Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Thread: Crysis 2 is Horribly CPU Dependent
    Live Long And Overclock
    Sep 2004
    I was watching a Crysis 2 video of someone with a Phenom X6 1100T and a 5770. I wondered why someone would spend $200 on a CPU and and only ~$100 on a GPU, and yet, to my surprise, it makes quite a bit of sense:
    (Remember, all of the above is with the exact same video card)
    On the same CPU/GPU budget, had he gone for an Athlon and a 6870, he would actually have gotten lower performance.
    I'm assuming this dependency will be reduced once the DX11 patch comes out.
    Dec 2010
    Nor*cal
    console port, lol
    Sep 2004
    Yup, the same is true of Black Ops as well.
    Xtreme Mentor
    Aug 2008
    Australia
    Hows it scale with more cores?
    Ci7 990X::Rampage III Extreme::12GB Corsair Dominator 1866C7GT::2 x EVGA SC Titans in SLI::Corsair AX1200::TJ07::Watercooled
    Ci7 920 3849B018::Rampage II Extreme::6GB GSKILL Trident 2000C9 BBSE::EVGA GTX580::Antec Signature SG850::TJ09::Aircooled w/TRUE 120X
    Sep 2004
    Quote Originally Posted by CryptiK View Post
    On the lower end, it has linear scaling i.e. a Quad core will have double the performance of a Dual core, given the same GPU.
    It loves hyperthreading (based on how the Core i5 performs) and L3 cache (as apparent from the difference between the Athlon Propus X4 and the Phenom X4).
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    Quote Originally Posted by perkam View Post
    it looks like it needs 4threads and dose not care about HT to me, with the intel 2500 v 2600 and the 1100 v 975 amd
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Jul 2004
    U.S of freakin' A
    Crysis 2 is perhaps the only game I've ever played where I see activity in all 8 windows of the CPU usage history in the task manager. Thats a good thing though, seeing as CPUs are becoming more and more parallel in nature..
    Intel Core i7 6900K
    Noctua NH-D15
    Asus X99A II
    32 GB G.Skill TridentZ @ 3400 CL15 CR1
    NVidia Titan Xp
    Creative Sound BlasterX AE-5
    Sennheiser HD-598
    Samsung 960 Pro 1TB
    Western Digital Raptor 600GB
    Asus 12x Blu-Ray Burner
    Sony Optiarc 24x DVD Burner with NEC chipset
    Antec HCP-1200w Power Supply
    Viewsonic XG2703-GS
    Thermaltake Level 10 GT Snow Edition
    Logitech G502 gaming mouse w/Razer Exact Mat
    Logitech G910 mechanical gaming keyboard
    Windows 8 x64 Pro
    May 2007
    Europe/Slovenia/Ljubljana
    Ppl were cheering that it's finally using all cores on ther quad up to 80% each. What i'm having hard time understanding is on what the hell they use so much CPU. Ai is retarded, world is completely static and physics, well they don't exist. Then what is using so much of the CPU!?
    Intel Core i7 920 4 GHz | 18 GB DDR3 1600 MHz | ASUS Rampage II Gene | GIGABYTE HD7950 3GB WindForce 3X | WD Caviar Black 2TB | Creative Sound Blaster Z | Altec Lansing MX5021 | Corsair HX750 | Lian Li PC-V354
    Super silent cooling powered by (((Noiseblocker)))
    Sep 2004
    West Covina. CA
    I'm sorry, but giving an example with a DUAL GPU highest end card on the planet is *NOT* showing that the game is CPU limited!!
    EVERY single freaking game on the PLANET is CPU limited with a GTX 590.
    I need to give the Falkentyne award to that graph:
    Ok now,
    If you want to show that the game is massively cpu limited, then run it on a hd 5870, 4890 or 6950.
    (or a GTX570, 460, etc..you get the point).
