Page 1 of 2 12 LastLast
Results 1 to 25 of 39
Thread: A64 mobiles rule
    Mar 2004
    Toronto, Ontario Canada
    Thumbs up A64 mobiles rule
    Priming right now @ 36C with SLK-948, 80mm tornado @ 3.3K rpm (very quiet)
    Hoping to run 2.6Ghz+ on water with 1.7v
    Aug 2003
    Somewhere I Belong
    Jul 2004
    Belgium
    Hello,
    It's stable or not ?
    Apr 2004
    Nice, is that with 2T or 1T ???
    I'm asking because i've same mobo but not mobile cpu and i'm doing same clocks as you right now on water with 1.7Vcore but i think i can run it at that speed with less than that, will try later.
    Nice clock for mobile tho, squeeze the bstrd!
    Gluck.
    B
    Mar 2004
    1T CAS 3-3-3-10 with 2x512MB Crucial Ram
    Prime errored after a while @ 1.6v, so I bumped up voltage to 1.65v in BIOS, but it's reading 1.63 actual. So far it's been going for 10 minutes @ 37C
    Apr 2004
    Right... i'm having problem at 1T with my normal Newcastle chip at 1T, can't go more than 210fsb for some reason, i'm using Crcuial Ballistix at CL2.5 3-3-10, u have the same ones?
    What kind of error prime came up with? If it's something like ... error occured 0.499 or 0.5 while expected 0.4 then it's the memory toping out at 1T.
    Cheers,
    B
    Mar 2004
    Ya I think this board has problems running 2x512 double sided sticks beyond 210Mhz. Mine are single sided sticks, regular crucial.
    Apr 2004
    Oh!, thanks for letting me know because i got worried about this...
    I've also tried single channel but same thing.
    Crank up the Vcore to 1.7 and see how ur mobile goes
    Cheers,
    B
    Jan 2004
    This is on your K8NS Pro correct ? What BIOS, etc... did you use to clock up there, a lot of people have had problems with that board and mobiles. I used the K8N Pro of course (see sig) and got similar results. Very nice chips indeed
    Xtreme X.I.P.
    Nov 2002
    Shipai
    sweet!
    congrats!
    Mar 2004
    Quote Originally Posted by LilGator
    Yes it's the K8NS Pro, using F5 BIOS, basically the same as the F4, just newer gigabyte raid BIOS.
    Totally prime stable right now, been running for about an hour. (The 5v reading is fubared, jumps around like crazy for some reason)
    Not bad for a $190 chip
    Xtreme Mentor
    Jan 2004
    Berkeley/Stanford, CA, USA
    whered u get it for $190?
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    wow! 200$? :0
    mobile, 1mb cache ,cg stepping...
    Xtreme Guru
    Jul 2004
    Yeah those chips really like 1.7v. This is on a 9800pro with no mods. 287*9 166 (235 mhz 2-2-2-6 1T) 1.76vcore prime stable
Name:	289x9 real time.JPG
    Mar 2004
    Got it off hardforums
    They go for like $230 new I think, still cheaper than a 3400+ CG, and OC's the same if not better.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    was it a DTR 1.5v chip?
    Aug 2004
    Looks a lot like my chip.
    Attached Images Attached Images
  18. #18
    Mar 2004
    Quote Originally Posted by saaya
    No, DTR chips are just desktop without the IHS. They even get recognized as desktop chips on mobos that support them. Mobiles are different.
  19. #19
    Mar 2004
    Quote Originally Posted by Dmytry
    That is a 512K L2 cache Newcastle chip, nice try
  20. #20
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    That is my mobile chip, I sold it to him for that amazing price.
    Glad to see it performing like I hoped it would.
    Formerly XIP, now just P.
  21. #21
    Xtreme X.I.P.
    Nov 2002
    Shipai
    so where do i get a REAL mobile?
  22. #22
    Mar 2004
    Quote Originally Posted by EnJoY
    What speed/voltage is your 3400+ CG running? What about the ram? What voltage?
  23. #23
    Aug 2004
    Quote Originally Posted by HKPolice
    It's a Clawhammer with 1/2 it's cache disabled. It's a gimped hammer.
  24. #24
    Aug 2004
    HkPolice dont supose you can post your FULL stepping code on that chip , seen a mobile for sale in UK, stated as Mobile but according to Athlon64 coding its DTR (AMA)
    Cheers Jeff
    DFI Ultra-D
    X2 3800 Toledo 290x10 (1.39v) (not tweaked yet)
    2x 1GB Ballistix
    Sapphire X1950 256
    Seagate Barracuda 7200.9
    OCZPowerstream 520
    Custom water cooled
  25. #25
    Xtreme Guru
    Jul 2004
    Mine does 2.58 stable with good water. I can 3d bench at 1.65, but not prime 95. How far will your go with 1.75v?
    Yours must be the same as mine, 62w clawhammer. runs on 1.4v. but really needs that 1.7v+ to take off.
