Finishing up 2 containers for LN2
The GPU container:
Unfortunately, the immense mass of the container made it very difficult for every part to be hot enough for the filler metal to flow evenly, especially so since brazing on the stove is not very possible. I just discovered a very slight leak. Will patch up with silicone and have a catch below so that if any LN2 trickles down it should evaporate pretty quickly on the catch.
The CPU container...
Need to catch a good source for LN2 then its party time!![]()
