Results 1 to 25 of 76
Thread: FancyCache - software RAM based disk cache
Threaded View
    Oct 2006
    Kirghudu, Cowjackingstan
    Thumbs up FancyCache - software RAM based disk cache
    Well, finally there's a poor man's software disk cache. Note that this is not a RAM drive. You simply enable portion of your RAM as a disk cache.
    It's beta right now and is 90 day free trial.
    Homepage: http://www.romexsoftware.com/en-us/f...che/index.html
    Benchmarks: http://www.romexsoftware.com/en-us/f...use-cases.html
    How-to: http://www.romexsoftware.com/en-us/f...ache/help.html
    Features:
    * Supports LRU (Least Recently Used) and LFU (Least Frequently Used) cache algorithms
    * Supports caching strategies: Read/Write Caching, Read-Only Caching and Write-Only Caching
    * Supports Write-Through and Write-Deferred modes
    * Supports OS Invisible Memory and SSD (Solid-state Drive) as Level-II cache
    * Supports caching for volumes or entire disks
    * Supports TRIM command for SSD
    * Supports visual performance monitor
    * Supports cache plug and play
    * Supports basic and dynamic disks
    * Supports NTFS junction point
    * Supports volume/disk with proprietary file system
    All runs below are on P67 with 2R0 X18-M G1 on SATA2 ports...
    My fast and dirty C:\ CDM run (<Cache Size).
    CDM 2Gb > cache size. Need some tweaking to do since I also have Write Caching enabled in Windows.
    AS SSD
    Winsat
    My set-up
    Sony KDL40 // ASRock P67 Extreme4 1.40 // Core i5 2500K //
    G.Skill Ripjaws 1600 4x2Gb // HD6950 2GB // Intel Gigabit CT PCIe //
    M-Audio Delta 2496 // Crucial-M4 128Gb // Hitachi 2TB // TRUE-120 //
    Antec Quattro 850W // Antec 1200 // Win7 64 bit
Tags for this Thread
