03-04-2004, 04:48 PM
#1
Water_Chiller gallery
Now that water chilling has its own area we should also have a gallery
I'll start with mine
clean looking huh
I vaccumed it today so hopefully soon i will have it going
also the compressor on this sys is a 9000 btu Window AC compressor that i got from ebay
__________________
03-04-2004, 06:14 PM
#2
I am Xtreme
hey I was gona make this thread
Anyway yea mines a suckey loud over charged big ass window AC
Gona fire it up again when my mag3 for my gaming rig comes monday (stole chillers eheim 1250  ) than I'll start my own... FINALLY!
__________________
Phenom II 940 BE / ASUS M4A79 / HD5770
3808mhz CPU 2720mhz NB | DDR1088 5-5-5-15 | 975/1300
03-04-2004, 06:16 PM
#3
I am Xtreme
__________________
03-04-2004, 10:37 PM
#4
Lookin schweet, i might braze mine up soon once ig et some fill gauges etc.
__________________
Ripping it up on old technology
i4memory.com
03-05-2004, 11:46 AM
#5
03-05-2004, 11:54 AM
#6
Banned
could we get a peek inside your res?
03-05-2004, 12:12 PM
#7
I am Xtreme
I love how its in a case and so well insulated
__________________
03-05-2004, 12:22 PM
#8
Banned
yea I really need to insulate my beer cooler its a few degrees below ambient.
03-05-2004, 02:03 PM
#9
cold_ice what did you use to hold styrafoam together?
03-05-2004, 02:20 PM
#10
Hi fellas,
Still working on it, but here's a teaser...
Was just a testrun, no load other then missing lid (and top insulation).
03-05-2004, 08:25 PM
#11
Well this isnt my rig but i sure hope it was:
http://www.voodoopc.at/
It is waterchilled
__________________
________QUIKSILVER_______
03-05-2004, 08:40 PM
#12
I am Xtreme
Thats regular watercooling that they try to make sound special
__________________
03-06-2004, 04:08 AM
#13
@afireinside: thx mate
I have the same PSU
@iceman2g: Did you mean the wodden box for the water? You don´t need anything to hold it together
My chiller is not so powerfull like some chillers here (water temp is -10° to -15°), but it´s enough at the time. And in the next few weeks I´ll biuld a direct die system...
03-06-2004, 04:11 AM
#14
What exactly is that block cold_ice?
__________________
i4memory.com
03-06-2004, 04:31 AM
#15
It´s a selfmade one
Some pics:
With some silicone
insulated
On the mainboard
03-06-2004, 04:34 AM
#16
Dude nice, small tubing though.
__________________
i4memory.com
03-06-2004, 12:55 PM
#17
It is waterchilled
I wouldnt call that rig "waterchilled", AFAIK, its watercooled , but not with chilled water.
__________________
Asus G60VX : Intel P7450@2.53GHZ : Nvidia GTX260M @ 575/975/1400
Iraq Veteran OIF 2008
03-07-2004, 07:48 AM
#18
im not sure about that....Everyone here has told me that...but everyone at voodoopc has told me something else!!!(voodoo forums)!! I know it sounds obvious on who to believe but many people have that Rig and have actually seen that it is liquid chilled!!
i have a question about that....They say that voodoo doesnt want to bring down the temps too low because of the risk of condensation!! Is there any way to avoid this??
__________________
03-07-2004, 08:17 AM
#19
2.4C killer
You can tell in that link with pics that it is just plain jane'r water cooling. Liquid chilled just sounds better, so thats what their going to put
03-07-2004, 11:08 AM
#20
Ill try to find better pics....
Btw heres something the president of voodoo said
http://www.voodoopc.com/boards/messa...284&forum=1027
And I really dont think that he is lying because millions of magazines have reviewed this rage F:1 ..and are probably sure that it is not watercooling....Say for example computergamingworld magazine rated it as the best gaming pc!
__________________
03-07-2004, 11:31 AM
#21
I am Xtreme
I heard in the WC section here its an 80 watt pelt or something :|
Thats just sad. They would have to insulate to prevent condensation.
__________________
03-07-2004, 11:36 AM
#22
It seems it would be some TEC system...........keeps the coolant at or just above ambient.
If chilled below ambient, insulation and condensation proofing would be needed.
__________________
Heat
Gimme back my bullets.
03-07-2004, 01:12 PM
#23
Xtreme Guru
Is DI chiler accepted? If yes i will post someics in like 1 week.
03-07-2004, 11:39 PM
#24
Is it possible to have a type of waterblock for using it with dry ice.
like dis:
[__]
- = barbs
[ ] = container
__________________
i4memory.com
03-08-2004, 12:39 PM
#25
Xtreme Guru
I dont think so, but my Di chiller will be in a freezer(w/o compressor) and i will put a kind of bug net like 5-10cm over the water and I will put some DI on that. And the DI is -80C, so the water will chill very fast.
And after i will put some DI on my water block(just to bring a little cooler). My DI is free, so i can some anywhere.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
