XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 06-12-2004, 01:02 PM   #1
All Kill3r
Air Cooled Gallery
The other cooling forums have their own galleries. Why doesn't the air cooling forum have one ? I say we start it up Air cooling doesn't mean you can't be extreme
__________________
HEATWARE
All Kill3r is offline   Reply With Quote
Old 06-12-2004, 01:03 PM   #2
All Kill3r
post em up fellas
__________________
HEATWARE
Old 06-12-2004, 01:30 PM   #3
SuperDude
SuperDude's Avatar
Send a message via AIM to SuperDude
How do you upload imagse thru the forums? If not whos a good host i can use?
*sigh* my mom took her digi cam with her today, ill get pics up tommorrow
SuperDude is offline   Reply With Quote
Old 06-12-2004, 02:11 PM   #4
All Kill3r
when you make a post, theres an attach file button down there below the smiley box.. click browse and select the pic, must be gif, jpg, png, txt, zip, bmp, jpeg, or doc no bigger then 204800 bytes
__________________
HEATWARE
Old 06-13-2004, 12:39 AM   #5
SuperDude
SuperDude's Avatar
hrmm, says i may not post attatchments.....
Old 06-13-2004, 05:26 AM   #6
craig588
Xtreme Guru
craig588's Avatar
Send a message via AIM to craig588 Send a message via MSN to craig588
It works for me.
Thats a 120x38MM 1amp fan. Its not even too loud. The HS is a heavily modded VGA silencer.
__________________
For those of you about to post:
craig588 is offline   Reply With Quote
Old 06-13-2004, 06:18 PM   #7
FireDragon
FireDragon's Avatar
Send a message via AIM to FireDragon
craig what did you do to the VGA?
__________________
http://smbach.com/mad.gif
Opty 175 Rig
Lian-Li PC75B case, Thermaltake BT w/ 165 CFM delta fan, Enermax 550watt PSU (36A on 12+), x1950 Pro, DFI Lanparty NForce 4 Ultra-d (moded for SLI so that i can use the second slot at 8x), Opteron 175 CCBWE 0547 TMPW (2.80, 280x10, 1.5 volts), 2x1gb Mushkin Redline xp4000 (280 3-3-2-8, 2.65 volts), 80GB WD
AM3 Rig
Lian-Li PC-75b case, Asus Crosshair III Formula, 965 x4 C3 @ 4.1 1.525 volts 2.8 NB 1.25 volts, 2x2gb Dominator GT Cas 8 2000Mhz@ 1720 6-6-5-18-22 1.725 volts, Asus 5770 VT @1010/1435, Seasonic 850watt PSU 2x12v rails 40 amps each, 36GB raptor boot drive, 80GB WD storage drive, HeatKiller LT cpu block, BI GTX 360 with 6x Scythe 3000RPM fans in push/pull, MCP 655 variable pump on setting 5, EK 150ml res, all 1/2 inch
DFI NF4 BIOS Guide
FireDragon is offline   Reply With Quote
Old 06-14-2004, 06:53 AM   #8
comment
comment's Avatar
Send a message via Skype™ to comment
Does this Radeon 9800 Pro air cooling mod qualify for the Xtreme Air Cooling label?
__________________
  • DFI LANParty LT X38-T2R Rev. AA1
  • Core 2 Duo E8500 @ 4009MHz, 1.31V
  • TRUE @ 2x Scythe S-Flex SFF21F, 5V
  • 4 x 2GB G.Skill Pi PC2-8800
  • MSI R4870X2-T2D2G-OC
  • 3x 74GB Raptor ICH9R Raid0 @ 128KB Stripe Size
  • Plextor PX-716SA/T3KB DVD-RW
  • Auzen X-Fi Prelude @ TI OPA637AU - Thule - Dali/Ultimate Ears - Argento
  • SilverStone OP700
  • CM Stacker 830 Evo
  • Eizo FlexScan HD2441W - Audioquest DV-X
  • WinVista Ultimate 64bit SP1
comment is offline   Reply With Quote
Old 06-14-2004, 07:36 AM   #9
Pimp!
im speechless ...
