Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 107
Thread: Three Stage Cascade
    HVAC/R Engineer
    Nov 2003
    Three Stage Cascade
    The beginnings of a beautiful thing... -150C
    Aug 2004
    looks real nice good luck
    2500M @ 2875 mhz 250 x 11.5
    2-2-2-11 Mushkin Black Level 1 @ 3.3v
    9800 pro w/ removed shim 490 core/407 mem w/ modded vga silencer
    DFI Infinity NFII
    Lian Li Pc-65B
    Samsung 710T(no ghosting!)
    3dmark2k1 = 23109
    3dmark2k3 = 7842
    Prometeia mach 1
    Feb 2004
    Tucson, Az, USA
    I never get tired of looking at system pics. Its amazing what people can build in their spare time.
    Jul 2003
    Finland
    What size capline you use from the valve to the evap? Looks sooouu nice A Pro is always a Pro no mater what, and it raly is visible in this sytem.
    cool cool cool!
    HVAC/R Engineer
    Nov 2003
    The tubing supplying the refrigerant to the evap is a 0.060 ID tube the metering device is the PEV which in this case will regulate the input pressure into the tube...
    Mar 2004
    So-Cal
    looks realy nice! btw what kind of brazeing rods do you use?
    HVAC/R Engineer
    Nov 2003
    Quote Originally Posted by JSU
    On the block I use 56% silver solder and on teh copper to copper I use 15% silver brazing alloy. With teh 56% you must use a floride paste flux with simmilar melt point to the solder. For teh 15% no flux is nessassary.
    Dec 2003
    Austria
    This looks very very good!
    It is a bad idea to take copper/phosphor brazing rods? Because I can get 5 c/p rods for the same price as for one silver rod
    XS Local
    Dec 2001
    Close to Neweggs New RMA Center, CA
    Looks Neat. Wish i had one or 2 of those laying around.
    Opteron 175 Dual Core CCBWE 0544XPMW @2.3ghz 1.41v
    DFI SLI-DR Expert 11-25 Bios
    G-Skill 1gb GH UTT @210 2-2-2-5
    BFG 7800GT OC 485/1170 NV 5rev3
    74gb Raptor 300gb Maxtor 500gb Hitachi
    OCZ 520w SLI 3.46v 5.16v 12.64v
    Thermaltake CL-P0114 Big Typhoon
    3dmark01 3dmark05
    Heatware
    Apr 2004
    Herning, Denmark
    not bad, chilly
    will it be r507, r1150, and then methane??
    -100C Club Member
    Feb 2004
    australia
    do you remember care50 post a few weeks back
    r290 50% ethane for -50c at 1 atompshere and lower pressure than r410a
    i recond if you got some ethane and played around a little could get a really cold first stage going
    Jul 2003
    Finland
    Phosphorous copper is good for copper to copper joints and dont need flux. Easy to use and cheap. With propper Silver rods you can braze almoste anything (exept aluminum) and you can get the rods that are covered with flux so no need for manual fluxing. Propper silversolder costs helluva lot but you realy don't need it unless you solder stainles to copper etc.
    cool cool cool!
    HVAC/R Engineer
    Nov 2003
    Quote Originally Posted by SlackeR
    not bad, chilly
    First stage R507, Second R1150 + 2 oz R12, Third R50 +25% R740 + 2 oz Ethlyene + 2 oz R12, This will be the first Range of refrigerant I will try. I am going with R12 instead of propane because of its misicibility with the oil.
    Admin
    Mar 2003
    North Texas
    1. How do u measure 2 oz?
    2. What the heck is R740 and why are u using it?
    3. How are you going to add 25%?
    UNDER THE ICE .com
    Phase Change Cooling
    is the remedy
    Xtreme Mentor
    May 2004
    the cold place Temp: 5C
    2. R740 is argon, it has a boiling point of -182C.
    For those of you about to post:
    HVAC/R Engineer
    Nov 2003
    Argon= R740 instrument grade, R50= Methane CP grade, R 290= Propane instrument grade.. Instrument grade is 99.997% pure , CP grade is 99.95% pure, My propane does not small (No mercaptian)
    Here to help
    Nov 2002
    Are those plate HX's expensive?
    And is the schematic for that 3 stage in your cascade drawings thread?
    Cant wait to get some numbers on that beauty when you fire her up
    Regards
    John.
