08-30-2004, 05:26 PM
#1
X.I.P.
Complete A64 Memory Divider Table
Ps : It may not be 100% correct
08-30-2004, 05:29 PM
#2
umm... ok...
cool
__________________
08-30-2004, 05:39 PM
#3
Dats Really Cold
Thanks Oskar, nice bit of info :thumbsup:
09-06-2004, 03:07 AM
#4
X.I.P.
Re: Complete A64 Memory Divider Table
Any problem from this table ?
09-06-2004, 07:45 AM
#5
Nice to see you again OSKAR. This will come in useful for my yuletide A64 system.
__________________
09-06-2004, 01:55 PM
#6
X.I.P.
Better off presenting a table of memory dividers.
125 MHz is actually 117 MHz AFAIK
No idea about the 143 MHz setting.
in goes in steps of 1/12
09-06-2004, 06:12 PM
#7
X.I.P.
I think you know DRAM frequency we set in A64 register is " Upper limit " of DRAM speed ...
A64 memory controller will automatically choose a smallest interger divider(>4) to generate the DRAM clock from Core Frequency , and the DRAM clock will not be faster than the uppder limit ...
Using an oscilloscope and check all the multiplier from 4~12 with the same register setting in A64 ...
What I got are 200/183/166/150/143/125/100 may be the upper limit of DRAM speed when you set correspoding register setting in A64 ...
Here is the divider table I got after using an oscilloscope to check the possible upper limit of DRAM clock ...
What I can not be sure is the exact frequency besides 200/166.67/133.34/100 ...
09-06-2004, 08:51 PM
#8
Dragon Family
wow....
09-13-2004, 07:22 PM
#9
That looks nice, but since I do not have an A64 yet can you please explain the chart. Memory speed, HTT setting , CPU ratio etc....
__________________
Abit NF7-S V 2.0
AMD XP 2500+ @ 2300+Mhz
2x256 Twinmos (DC) BH-5
WD 80 GB w/8MB Cache
XFX Ti 4200-- 128MB
Windows 2k Pro
CPU watercooled by Flowmaster
09-15-2004, 04:40 AM
#10
XS Local
Tagged..
__________________
Opteron 175 Dual Core CCBWE 0544XPMW @2.3ghz 1.41v
DFI SLI-DR Expert 11-25 Bios
G-Skill 1gb GH UTT @210 2-2-2-5
BFG 7800GT OC 485/1170 NV 5rev3
74gb Raptor 300gb Maxtor 500gb Hitachi
OCZ 520w SLI 3.46v 5.16v 12.64v
Thermaltake CL-P0114 Big Typhoon
3dmark01 3dmark05
Heatware
10-16-2004, 02:25 PM
#11
Sorry, but I need to ask the obvious question...
Any way you can find out or tell us what happens to the RAM Divider for DRAM Freq. over 200 in BIOS? For example, if I use DRAM Freq. 225, 250, 275 or 300?
Thank you for any information you can provide, and furthermore, thank you so much for your efforts, Oskar. Your LP nF3 is a true marvel of modern engineering!
-Ed
__________________
-Edward Ng, SPCR Reviewer
10-16-2004, 02:56 PM
#12
Xtreme Guru
You can't use a devidor less than your multiplier.
__________________
For those of you about to post:
10-16-2004, 04:51 PM
#13
Okay, suddenly I understand...
I was thinking of the LDT setting, not the RAM ratio.
Gotcha'; thanx.
__________________
10-17-2004, 08:26 AM
#14
Xtreme X.I.P.
Originally Posted by tictac
wow....
ditto!
thx a lot oskar!
__________________
Nvidia: Tesla C2050 and C2070 products (GT300) will retail for $2,499 and $3,999
JHH (Nvidia) sep 2009: The best way to always be the number1 is to have no backup plan link
JHH (Nvidia) nov 2009: Tolerance for failure is important, it puts our employees in a position where they are willing to try new ideas link
Solus Corvus - maybe things would get better if people addressed the content of each others posts instead of trying to discredit each other with insults and poisoning the well. Attack the argument not the person.
Hail Voltage! The Solution to AND Source of all our Hardware Problems
10-17-2004, 08:30 AM
#15
Xtreme Guru
Yeah, I love this divider table.
__________________
11-02-2004, 04:13 PM
#16
where did the divider table go? Can someone post it again?
__________________
Asus G60VX : Intel P7450@2.53GHZ : Nvidia GTX260M @ 575/975/1400
Iraq Veteran OIF 2008
11-02-2004, 04:57 PM
#17
*.png8 139KB & 155KB
__________________
learn A.K.A JP
11-02-2004, 05:26 PM
#18
it simpler if u don want to remember tables.
u multiply the (HTT/ram) ratio -inverse of ram:htt ratio in the bioses- with the
cpu multiplier , and u aproximate to its closer bigger integer.that's ur memory divider,then u divide ur cpu mhz by this divider..
example if multi is 8 ,HTT=240(=>cpu=1920MHZ) and divider "ram:htt" is 5:6 , u multiply 8*(6/5)=9.6 , then approximate to the bigger closer integer =.. 10 and divide the cpu clock by ths number ...=> ram clock is 1920/10=192mhz
of course if u choose a half multi , the bios "approximates" it to the closest integer(bigger)
11-08-2004, 03:54 AM
#19
Wow, that IS a lot simpler.
