Page 1 of 2 12 LastLast
Results 1 to 25 of 45
Thread: I can prove that Bulldozer will work in AM3 sockets
    Xtreme 3D Team
    Jan 2009
    Ohio
    Foxconn AM3b leaked socket info shows solder joints on the back of the socket, and I'm pretty sure I can prove that as long as Bulldozer does not include a dummy pin (which literally would not have any electrical contact to the board), Zambezi will fit and according to manufacturers operate in an AM3 socket and board with just a BIOS update...
    THAT IS, provided all of the required AM3 pins were soldered...
    Anyone still skeptical should look at the pics I'm about to post up
    I am Xtreme
    Dec 2008
    France
    In ALL of them? I wouldn't be so sure.
    I assume you've seen this post:
    Quote Originally Posted by nex_73 View Post
    Ok, a little more info from kinc
    Featured AM3 processors such PII X6 uses 938 of 940 AM3s connection entries (two of which were never and are not routed by default, except the cards ASUS lists in their press release). AM3 + socket has 941 connections. AM3 + CPUs, however, has 940 connections, the exact same number of AM3 socket. Hence it is suitable even reasonable physical. Just be aware that it "only" works in practice with the motherboards on ASUS list.
    Important to say is that it's only those who work when they have the correct routing to the power circuitry to operate a AM3 + CPUs.
    So there you have the explaination to why it doesn't work on ex: gigabyte boards before v3.1
    Asus has routed the extra am3 socket pin-holes on the listed models, where the other manufacturers have not.
    Donate to XS forums
    Xtreme 3D Team
    Jan 2009
    Ohio
    Quote Originally Posted by BeepBeep2 View Post
    Quote Originally Posted by zalbard View Post
    I am Xtreme
    Dec 2008
    France
    Which means it will only work in selected motherboards, and these have been officially mentioned already.
    Maybe we'll see more pop up, though, who knows.
    Donate to XS forums
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    I said for one week ago some simillary...Again.
    AM3 socket=941 pins, standartly 938 electrically active into motherboards AM3 CPUs=938pins
    AM3+ socket=942 pins AM3+ CPUs=940 or 941 pins
    my theory: some ASUS boards has from begining at AM3 boards (from support list) electrically active all possible conections for pins, so this is 941. Second condition is big flash rom
    ROG Power PCs - Intel and AMD
    Xtreme 3D Team
    Jan 2009
    Ohio
    It's been said but not proven, just want to show some pics showing each socket and the way that AM3b is soldered compared to AM3
    Xtreme 3D Team
    Jan 2009
    Ohio
    If correct AM3 pins were soldered as foxconn shows in the user guide then Zambezi would definately work in ALL foxconn AM3 sockets considering the AM3+ CPU does not have a pin where the key is gone in the new AM3b socket.
ID:	113070   Click image for larger version.
ID:	113071   Click image for larger version.
ID:	113072   Click image for larger version.
    Xtreme Mentor
    May 2008
    cleveland ohio
    who cares AM3+ takes AM3 chips.
    it's not like sandybridge where they went from 1156 to 1155, and don't fit each other.
    HAVE NO FEAR!
    "AMD fallen angel"
    Quote Originally Posted by Gamekiller View Post
    You didn't get the memo? 1 hour 'Fugger time' is equal to 12 hours of regular time.
    Xtreme 3D Team
    Jan 2009
    Ohio
    Quote Originally Posted by demonkevy666 View Post
    Because a lot of us own AM3 boards already and don't want to spend another $250 for a board?
    Aug 2010
    Illinois
    ... Asus has said they will offer bios updates with limited support for their 8xx series boards for a bit now.
    Jul 2010
    Birmingham, United Kingdom
    I wonder if some 7xx series could be updated as well lol
    Jul 2009
    Quote Originally Posted by Panther_Seraphi View Post
    seeing how bad some 7 series boards did thuban, I'd be hesitant to even try.
    Xtreme Enthusiast TheBlueChanell's Avatar
    Dec 2006
    I really feel like 990FX was supposed to be launched by now. We are getting bastard children now.
    Main: 900D - Prime 1000T - Asus Crosshair VI Extreme - R7 1700X @ 4.0ghz - RX Vega 64? - 32GB DDR4 3466 - 1TB 960 Pro -
    --- XSPC AX360 x3 - HK IV Pro - HK RX480 - HK 200 D5 - BP Compression ---
    HTPC: 250D - Prime 850T - Gigabyte G1 ITX - i7 6700K @ 4.5ghz - GTX 1080 Ti - 16GB 3200 - 1TB 960 Pro -
    --- ST30 x UT60 - Kyros HF - KryoGraphics 1080 - HK100 DDC - Monsoon Compression ---
    HV01: Define XL R2 - Prime 1200P - Asus Zenith Extreme - TR 1950X - RX580CF - 128GB DDR4 ECC - 512GB 960P - 4x 2TB RE
    HV02: Node 804 - Prime 850T - SuperMicro X1SSH - E3-1230 v6 - Vega FE - 64GB ECC - 512GB 960 Pro - 4x 6TB Gold -
    May 2008
    Czech republic
    hm, whats better for you as overclocker? Better performance with new board or lower performance with older boards? For me its first. I like AMD and still Im hope for better days, when we will see better average performance at AMD side.