    Running a game on a high end dual GPU card is the WORST way to show that a game is massively CPU limited. You made it CPU limited by running on that card in the first place :P
    Xtreme Enthusiast TJ TRICHEESE's Avatar
    May 2009
    Quote Originally Posted by RejZoR View Post
    Yea i was hoping that it had physx but my physx card has 0% usage all through it
    Sep 2004
    @ Zanzabar, true, I guess I meant it likes Intel's architecture a lot better than AMD's, if a dual core with HT (i3 540) can outperform the Athlon X4 by a mile.
    @ Falkentyne, the idea that "OMG It's a 590, OFCOURSE it's going to look like that" is oversimplifying the issue here, which is a difference between GPU and CPU dependent games. Crysis 2 is a very CPU dependent game, and that is what the graph shows. It is true to a lesser extent with less powerful GPUs, but it doesn't change the fact that it is CPU dependent. In GPU dependent games, with a GPU like the 590, it wouldn't make much of a difference at all which CPU you used, AMD or Intel, Dual or Quad or Sexta because the GPU power would overwhelm anything the CPU would contribute.
    Dec 2004
    United Kingdom, South East England Kent
    Lighting calculations? And of course there is physics, just cause it doesn't have the blatantly obvious pre programmed destructible environments. There's lots of calculations which occur.
    Also-broken AI doesn't mean it's not complicated. Maybe they over complicated it from crysis 1 such that it just doesn't work so much, and infact they get stuck in a horribly inefficient state of constant calculation while standing still and going in circles. As I say, broken AI /= no AI
    Nov 2007
    I was shocked to find that a made for console, lazily ported to PC game actually supports octo core CPUs. Kind of like throwing the PC community a low priority bone with no meat on it isn't it? I'd have rather had quad limited support and advanced graphics options.
    As far as that bench goes though, another area it's deceptive is their choice of CPUs and CPU speeds. It gives the illusion the game does much better with a "faster" CPU, when in fact it's mainly that the default clock speed and Turbo Boost of the new SB chips that makes them "look" way faster. It's absurd to put a stock clocked 2.66 GHz 920 up against a 2600k with more efficient architecture AND much higher clock speed, not to mention way higher Turbo Boost.
    I am Xtreme
    Dec 2007
    im still lost as to how the athlon x4 3.0ghz is so much slower than the phenom x4 3.5ghz
    18% faster and L3 should not equal nearly double the framerate.
    2500k @ 4900mhz - Asus Maxiums IV Gene Z - Swiftech Apogee LP
    GTX 680 @ +170 (1267mhz) / +300 (3305mhz) - EK 680 FC EN/Acteal
    Swiftech MCR320 Drive @ 1300rpms - 3x GT 1850s @ 1150rpms
    XS Build Log for: My Latest Custom Case
    Jul 2007
    Athens
    Omg...
    CPU Limited to the bone!
    iMac 27" (mid 2011) Intel i5 2.7GHz, 12GB 1333MHz, Mac OSX Mountain Lion / iPad 3 16GB | White / iPhone 5 16GB | White
    FX 8150 oc@4.6 Ghz 1.38V / ASUS Crosshair V Formula / 16GB Kingston HyperX 1600MHZ / ASUS EAH 5870 1GB / Intel 320 Series 120GB / Silverstone Tj07 - Black / Corsair TX750v2 / Windows 8 Pro x64
    Apogee HD/Heatkiller GPU-X?/MPC655/360 Radiator
    Sep 2004
    West Covina. CA
    Well comparing it to the first Crysis, when it was released in, what was it, 2007? And the fastest card out was a HD 3870 or 9800 GTX (aka 8800 GTX), then yes, it's definitely CPU limited. The first Crysis was all GPU (but now it's CPU limited on the highest end cards, and STILL GPU limited to this day on lower cards). But I want someone to find me one game out right now that isn't CPU limited on a GTX 590 at 1920x1200.
    I'm not arguing the point, though, which is Crytek sold out to the underpowered console cpu crowd. Just that you shouldn't need a dual fermi to show it. If this were done with a 580 or 6970, then I can't say anything
    Oct 2010
    Italy
    this days i was trying this game, cpu @ 4.4ghz ht on with overclocked video card does an average of 5 fps more than 4ghz cpu speed ht on with stock speed gpu 80/85 --> 75/80 ... dx9 are nice in this game. .. i'm really dissapointed about the rest of the game.
