Results 1 to 20 of 20
Thread: MYSTERIOUS 3400+, 800 HTT? What's that mean?
    Mar 2004
    Well after purchasing the 939s 3400+ and realizing its the exact same clock speed as the 939 slot 3500+, i did a seach and found out that the only difference is in the HTT bus. It says its limited to 800 HTT, but what does that really mean? Does that mean its just like an Intel 800Mhz Bus? Hopfully this thing is overclockable past 200Mhz... I have some Corsair PC4400 !
    Im switching over to AMD from Intel which is basically why I am confused. If someone has any knowledge of this 3400+ let me know, and can explain this whole Hypertransport thing
    http://www.newegg.com/app/viewProduc...ion=19-103-503
    May 2004
    대한민국 강원도 원주시 Wonju, South Korea
    HyperTransport is kinda like FSB in non-A64 systems. Multiply HTT speed by multi to make CPU clock speed, but if you multiply the HTT speed by the LDT multiplier (usually 2,3,4 or 5) you get the overall HTT speed. The new 3400+ just has a slightly limited overall HTT speed, which probably won't make much of a difference in real-world performance, if it makes a difference at all. However, the weird thing about HTT is that it is used instead of a traditional north bridge. The northbridge and memory controller are located in the CPU itself, instead of in the motherboard, eliminating a major bottleneck. The HTT speed governs how much theoretical bandwidth there is between your CPU and RAM, basically. The difference between an HTT speed of 800 and 1000MHz should not be very evident.
    Any A64 owners out there feel free to correct me if I'm wrong.
    EDIT: Here's a link that will probably explain it better than I did. http://www.ocforums.com/showthread.php?t=306418
    7700k @ 5.0GHz
    ASUS Z170-Deluxe
    2x8GB Avexir Raiden DDR4-3000 15-15-15-35
    Gigabyte Aorus 1080 Ti @ 2076/1500(6000)
    512GB Samsung PM961 + 840 Pro 256GB + some TBs
    Corsair AX1200i
    X-Star DP2710LED @ 110Hz + 40" Samsung TV
    CPU and GPU under water: 9x120 rad + 3x120 + 3x120
    ...and an HTC Vive!
    Mar 2004
    awesome, that explains it. yeah, i dont see how 800HTT from 1000 could create much of a diff. Is there a way to increase HTT through overclocking in any way?
    May 2004
    Yeah, you can change the LDT multiplier in the BIOS or raise HTT speed. You should probably try to keep the HTT overall speed not too much over stock to maintain stability. If you get up into the 250+ range, you'll probably want to knock the LDT multi down to 3 (from 4).
    Ask some people that have tried it, or do some benchmarks yourself and see if there's a difference between higher HTT speeds and lower ones (say, 800MHz and 1000MHz ). Have fun!
    EDIT: Forgot to say that HTT overall speed increases as you overclock the HTT to get a higher CPU clock unless you lower the LDT multi. Confused yet?
    7700k @ 5.0GHz
    ASUS Z170-Deluxe
    Corsair AX1200i
    ...and an HTC Vive!
    May 2004
    Doh! There is a thread with benches at different HTT speeds stickied here! I assume you're slightly more observant than me, but here's the link, anyway. http://www.xtremesystems.org/forums/...ad.php?t=39559
    7700k @ 5.0GHz
    ASUS Z170-Deluxe
    Corsair AX1200i
    ...and an HTC Vive!
    Xtreme Mentor
    Jan 2004
    Berkeley/Stanford, CA, USA
    HTT is set by the chipset isnt it?
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
    Xtreme Mentor
    May 2004
    the cold place Temp: 5C
    Yes, it has nothing to do with the CPU. Even less so than the FSB has to do with the CPU in a Barton based system.
    For those of you about to post:
    Jan 2003
    Littleton, Colorado
    READ
    http://www.xtremeresources.com/forum...ad.php?t=34304
    The S939 3400+ is identical to the 3500+ except it's HT link speed id restricted to 800MHz, instead of 1000MHz.