__________________
msi k8n neo2 plat
3200+ winchester (10x262)
bfg 6800gt
pdp pc3200 xbl
thermalright xp-90 w/7v tornado 92mm
Pimp! is offline   Reply With Quote
Old 06-14-2004, 11:43 PM   #10
Mini
Mini's Avatar
http://www.mainboard.dk/upload/files/DSCF0025.JPG
Darn comment... Looks insane... I only need to Vmodd mine... Thkin of gettin Revoltec Heastsinks for my gfx ram...
Just need to clench my butt cheeks and get it over with...
__________________
P4 3.0C 800@3.64 242FSB 1.625Vcore on Ic7 max3(Watercooled)
Corsair 2x512@DDR484Mhz PC4000( 3-4-4-8 )2.8V
X800XT@586/594(Watercooled)
3*Maxtor 120 GB fluid +9 SATA RAID-0
3Dmark01: 25250--Aquamark3: 66423--3Dmark03: 13780--3dmark05: 6361
Mini is offline   Reply With Quote
Old 06-15-2004, 12:17 AM   #11
comment
comment's Avatar
Cool mod Mini :thumbsup:
I was thinking about using one of the big SLK's for the core too, but settled for the smaller SLK600 as I wanted to make some HUGE sinks for the BGA's. Seeing your mod I might reconsider the mod though - xtreme is never xtreme enough
Btw: Why aren't you using two fans on top of that SLK900U
__________________
  • SilverStone OP700
Old 06-19-2004, 04:17 PM   #12
TM30
TM30's Avatar
Really Huge Coolermaster Hyper 6 Heatpipe with two YS Tech w. poti
TM30 is offline   Reply With Quote
Old 06-20-2004, 12:06 AM   #13
Jupiler
Administrator
Jupiler's Avatar
Good idea, All Kill3r.
I'll sticky this one.
__________________
Rig #1
Gigabyte UD3P Rev. 1.0 Bios F4
E8600 @ 4400Mhz, 1.296V
2x2Gb OCZ1066 LV Blade
BFG GTX280 OC
Coba Nitrox 750W
Watercooled with HK 3.0 CU, EK-FC280GTX, PA120.3, Laing Ultra with XSPC top
Rig #2
DFI UT P35-T2R (0317 bios)
E8200 @ 4000 (1.216V) / 4100 (1.248V) / 4200 (1.296V) / 4300 (1.344V)
2x2Gb Chaintech Apogee GT PC2-8500
Powercolor 4870
Corsair 520HX
Watercooled with HK 3.0 CU, EK-FC4870, Feser tripple, Laing Ultra pump
Originally Posted by Movieman View Post
I've got Supermicro boards that lasted longer than one of my marriages!
Jupiler is offline   Reply With Quote
Old 06-20-2004, 09:59 AM   #14
Kameleon
Kameleon's Avatar
The Hyper 6 is a nice heatsink, isn't it? Here's a crappy phonecam pic of my work in progress mod of it on my 9800 Pro
It'll probably end up with 2 Tornados in push-pull, it all hinges on whether the AGP extender I'm getting will run the card alright, as otherwise I'd need to dremel out my PCI slots for the cooler to fit centrally on the core Need to chop up some huge BGA sinks for it too, the current ones are abysmal, and the new ones aren't big enough for my liking - turned two of these, i865 NB sinks...
...into eight of these
Pics of the complete card when finished
__________________
"Can anyone tell me the best way to find out what the ludicrously named
'System Idle Process' is actually doing? I can guarantee it's going to take
up 95% of processor resources, just when I'm in the middle of something
important."
- god i love the internet
Kameleon is offline   Reply With Quote
Old 06-20-2004, 11:12 AM   #15
TM30
TM30's Avatar
OMFG!
will you install the vga normally ? i mean... 1KG copper
Old 06-20-2004, 11:19 AM   #16
Kameleon
Kameleon's Avatar
Originally posted by TM30
OMFG!
Well it's not going in a case, I can tell you that for free The weight would shear the card in half. It'll just be a motherboard-sitting-on-box job like it is now, with the cooler resting on the PCI slots. I've had to buy an AGP extender too, which will make the board even less portable Expect some sort of ghetto mod like Coke bottle caps to hold the cooler up off the PCI slots as with the extender in there'll be a bit of a gap between it and the board. HaLDoL just broke Stang's aircooled XP record, I'd like to shoot for that if at all possible
__________________
important."