  18. #18
    Jul 2007
    SF bay area, CA
    Quote Originally Posted by Falkentyne View Post
    the 9800gtx was a 8800gts 512MB, and crysis was made for what 3x8800ultra sli was theoretically going to do. and it was optimized for low shader count.
  19. #19
    Jun 2007
    Quote Originally Posted by zanzabar View Post
    the 9800gtx was a 8800gts 512MB, and crysis was made for what 3x8800ultra sli was theoretically going to do. and it was poorly optimized for low shader count.
    Fixed .
    Intel 6700K @ 4.3 GHz
    Gigabyte GA-Z170-HD3 DDR3
    4x4GB Corsair DDR3-2800
    GTX980Ti MSI Lightning
    Samsung 950 Pro 512GB
    4 x Intel 80GB x25-m SSD's RAID0
    Enermax Revolution 85+ 1250W
  20. #20
    Jul 2007
    SF bay area, CA
    Quote Originally Posted by chinobino View Post
    Fixed .
    no, it was optimized for low shader count, so it dose not scale with newer cards as shaders have not gotten faster just more abundant.
  21. #21
    Xtreme Cruncher
    Oct 2006
    1000 Elysian Park Ave
    No idea, game is a flop, call it news if BF3 is the same way.
  22. #22
    Nov 2009
    Well comparing it to the first Crysis, when it was released in, what was it, 2007? And the fastest card out was a HD 3870 or 9800 GTX (aka 8800 GTX), then yes, it's definitely CPU limited. )
    06 and 8800gtx was the card to have unfortunately i bought one thinking it would run on it and i couldnt enjoy the game til the 4870x2 came out and even then had lag here n there
  23. #23
    Feb 2007
    Arizona, USA
    The better question perk is IF it will come out.
    Core i7 920 D0 B-batch (4.1) (Kinda Stable?) | DFI X58 T3eH8 (Fed up with its' issues, may get a new board soon) | Patriot 1600 (9-9-9-24) (for now) | XFX HD 4890 (971/1065) (for now) |
    80GB X25-m G2 | WD 640GB | PCP&C 750 | Dell 2408 LCD | NEC 1970GX LCD | Win7 Pro | CoolerMaster ATCS 840 {Modded to reverse-ATX, WC'ing internal}
    CPU Loop: MCP655 > HK 3.0 LT > ST 320 (3x Scythe G's) > ST Res >Pump
    GPU Loop: MCP655 > MCW-60 > PA160 (1x YL D12SH) > ST Res > BIP 220 (2x YL D12SH) >Pump
  24. #24
    Sep 2007
    Alberta, Canada
    Wow they're lucky it doesn't look like this with their Multi GPU setup..
    Here's my crysis 2 experience :P
    http://www.youtube.com/watch?v=DjpN5HoX8xA
    EVGA z68 FTW
    i7 2600k @ 4.8
    8gb DDR3 1600
    3x GTX 580 3gb HydroCopper2
    Silverstone Strider 1500W
    Areca 1880i w/ 6x intel x25m
    On water
  25. #25
    Nov 2004
    Denmark
    Quote Originally Posted by InCredible View Post
    November 17th 2007, Crysis 1 ...
    But yes, 8800GTX was still the fastest card around, and IIRC, I got decent FPS with a mix of high, med and a couple of low settings at 1400x900... Still looked amazing, but running it with all very high on a HD5800 at 1900x1200... No comparison :P
    Silverstone RAVEN RV02|
    Core i5 2500K@4.4GHz, 1,300V|
    Corsair A70|ASUS P67 Sabertooth|Creative X-Fi Titanium Fatal1ty|
    Corsair Dominator DDR1600 4x4096MB@DDR3-1600@1.65V|Sapphire HD7970 3GB 1075/1475MHz|
    Corsair Force F120 120GB SSD SATA-II, WD Caviar Black 2x1TB SATA-II 32mb, Hitatchi 320GB SATA-II 16mb|Silverstone DA750 750w PSU|