  18. #18
    HVAC/R Engineer
    Nov 2003
    This is my three stage design. There are a few things in the block not shown... But basically thats it. Plate HX's of this size (originally for a 1/2 ton chiller) are 195 US plus shipping. This is my first cascade with plate HX's..
  19. #19
    HVAC/R Engineer
    Nov 2003
    Thumbs down Rethinking design..
    Update.The Argon needs a colder condensing temp (-130) to operate properly at load. The methane needs -100C to condense, On first run we found we had a dead first stage compressor, changed and restarted, third stage compressor started and hammered then tripped the breaker, Bent rod or broken poiston "Hammered it to 600 PSI" Danfoss compressors destroy them selves at 600+ psi. Changed this compressor charged third with ethlyene temps down to -112C on block... First at top of HX (outlet) -20C second HX (outlet) -70C Minimum for operation with methane is -95C , Working on it, I will post the answers asap... Probably remove the HX's and redesign the interstsage... Need more capacity. Maybe move up to a 2 hp for first and a 1hp for second. Tried a few blends only more of the same Temps stay the same but pressure rises with blend,, no Gains, Blew up a capacitor, dont stand over a start cap on a system.. Covered in Oil from the cap,,, More to follow...
  20. #20
    Oct 2003
    USA /okla
    ouch well atleast you are making some progress and gathering info.
    you guys sure live on the razors edge
    ***OT***
    here after awhile when money if gathered and wife won't notice I will be contacting you via PMs on a nice -60+ single stage setup.
    i7 6700K @4.8 ghz
    XSPC RayStorm (very nice block)
    Z170 Sabertooh ,, 32GB- Gskill (15-15-15-36 @3600 mhz) 1:1
    XFX-7970 with Swiftech Komodo nickel block
    Water Cooling - MO-RA3 Pro with 4 Silverstone 180mm @ 700 rpm, Twin Vario mcp-655 pumps
    Samsung 850-1TB SSD,, OCZ ZX-1250W (powerfull and silent)
    Crossfire 30" decent monitor for IPS too bad SED tech died
    Docsis2.0 Docsis3.0
    -- People who reject the idea that "government has a responsibility to reduce income inequality" give an average of four times more than people who accept that proposition.
  21. #21
    Freezer Racer
    Sep 2003
    la,ca
    Anything over 2 stages requires some seriouse thought. Designing a system so that interstage temperatures are just enough to condense the next stage is foolish. You always need to alow plenty of room for error. When designing a 3+ stage system I will always be sure my 1st stage is nearly twice the size of my second. If designing a 4 stage, use the same logic... like Biggest, bigger, big, 4th stage. lol get me? Also an excellent way to minimize interstage loads is to pipe a completely seperate condenser with a fan, as a desuperheater. Use say, the first 5 or 6 loops to desuperheat the 1 stage. then the next 4 or 5 for the second desuperheater and so on. This will allow the bulk of the heat from each stage to be blown off prior to entering the interstage. This minimizes the desuperheaters physical space, while maximizing surface area.
    C.C.
    If i was an animal Id be a freezer.
  22. #22
  23. #23
    HVAC/R Engineer
    Nov 2003
    Captain Long time no see, I am close to being able to condense methane the bottom of the HX (brazed plate) was -95C. The Metering device is an expermential valve from sporlan, The first compressor I had was 2X times the second but it was a DOA. I used a 1 hp R22 in its place and My condenser is a little small, I am instaling a larger one. Also I need to install a larger second stage air coil before the oil seperator, The discharge temp of the second stage was 215F which is about the limit of the compressor I had there, THe Third stage compressor has the same displacment as the second but with methane the BTU that it will dissipate is nearly half that of the previous stage. So With a few tweaks it should work...With methane.
  24. #24
    Here to help
    Nov 2002
    Are you thinking a fourth stage may be required to condense the Argon? I dont know if you can get plate HX's that have 3 routes, can take three gases in seperate paths. Hope that makes sense. You could maybe run the discharge from the fourth stage and route it through all the HX's then.
    That way the first two HX's would desuperheat the argon at it could then condense in the third? Probably damn expensive though, even if such a thing exists
    Regards
    John.
  25. #25
    HVAC/R Engineer
    Nov 2003
    Quote Originally Posted by pythagoras
    Regards
    John.
    I am a little dissapointed at the preformance of the Plates but I can work with them. I did a few calculations on the enthalpy and critical temperatures of argon and we will need -140C to condense it at anywhere near resonable pressures.