__________________
Athlon 64 90nm 3500+ 2.6Ghz @ 1.45v
Coolermaster Hyper 6 & Stock Fan
MSI K8N Neo2 939
ATI X800XT AGP (stock)
512Mb Twinmos CL2.5 RAM + 512Mb KHX PC3000 BH5
160Gb Maxtor 8Mb Cache x 2
Pioneer 108 16xDVD+/-R 4xDL
Fortron 520W
Tsunami Dream Black Dual 120mm
SamsungX05
Centrino 1.5Ghz
768Mb RAM
30Gb HDD
DVD/CDRW
11-08-2004, 11:26 AM
#20
Location: Savannah, GA. The continually less "United" States of America.
New guy wants to look good...
I'm new here and to OCing... but I have a theory about pushing the Hz and Voltage on the system:
I think that these tables indicate it off the bat, but what I imagine is that it really helps to keep the frequencies in as efficient a synch rate as possible...
Looks like... a 4Ghz system would be most stable if one were to use RAM of as compatable a frequency... something like 400Mhz
That way, the clock pulses have a pretty good chance of interlacing properly.
From what I understand, AMD's FSB controls the RAM directly from the CPU, so it would make sense then to make sure that you can run compatible RAM. Seems like the system would be better of say at 4Ghz then at 4.1 with 400mhz ram in terms of stability.
Now Raw speed... that's another thing
Just an idea, I really have no expertise on this.
BS?
11-11-2004, 12:53 PM
#21
oskar, or somebody else:
could you tell me the "interval" with which you calculated that all?
because, i want to extend the table with clocks like 217/233/250/266/275/283/300MHz
11-12-2004, 03:07 AM
#22
ok, got it:
multiplier * your wanted FSB(HTT)-clock / wished divider (f.e. - 166 for the 6:5-divider or 133 for the 3:2-divider and so on) = a real-count
you have to "up-round" the result - so, if it's 13,2 you have to say, it's 14 - if 12,6 it's 13, if 12,1 it's 13, too
so, then:
CPU-Clock / result of the first calculation = REAL RAM-CLOCK
one full example:
13 * 200 / 166 = 15,66 ---> = 16
2600 / 16 = 162,5MHz
11-14-2004, 02:01 AM
#23
Xtreme X.I.P.
isnt it funny that it goes to 5ghz cpu speed but only 200mhz memory speed? ^^
__________________
11-14-2004, 07:05 AM
#24
i have some ''objections'' tο the above table
it needs to be clear enough, what exact every ratio is,e.g. 166/200=5/6 , but for the not common ones (183,143) , is more ..misty
the 183/200 what should be? 183.3333333/200 which means 11/12 ??? ,should be 9/10 as dfi says in the bios??? , or 10/11 ???
From the table , we can find some multis that are in the ''edge'' to change for different ratios (9/10, 10/11, 11/12) so the rounding could be different ,and IF , we assume the table is correct we might find the right one.
--from now on will be LONg post
for 10x multi(CPU) 10/9 gives 11,1111-> 12x ram multi
11/10 gives 11 -> 11x
12/11 gives 10.9-> 11x
for 19x , 10/9 =21.1111-> 22x
11/10=20.9 -> 21x
12/11=20.73->21x
for 20x , 10/9=22.2 ->23x
11/10=22->22x
12/11=21.81->22x
for 21x , 10/9 =23.3->24x
11/10=23.1->24x
12/11=22.9->23x
for 22x , 10/9=24.4->25x
11/10=24.2->25x
12/11=24->24x
so.. from the table and the calculated ram mlutis (for cpu 10x,19x,20x) we can easily see, that the 10/9 is unacceptable, so 11/10 or 12/11
but...for 21x multi =4200MHZ clock , for 183mhz ram setting ,the table says 182.61MHZ =..23x ram multi as for 11/12 ratio
and for 22x =4400mhz >> , >> 176mhz, as for 11/10 ratio..!!?? whats happens here??of course IMO , the correct ratio is 11/12 as for 183.33333333/200
doing the same thoughts in propotion for the 143mhz divider , i think -and seems to be confirmed the 5/7 ratio ,
2 more observations.. :
1)all the mem dividers for half multi dividers, are ''calculated"-oscilloscoped from the above table, like the half multis do exist, but... we all think that they are just a trick to give more flexibility.example from the table : 6.5x cpu multi , 5/6 ratio (should be =rounded to 7*1.2=8.4=..9x ram multi) ,but it gives 6.5x1.2=7.8=..8x ram ratio.Also note that for 1:1 setting the half multis are normally up-rounded .. so may that mean that the half multis DO EXIST when not using 1:1 htt:ram setting???
2) the cpu multies <5x seems to be emulated using 5x multi , as a consequense the 4x multi 1:1 gives only 160mhz!!
11-21-2004, 08:21 PM
#25
Dragon Family
0.5multi bug....
Oskar wu can you fix it?
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