Old 06-20-2004, 12:11 PM   #17
All Kill3r
damn nice ramsinks there m8
__________________
HEATWARE
Old 06-20-2004, 12:44 PM   #18
comment
comment's Avatar
Yeah, nice work on the BGA sinks Kameleon
__________________
  • SilverStone OP700
Old 06-20-2004, 01:13 PM   #19
Kameleon
Kameleon's Avatar
Thanks guys - yours are pretty godlike too, LOL Anyone got any quick suggestions as to what would be relatively safe to push the voltages to with this cooling? I'm also thinking of trying to get something for the backside of the GPU but I have no idea how I'd buffer it from crushing the SMD resistors...
__________________
important."
Old 06-20-2004, 08:16 PM   #20
dalek
What did you do to that video card? Have you ever had it to run hot by any chance?
I just had to ask.
Yep, first post. Noobie over here, well to here anyway.
__________________
My rig: ABIT NF7 mobo || AMD 2500+ 333 FSB || Volcano 11 CPU cooler
1Gb Kingston Memory || Chaintec fx 5200 128Mb Video Card || Gateway EV910 19" monitor
Actiontec external modem || HP Deskjet 3820 printer
LG GCE-8520B CD R/W || WD 80GB and Maxtor 30Gb HD || Cyberpower 1250AVR UPS
Foxconn 7A090-043 Full Tower Case ( with 4 Thermaltake Smart II and one P/S fan installed)
Gentoo 1.4 | Mandrake 9.1 NO WINDOZE HERE
dalek is offline   Reply With Quote
Old 06-21-2004, 01:42 AM   #21
comment
comment's Avatar
I've been told that the max voltage on the core is about 2.0V and on the mem 3.20-3.40V. For record benching you could go 2.10V on the core and 3.4-3.5V on the mem. Mine is fed 1.96V on the core and 3.08V on the mem on a daily basis.
As to the back of the GPU, I made a sink for my old GF 4 Ti 4200 that fit right in the middle of the core where there's no risistors. Mounted it with thermal tape. Meassures: 30x30x25mm (LxWxH). What you do is to cut away some of the base without resizing the overall deminsions of the base. The result should be a sink with app. 10x10mm contact surface that fits in the middle of the core back with a bigger overall base size of 30x30mm. I haven't got any pic's but I hope the description makes sense to you.
I haven't been able to do that mod to my R9800Pro due to the Swiftech MCX159-R sitting on my northbridge.
Good luck
__________________
  • SilverStone OP700
Old 06-21-2004, 01:43 AM   #22
comment
comment's Avatar
I just had to ask.
Welcome to the madness
You can rest assured that the card runs hot when gaming a few hours
__________________
  • SilverStone OP700
Old 06-23-2004, 03:35 PM   #23
K32A
K32A's Avatar
Send a message via MSN to K32A
Well..
This is my Soltek Barebone...
I have mounted a Zally CNPS7000A-Cu on my A64....
I still need some Vmods on the mobo, cause i can only give the CPU 1.55vcore and 2.8vdimm, and thats just NOT enough for me
I want to overclock this bastard
So rigth now its just running stock-speed (Pretty Xtreme, huh ) and i cant live with that
Another pic...
__________________
Shuttle SN95G5 V2
AMD Athlon64 3000+ Winchester @ 2430MHz, 1.47vcore
Club3D X800Pro 256MB
1GB Kingston Value PC3200 @ 221MHz, 3-3-8-3, 2.7v
200GB Maxtor DiamondMax 10
NEC 3500A DVD±RW
Acer AL1715 17" TFT
K32A is offline   Reply With Quote
Old 06-24-2004, 07:05 PM   #24
cheece2001
Send a message via MSN to cheece2001 Send a message via Yahoo to cheece2001
these are some of my pics. sory about the size.
cheece2001 is offline   Reply With Quote
Old 07-06-2004, 10:29 AM   #25
dcpusher
I just need a host for the pics.
__________________
dcpusher is offline   Reply With Quote
Reply
Tags
air cooling
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