    Maybe for one year ago AMD said, they have solved lower performance and AM3 socket or better performance and TDP with new socket. Think, the choice was right-better TDP and higher performance. Long time compatibility from AM2 socket was OK, but nothing will can be forever.
    Xtreme 3D Team
    Jan 2009
    Ohio
    Quote Originally Posted by FlanK3r View Post
    Most 890 boards will do 2600-3000 HT Link, a lot of them support DDR3-2000 ram or above, 890FX has support for IOMMU and they also for the most part have strong pwm.
    To say that there will be "lower performance with older boards" is a gross estimation.
    May 2008
    Czech republic
    I think, Bulldozer can 2400 MHz RAM "easily", here will be problem find so good RAMs for it
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    Are you talking Chew* easily, or me easily here?
    Quote Originally Posted by iddqd View Post
    Not to be outdone by rival ATi, nVidia's going to offer its own drivers on EA Download Manager.
    X2 555 @ B55 @ 4050 1.4v, NB @ 2700 1.35v Fuzion V1
    Gigabyte 890gpa-ud3h v2.1
    HD6950 2GB swiftech MCW60 @ 1000mhz, 1.168v 1515mhz memory
    Corsair Vengeance 2x4GB 1866 cas 9 @ 1800 8.9.8.27.41 1T 110ns 1.605v
    C300 64GB, 2X Seagate barracuda green LP 2TB, Essence STX, Zalman ZM750-HP
    DDC 3.2/petras, PA120.3 ek-res400, Stackers STC-01,
    Dell U2412m, G110, G9x, Razer Scarab
  18. #18
    Aug 2010
    Illinois
    Quote Originally Posted by TheBlueChanell View Post
    Who launches boards 4 months in advance?!?
  19. #19
    Jan 2009
    SF
    Quote Originally Posted by ChanceCoats123 View Post
    Well AM3 cpus fit in AM3+ boards, why not?
  20. #20
    Xtreme X.I.P. Particle's Avatar
    Apr 2008
    Kansas
    Let's be realistic. Most of the boards "we" buy are typically priced $150 to $200. There is no need to exaggerate here. I'll also never buy the whole argument about needing to keep a motherboard for cost reasons when we aren't regular consumers. We pay extra for top-end power supplies, RAM, chips, often even considering upgrading to just a later speed bumped model less than a year after we get one. Quibbling over a motherboard because of cost when we clearly aren't engaged in a cheap hobby and readily spend money on the seemingly more exciting parts is so artificial. The truth of the matter is that motherboards aren't very exciting compared to processors and are a pain in the butt to change. Thus, the prospect of buying new ones is often not very exciting. It made sense back in the day when a motherboard cost more than the CPU you were going to plug into it, but when that changed the sentiment of which was more painful to pay for should have as well. It never did.
    Particle's First Rule of Online Technical Discussion:
    As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
    Rule 1A:
    Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
    Rule 2:
    When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
    Rule 2A:
    When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
    Rule 3:
    When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
    Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
    Random Tip o' the Whatever
    You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
  21. #21
    May 2008
    Czech republic
    Quote Originally Posted by eXa View Post
    talking about Zambezi, not Thuban. Thuban is in comparsion with Zambez crapp . And with Thuban is 2000 MHz with 2x2GB stable and good motherboard easy for average user.
    part1
    part2
  22. #22
    May 2004
    Unfortunately this is based on absolutely nothing
  23. #23
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    part1
    part2
    I know that you were talking about BD, my question is still valid
    Edit: Not doubting that your ram is stable, but you should use prime95, not linpack for testing ram/imc on AMD
  24. #24
    Aug 2004
    Brasil, S.P.
    Quote Originally Posted by Shadowized View Post
    where?
    mine is doing very fine... I wouldn't change if not needed.
    3dm11 P9489 / Gigabyte 790FXT-UD5P / 1090T @ 4.32 Ghz / 2x ATi HD 6870 @ 1092/1124Mhz / 2 x 2 GB Super Talent @ 1730Mhz 6-6-6-18
    http://3dmark.com/3dm11/875250
    990FXA-UD3 | FX8350@4.7Ghz | Asus HD7870 | 2x 4GB Crucial Ballistix Tracer 2050Mhz 8-8-8-22 | AX850W |SSD Vertex3 Max IOPS 120GB | Auzentech Forte + TAPCO-S5
    EK Supreme Full-Gold | XSPC RX240 + EX120 | MCP35x | 3x Koolance Blue Led @PWM | Tygon Black 1/2 | Bitspower Compression | @ FM CM690 I
  25. #25
    Aug 2006
    Some 8 series boards suck with thuban. Got my ch3 up to 4580mhz with thuban and water. Depends entirely on the board chip and person clocking.
    Personally I think this is a waste of thread space. Some boards will update some will not exactly as phenoms in am2 boards did.
