Results 1 to 7 of 7
Thread: Help - Asus P8P67 Deluxe Rev. 3.0 - CPU RED LED / Q-Code 30 - not booting
    Sep 2006
    I have problem with boot on this motherboard, it gave me red CPU LED when are installed two memory modules in blue slots, nothing on Q-Code is showing, when I leave one module in A2 I have red RAM LED and Q-Code 30, when I hit MEM OK its start blinking, restart computer several times and still nothing happen.
    Memory are G.Skill Ripjaws 2x2gb F3-12800CL7D-4GBRH compatible with this m/b they are on Asus QVL list and they are ok on 100%, I tried reinstall with no luck.
    Tried clear CMOS on rear backplate button, nothing helped.
    I remove cpu and checked socket pins on m/b all are good, but still have this problem
    8pin connector is connected
    CPU; 2600k - brand new
    MEM; G.Skill Ripjaws 2x2gb F3-12800CL7D-4GBRH - 100% fine from my previous setup
    GPU: EVGA GTX 280 - 100% fine from my previous setup
    PSU: Corsair HX620W - 100% fine from my previous setup
    Please help
    Xtreme Cruncher
    Jun 2009
    Bombay , India
    Try removing the battery and leaving it like that for 20 mins. Also keep the Clear Cmos button pressed for like 30 seconds with the battery out of the mobo
    Intel Core i7 3960x | 3x Intel Core i7 980x | 3x Intel Core i7 920 | 2x Intel Core i7 2600k | 2x AMD opteron 6282 SE | 3x Asus Rampage II Extreme | 2x Asus Rampage III Extreme | Asus Rampage IV Extreme | 1x Gigabyte X58A-UD7 | 2x Asus Maximus IV Extreme-Z | Asus KGPE-D16 | 3x 6GB DDR3 Corsair Dominator 1600 Cl7 | 1x Patriot Viper II 6GB 2000 Cl8 | 3x Corsair Hx1000 | 4x Corsair Ax 1200 | 3x Antec 1200 | 4x Corsair Obsidian 800D | 2x Intel 80Gb G2 SSD | 4x Kingston HyperX 120GB | 2x Vertex 2 120GB | 2xWD 150GB Velociraptor + 1x WD 300GB Velociraptor +5TB | Msi Nvidia Gtx 295 | Msi Ati 4870x2 OC Edition | 2x Msi Ati 4890 OC Editions| 2x Sapphire Ati 5870's| Sapphire 5970 OC Edition | 2x Msi Gtx 460 | 3x Sapphire 6970 | 3x Asus Gtx 580 | 3x Asus 7970
    Sep 2006
    not helped same problem
    May 2007
    Calgary, Alberta. Canada
    I had a simalar problem when changing from Mushkin to Gskill. I reset CMOS with power unplugged. Then Installed one stick in slot A2. It started, I then set the timmings in bios saved, shut it down then added the other stick, been running good since.
    Rig 1
    CPU: i7-990X. CASE: Antec Nine Hundred II. CPU Cooling: TR Venomous X RT. MOBO: ASUS Rampage III Formula. RAM: 12GB Mushkin DDR3 1600 CL7. GFX: EVGA GTX 580's x 2. SLI. HDD's: 1.5 TB Seagate, 1TB WD Sata III. Monitor: Samsung 25". PSU: Corsair AX 1200W. Win 7 64 Bit
    Rig 2.
    CPU: i7-2600K. CASE: Antec Nine Hundred II. CPU Cooling: TR Venomous X RT. MOBO: ASUS P8P67 Deluxe. RAM: 4 GB GSkill Ripjaws X DDR3 1600 CL6. GFX: EVGA GTX 580. HDD: 1TB WD Sata III. Monitor: Samsung 23". PSU: Corsair AX 1200W. Win 7 64 Bit.
    Sep 2009
    Dont use any Windows 7 L0adr some people had that problem
    Sep 2004
    West Covina. CA
    Windows 7 loader has no effect on if a computer will enter BIOS or not.
    Mar 2011
    Quote Originally Posted by PeterMac View Post
    Please help
    I am barely experienced in OCing matters. But, note that I had a different problem when using DRAM that apparently runs best at about 1.65V--which is the top value yielding general predicted safety on our boards.
    I was able to forget about having any DRAM-related problems when I switched to Corsair Vengeance (1.5V). The DRAM always runs at 1600 to 1648 MHz unless my OC settings are very conservative. I don't know if making such a switch might help you since I have scant info on your RAM, but you might consider whether a switch could be desirable.
    Intel 2600K with Zalman CNPS9900MAX-B Fan
    ASUS P8P67 Deluxe Rev B3
    ASUS EN GTX 470
    Cooler Master 932 HAF
    Cooler Master Silent Pro Gold 1000W
    8 GB Corsair Vengeance @ at least 1600 depending
    64 Bit Win7 Ultimate RAID 0 on WD Caviar Black SATA 3.0's
    Pioneer Blu-ray Burner and Samsung DVD Burner
