Results 1 to 25 of 34
Thread: UD4 vs UD7 3Dmark2001 Sli and Single card Compared.
Threaded View
    take me to the manbar
    Apr 2008
    South Africa :)
    Yo guys! (please move to more appropriate section if it does not fit here)
    Getting ln2 tomorrow only.. so while i'm bored i did this.
    Quck history:
    I had a UD4 1st, was happy with it. But i wanted to run dual card 01, and the 16x 16x on UD7 sounded juicy. So i bought a UD7 and some of my scores went down a little. Probly because the NF200 chip not so good for single card. It's also not so good dual card. (only tested 2001 though).
    So i compared results from UD4 VS UD7.
    All my tests done at SAME speeds. Everything identical.
    System:
    Gigabyte P67A-UD4-B3 and P67A-UD7-B3
    Corsair 2000mhz cl7 memory (1066 7-7-7-20 1T)
    Corsair 950W psu
    2600k (5.015ghz)
    2x MSI 275 Lightnings (750 / 1250)
    Just some pointers when using 182.50 nvidia drivers and P67 boards you need to use the sli hack to make sli work. And if you want to overvolt msi 275 lightnings on 182.50 drivers use madmatrix tool.
    Here we go:
    UD4 Left / UD7 Right (Single Card)
    Full Screenshot
    UD4 Screenshot
    UD7 Screenshot
    UD4 Left / UD7 Right (Dual Card)
    Full Screenshot
    UD4 Screenshot
    UD7 Screenshot
    The difference is quite big. The higher you go with cpu speed the bigger the difference will get.
    Seems like UD4 slacks a LITTLE in nature dualcard. But the other tests make more than up for it.
    As far as my testing go's the UD4 (probly ud5 aswel) is much better for 2001sE than the UD7.
    Cool