    Heatware
    Main
    intel i5 3570k @ 4+ GHz | Gigabyte Z77X-UD5H Rev 1.1 |Crucial Ballistix Tactical VLP 2x8GB DDR3-1600
    intel 335 240GB SSD | WD Black 640GB HDD
    Sapphire AMD 7870XT 2GB w-Boost (Tahiti LE)
    Creative X-Fi Titanium PCI-e
    HTPC
    AMD FX 6300 Vishera | ASRock 970 Extreme 3 | Kingston HyperX Black 2x4GB DDR3-1600
    intel 320 120GB SSD | Seagate Barracuda 640GB HDD
    AMD Visiontek HD7850 2GB
    Dlink DWA-556 Wireless N Adapter
    Tablet
    Lenovo IdeaTab A2109 - Running rooted J-Bean & ADW
    Mar 2004
    Thanks guys. Well im not a "stupid" or newbie overclocker but I am to AMD.. just trying to collect as much info as I can before i get my new system
    Xtreme Mentor
    May 2004
    I have run all of my 754 chips well over 1GHz HTT. The officiall speed for the Barton is 166MHz, no one ever runs at that speed either. Even in that thread it shows people running at 255HTT with a 4X multi, that is once agian, above 1GHz.
    Mar 2004
    So... im assuming the HTT spead cannot be affected unless you have an engineering sample. Cool, the benchies in that one thread above deemed negligable results anyways at higher clock speeds. Cant wait to see how far I can go with my Corsair 4400
    Mar 2004
    Actually upon further looking: It seems that HTT is configurable via the bios, atleast with the ABIT AV8.. http://www.hardocp.com/image.html?im...8yMl9sLmdpZg==
    Basically it seems you can overclock it to FSBx5 (1000) but its not "supported" ... thats where overclocking comes in
    Champion
    Jun 2003
    cape town
    so how does it run
    May 2004
    Perth, Western Australia
    yeh, k8t800 pro boards can have 5x ldt multi as can some nf3 250s. but its easier to decrease multi than increase HTV if theres no performance increase
    Quote Originally Posted by bh2k
    sorry m, OI'm a bit drunkz!
    Air benches with 3000+, DFI nf3 and 6800GT 2001SE: 26312 3d03: 13028
    Mar 2004
    Quote Originally Posted by flytek
    so how does it run
    Still waiting to get it newegg shipped today, will get it on Tuesday.
    Nov 2002
    Malaysia
    Do us a favour when you get it can you take a picture of the info on the cpu itself and then a screenshot of CPUID when installed. Some people on other forums still doubt the existence of this cpu!
    May 2004
    Toledo, OH
    Go to this link someone else allready has one and has CPUz screens.
    http://forums.anandtech.com/messagev...yword1=3400%2b
    Current Rig:
    Shuttle XPC SX58J3
    Intel i7-930 @ 3.33ghz
    ATI Radeon 5970
    OCZ Vertex 3 240GB
    12GB DDR3
  18. #18
    Xtreme 3DMark Addict
    Sep 2003
    I noticed no difference in performance and my 3dmarks didnt change one bit with 800 or 1000 HTT so it doesnt matter. However you should have gotten a winchester instead, its 5% faster clock for clock and the 3200+ is cheaper too and overclocks better.
    3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
    9700pro at 325/310 runs all games buttery smooth!
    9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
    9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
    9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
    9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
    3dmark scores with Ti4200 and Ti4800se
    Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
    3dmark scores with older gpus
    Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
  19. #19
    Mar 2004
    meh, i want a soc. 939 processor.
  20. #20
    Mar 2004
    well the winchester is a socket 939 cpu, they are released in lower modells too just like the s754. If I were you i'd get a winchester if you can find it for a good price(depending on where you live course)
