 2.6.x
    Nov 2003
    Denmark
    Impressive! What would the temperature be @ only 1.4xV? Couldn't you do those volts on high end water / phase change?
    | Pentium-M 730 SL86G 1.60@2.81GHz | ASUS P4P800SE w/ CT-479 | 2x512MB BH-5 | 1M @ 26s | Windows XP SP2 |
    | Athlon64 3000+ E6 LBBWE 0544EPHW | ASRock 939Dual-SATA2 | WinXP and various Linux distros | Currently enjoying:
    Xtreme Christmas Lighter
    Jun 2002
    Upstate NY, USA
    Quote Originally Posted by I²K
    And I've been saying it since I received my 1.5GHz Dothan notebook a few months back. After running a 51s SuperPi at the stock 1.5GHz... you knew these chips would be good if they scaled... and they do.
    May 2004
    Northern Virginia, U.S.A.
    Quote Originally Posted by FUGGER
    I hear the desktop boards should be available in the U.S. fairly soon
    Keep your eyes open and ill do the same...once ive secured one I will pass on the info
    Xtreme X.I.P.
    Nov 2002
    Shipai
    *opens his pentium M adapter folder and starts the pcb design program*
    May 2004
    Quote Originally Posted by saaya
    haha...even better! do you need any venture capital?
    Apr 2003
    Tallinn, Estonia
    i'm wondering if it's doable.. though test-phase needs 478 wires to be soldered
    and i'm wondering what will IC7 think of p-m..
    /me starts dl'ing and comparing p4 and p-m specsheets
    Xtreme X.I.P.
    Nov 2002
    Shipai
    dont need any capital, pcbexpress is sponsoring me i get the pcb for free
    all i need is two dead 478 boards so i can use the sockets for an adapter, thats it...
    and caater, im still looking for a place that can solder the parts together for me, but i think i found a place
    May 2004
    hrmmm do you need the actual pins from the socket as well? I remember ripping apart a bad board once and using the socket as a pin straightener (at the time I had dozens of chips that I needed to straighten for someone...long story).
    Anyway, I know when I ripped the socket from the board the actual contacts remained w/ the pcb...
    lmk
    Apr 2003
    Tallinn, Estonia
    another interesting note - it seems that pci/agp lock is missing? :o
    May 2004
    Quote Originally Posted by caater
    can we focus on the positives here !
    Oct 2004
    have u tried getting support from abit.....
    u would make them and yourself milliones if u could get it to work
    Team Japan
    Nov 2003
    Tokyo, Japan
    Hello, I'm k-ohashi as known as kyosen
    Thanks for your interest to my OC result!
    ...and thanks especially to sxs112 for beginning new threads
    AGP/PCI lock is available on AOpen i855GMEm-LFS!
    I simply want AGP clock for 3DMark etc. and also want to show
    robustness for higher AGP/PCI clock of this motherboard
    I'll try LN2 cooling again...in FSB/mem=3:5mode.
    Apr 2003
    Tallinn, Estonia
    Quote Originally Posted by kyosen
    Oh, nice to see you here.. good job on that mobile
    btw, is dothan more low temperature tolerant than prescott?
    afaik prescott hangs if temp goes lower than ~150C...
    And.. try to get x800 for 2001se goodness
    Xtreme Legend
    Nov 2002
    Sweden
    Is it only me, or does the Dothan scale bad?
    At around 2.5GHz they own A64/FX clock/clock.
    But now, "only" 25 seconds at 3.2GHz.
    (FX 3.35GHz = 24 sec)
    Impressive results! I just hope to see some DC boards coming out.
    "In mild doses, ethylene produces states of euphoria, associated with stimulus
    to the pleasure centres of the human brain."
    Intel benching: 3DMark Vantage: E69642, P37253, H30363, X22138
    Swedish Overclocking Champion 2006 - Celeron Mobile 1400 @ 4243MHz - 203%
  18. #18
    Aug 2004
    Earth->Germany->Soltau
    has that bord a agp pci fix? 119agp and 59pci is to many for the móst pci devices and for the most videocards.
  19. #19
    Team Japan
    Nov 2003
    Tokyo, Japan
    Quote Originally Posted by Denniscooldelux
    Yes, this board has AGP/PCI clock option in its BIOS,
    which is selectable from 66/33, 75.43/37.72, 88.00/44.00,
    and we have to set 75.43/37.72 or 88.00/44.00 for fixing AGP/PCI clock.
    If we choose 66/33 setting, it behaves synchronous in case of using
    AOpen's clock-mod soft.
    Now Mr. abo's SetFSB is also available for modding clock
  20. #20
    Aug 2004
    perfekt. anybody know where to buy dothan for low money? in germany the prices are to high i think.
  21. #21
    Apr 2003
    Tallinn, Estonia
    try eBay.. i've seen 1M p-M's going there for like $50 and 1.5-1.6ghz dothans for ~$150.
    kyosen/k-ohashi, how about a nice max-fsb stress-test?
  22. #22
    Sep 2002
    Milan
    hi kyosen i am waiting for this board and i would like to know if is possible to use 3:5 beyond 133 FSB and if 237/238 is the limit of your ram at 3.2v.
    10x (thanks)
    Ciao
  23. #23
    Jun 2003
    Germany
    would you post a link to this setfsb? i should get the board in a few days.
  24. #24
    May 2004
    Quote Originally Posted by jan
    http://www13.plala.or.jp/setfsb/
  25. #25
    Jun 2003
    Germany
    thx
