3500+ 90nm:
1.30 oofficial bios:
1.48v
Digital cam shot
so far so good
3500+ 90nm:
1.48v
Digital cam shot
so far so good
holy crap! Is is really stable at that speed with those volts?
For those of you about to post:
what cooling was that used with?
look at the bandwidth! aah, look at the voltage! look at the clock!
cant wait for my fx57![]()
Vapochill LSOriginally Posted by ArcTan
What kind of cooling? And is it really stable?
Edit: Posted 1 second too late.![]()
Bedroom: D201GLY2, Celeron 220 (1.2ghz/512k cache); 1gb DDR2 PC-5300; Geforce 6200 PCI
Gaming: Core 2 Duo E4500@2.93ghz (266x11); Abit IP35-E; 3gb Crucial Ballistix PC5300@400mhz (4-4-4-15); XFX Geforce 8800GS@680/800 10123 3dmark06
HTPC: Athlon 64 X2 BE-2300 (1.9ghz); ECS mATX mb; 2gb Crucial PC5300; Radeon HD2600 Pro 256mb (DXVA HA in BD and HD-DVD)
Originally posted by Thunderbird1Ghz(Geforce4Ti4200) at Sharky Forums
And you arent gonna believe this, but that DVD rom will even read regular CD roms!!!!!!!
can u see how far u can get with the 3500 on air?
thanks![]()
can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
I'm very interested in that as well.Originally Posted by blinky
and me!
don't have k8 cooler for air though...it's has been a long long time ago..![]()
Ohio State??? Go Penn State!!!We suck at football though.
Nice chip.
It is an incredible chip. Someone needs to send him an air cooler so we can find out what it can do.![]()
Onepagebook, what MOBO are you using???
http://www.newegg.com/app/ViewProduc...186-108&depa=0
less than $10
I think he's using the MSI.Originally Posted by The Virus
wow..on an ls...dang 3ghz pretty awsome![]()
nice![]()
All along the watchtower the watchmen watch the eternal return.
uuuuwwweeeeeee![]()
test it @ 1.600V, Kevin![]()
----- AMD K6-2 300 "Chomper" xxxxx xxxx xxxx /// 300 MHz @ 2,200 V -----
----- AMD Athlon XP 1700+ "Thouroghbred B" JIUHB 0306 MPMW /// 2400 MHz @ 1,900 V -----
----- AMD Athlon XP-M 2500+ "Barton" AQXEA 0327 UPMW /// 2450 MHz @ 1,850 V -----
----- AMD Athlon XP-M 2600+ "Barton" IQYHA 0401 XPMW /// 2500 MHz @ 1,750 V -----
----- AMD Athlon 64 3000+ "Newcastle CG" xxxxx 0418 WPMW /// 2600 MHz @ 1,600 V -----
----- AMD Athlon 64 3200+ "Winchester D0" xxxxx 0433 SPMW /// 2750 MHz @ 1,616 V -----
----- AMD Phenom II X2 555 BE "Callisto" xxxxx xxxx xxxx /// 4080MHz @ 1,375 V -----
----- AMD Ryzen "Zen" xxxxx xxxx xxxx /// TBA @ TBA -----
Yeah that is a good chip, my 3200 can only do 2500MHz w/1.55 on water...
Kinda makes me wonder what the cold does with these new chips. It would be nice to see max clocks on air/water/phase on the same chip.
GA-P35-DS3L no more than 450fsb w/1333 chip
E6550 stuck at 3150![]()
V-DATA 2x1gb
MSI 7900GS 512 3Dmark score in near future
Old A64 scores2001 39,707 3D03 23,768 3D05 11,394 3D06 5914
No way. That is just so wrong![]()
I want one![]()
your swim team should be good since you got yuriy from madison HS (he has several NYC High School records)
Originally Posted by Mrk200
Lets say 2800 on air is a good start.....![]()
BTW Onepagebook please try with air if its possible....
We all here want to see what it can do with default vcore @ air![]()
E8400 4400(Q814A015 Wafer **91)@1.296 Vcore
Q6600 (L733B458)@4054 1.5 Vcore
ASUS P5Q Unmoded - 2X2 GB Corsair Dominator 8500
Blaster AUDIGY 2
Sound Blaster Megaworks Speakers 2.1 250D THX / 300 WRMS
ATI 4850 512MB @750/1150 Stock cooling
LG W2600HP-BF 26" Wide TFT Monitor (S-IPS)
System Cooled by ThermalRight Ultra 120 Extreme
System Powered By OCZ 600W
Limits do NOT exist
my 3500+ 90nm seems to be doing very good also. ive got it up to 2.75ghz on air with just a small bump in voltage. time to slap it under the ls![]()
And what happened with the 9nda3+??? just "I will suggest NOT to buy this board..
" and nothing more???????
Shuttle SN95G5
Originally Posted by esoteradactyl
