XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 05-15-2004, 01:45 PM   #1
chilly1
HVAC/R Engineer
chilly1's Avatar
Cascade Drawings........
Adjustable Version and High heat load Version
Capillary Tube Version
The infamous tristage
chilly1 is offline   Reply With Quote
Old 05-15-2004, 02:07 PM   #2
blinky
Xtreme Mentor
blinky's Avatar
Send a message via AIM to blinky
nice pics chilly!
__________________
can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
blinky is offline   Reply With Quote
Old 05-15-2004, 03:51 PM   #3
chilly1
HVAC/R Engineer
chilly1's Avatar
Retawi@cox.net my addy.... got anything you need... working ona website
__________________
heatware
Old 05-16-2004, 11:42 AM   #4
afireinside
I am Xtreme
afireinside's Avatar
Send a message via AIM to afireinside Send a message via MSN to afireinside
Nice Could you lable the second one with all the parts though?
__________________
Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
3740mhz CPU 2400mhz NB | DDR1020 5-5-5-15 | 900/1250
afireinside is offline   Reply With Quote
Old 05-16-2004, 12:16 PM   #5
Pandrone
If you look at the first picture you can lurk it out what components the second cascade uses. If you don't know what those parts are you obviously shouldn't be into cascades. (bad english)
Pandrone is offline   Reply With Quote
Old 05-16-2004, 05:19 PM   #6
afireinside
I am Xtreme
I'm to lazy
Wth is a subcooler?
__________________
Old 05-16-2004, 05:42 PM   #7
chilly1
HVAC/R Engineer
chilly1's Avatar
A subcooler is an HX used for lowering the temperature of the liquidline and raising the temperature of the suctionline in other words cooling the superheated gas/liquid in the liquid line..
Used to make the system more effecient.
I edited the posts for the desuperheater that is actually a device that is connect after the compressor to desuperheat the discharge gas from the compressor..
__________________
heatware
Old 05-16-2004, 05:43 PM   #8
chilly1
HVAC/R Engineer
chilly1's Avatar
Originally posted by blinky
nice pics chilly!
I drew these in autocad and colored them in photoshop..
Old 05-16-2004, 10:32 PM   #9
Gary Lloyd
X.I.P.
Gary Lloyd's Avatar
What you are describing is a subcooler. A desuperheater lowers superheat, which this does not. This in fact adds superheat to the suction vapor. The vapor/liquid mixture in the liquid line is subcooled, not superheated.
Thx Gary missed the error...
__________________
Author - Refrigeration Trouble Shooting Books
Want to learn more? Click Here
Gary Lloyd is offline   Reply With Quote
Old 05-17-2004, 01:58 AM   #10
PhyberOptik
you guys 0 \/\/ /\/.
__________________
ASCII stupid question, get a stupid ANSII
PhyberOptik is offline   Reply With Quote
Old 05-17-2004, 08:59 PM   #11
Redwolf
I think hes half asleep when he writes these sometimes Gary.
Basicly a problem with "smoke"
__________________
Imagination is a powerful tool.
Redwolf is offline   Reply With Quote
Old 05-17-2004, 09:14 PM   #12
chilly1
HVAC/R Engineer
chilly1's Avatar
__________________
heatware
Old 05-18-2004, 02:19 AM   #13
Gary Lloyd
X.I.P.
Gary Lloyd's Avatar
He's from the city that never sleeps.
I'm still trying to figure out what a CPEV is. As near as I can tell, it's an AEV.
__________________
Old 05-18-2004, 03:58 AM   #14
chilly1
HVAC/R Engineer
chilly1's Avatar
Constant Pressure Expansion Valve Yes it is an Automatic Expansion Valve.
__________________
heatware
Old 05-18-2004, 05:03 AM   #15
Sidewinder
Sidewinder's Avatar
Send a message via ICQ to Sidewinder
Berlin? :o
__________________
dual ... quad ... hexal ... octal ... hexadecal?
Sidewinder is offline   Reply With Quote
Old 05-18-2004, 05:07 AM   #16
Hobocrow
Isn't the CPEV on the evap modified ... seems I read that in a very early post.
Hobocrow is offline   Reply With Quote
Old 05-18-2004, 08:25 AM   #17
chilly1
HVAC/R Engineer
chilly1's Avatar
Only the settings are changed the device remains the same... O teah the internal is set a little different I lower the sprinc tention a half anotch..
Old 05-18-2004, 03:40 PM   #18
Redwolf
Ya the strangeness has something to do with all the flashing lights and noisy buzzers, I think. Either that or Fugger keeps him up all night wanting to see that Ultimate O/C.
__________________
Old 05-18-2004, 04:03 PM   #19
chilly1
HVAC/R Engineer
chilly1's Avatar
They say it's the heat ... working on rooftops for the last nine years in the summers and temps around 140 with the rubber of your sneakers melting away in two weeks or less...
__________________
heatware
Old 05-18-2004, 04:33 PM   #20
Redwolf
If only we could all be so lucky... I feel for you guys down there.
140F... Do you guys get alot of blow offs from pressure reliefs or by passes opening up?
I'd be afraid to even carry around refrigerant jugs. I've seen an old boss of mine do that.. /rolls eyes.
__________________
Old 05-19-2004, 07:10 AM   #21
Hobocrow
Chilly1, hehe ... I just knew that cpev on the evap was tweaked!
Old 05-20-2004, 05:12 PM   #22
chilly1
HVAC/R Engineer
chilly1's Avatar
I used to be very afraid. The iside of the van parked could reach 150F But never a one... Some guys who over charge the recovery tanks get a blow off or two. and you hear of someone not tying their tank down and it blew in the truck but not much...Mostly wear out shoes and drink way too much water ten 2 liter bottles a day plus what I drink at home.. At a minimum... We get a hugh number of burned out condenser fan motors with this heat they operate about 10 degrees above their maximum temperature. Even the new R410 systems dont have trouble.. The head is a little high at 550 psi discharge, but it appears to work ok.. So this is for all the worriers about cascades out there the cascade systems we build the head pressure seldom exceeds 300psi...
Old 05-29-2004, 09:33 AM   #23
extremecorvette
extremecorvette's Avatar
Nice, so with this system you can run 24/7 at around -50 and them drop it to -100 for benchmarking?
__________________
AMD FX-57, ATi EXPRESS 200 Motherboard, 1GB TCCD, 74GB Raptors in 0-Raid, RADEON X850 XT Platinum PCI Express, Logitech Z-5500 Speakers, Samsung 191T+
Phase-Cooling
extremecorvette is offline   Reply With Quote
Old 05-29-2004, 02:12 PM   #24
chilly1
HVAC/R Engineer
chilly1's Avatar
Not really if you build a chiler that is an option. with phase change a Temp range of -70 to -100 is possiable. Fractional HP compressors don't have unloaders..
__________________
heatware
Old 05-29-2004, 02:42 PM   #25
extremecorvette
Ok, but is -70 ok to run 24/7 and safe
__________________
Phase-Cooling
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
{vb:raw chatroll.html}
